Do i need the LS1 sump still if i get the Hawks engine mount kit?
Old May 22, 2009 | 05:41 PM
evilstuie's Avatar
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
Hey guys, just wanted to know if the hawks complete ls1 conversion mount that can use the stock arms changes anything with the oil pan configuration?
I'm in Australia so 4thgen sumps are hard to come by and $295US from hawks seems a bit rich for a stock sump.
Old May 27, 2009 | 01:09 PM
87tpi350,6spd's Avatar
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
Re: Do i need the LS1 sump still if i get the Hawks engine mount kit?
What pan do you have? or can get.
Old May 27, 2009 | 03:04 PM
evilstuie's Avatar
Very nice lookin transAM by the way.
I can get a Holden commodore / monaro sump that would come with it.
I believe it would be the exact same as your 2000-2005 Pontiac GTO sump?
USA bought it off us from our Monaro :P
Old May 27, 2009 | 03:09 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Yep, but the monaro & Commodore are far better looking then their US counterparts
As for the oil pan situation, unfortunately, the monaro uses a front sump system, which falls exactly into the thirdgen k-frame and steering.
Unfortunately, unless you go to an aftermarket pan, the f-body is the only sump that will work.
Hawks is designed around a Pull out f-body LS1. So their kit only works with the f-body pan.
Old May 27, 2009 | 04:12 PM
evilstuie's Avatar
damn it.
How much can you get a f-body ls1 sump at the wreckers over there?
Coz the one hawks has just seems a bit too over the top
Old May 27, 2009 | 04:15 PM
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
Yeh the gto style pan is a definate no go. Check around on ls1tech Thats where I got mine from. I belive I only paid a little over 100 for it.
Old May 27, 2009 | 04:32 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
damn it.
My pan/windage/pickup was $150us shipped.
Old May 29, 2009 | 02:35 PM
screeminchicken's Avatar
check out LS1tech.........I am sure u will find somebody who can ship for $100
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
drathaar907
Aug 6, 2015 04:20 PM
