Removing and Installing Motor Mounts
Old May 30, 2009 | 10:08 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
I am puzzled as to how I am supposed to remove my old motor mounts from my K-Member let alone put on the LS1 style horseshoe mounts. My problem is that the nuts on the back / inside of the k-member are just spinning. I don't see how it is possible to get a wrench on the back side of those nuts. Any idea's?
Old May 30, 2009 | 11:05 PM
andrew69_04's Avatar
Car: 92 Camaro RS
Re: Removing and Installing Motor Mounts
I did mine with the suspension removed, was a piece of cake. i know it can be done on the car, but its a bit more work to try to get in there.
Old May 31, 2009 | 12:14 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
I just replaced my motor mounts today (motor not in car)! It can be done w/ the suspension and control arms in place. This is for V8 mounts. I haven't done V6 mounts so I don't know if it is different. Slide a 15mm wrench through the hole in the back side of the k-member to remove the top bolts and nuts. You can reach the lower bolt and nut w/ a short 15mm socket, extension, and universal/flex adapter. To put the bolts/nuts back on, get a extendable magnet and fish the nut w/ washer in the k-member. Turn the bolt by hand while holding the nut and washer w/ the magnet. It can be tricky, but it is possible.
Old May 31, 2009 | 07:08 AM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Agreed. What I did was to securely tape one open-end wrench to another, which (effectively) made a longer wrench. It was a PITA, but I was able to get all three nuts on each side. (All of my suspension was still attached as well.)
Then, when putting the nuts back on, I'd put a piece of tape over one side of the wrench (I think I used the box end this time) so that the nut would stay *somewhat* attached to the wrench, which allowed me to get the bolt threaded into the nut - and once it was tightened, I could pull the wrench away & move on to the next one.
Hope this helps.
Old May 31, 2009 | 09:45 AM
Shift06's Avatar
Thanks for the help guys, I am not looking forward to this though lol.
Old May 31, 2009 | 06:24 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Tape works too. I used a magnet so that I could hold the washer and nut together while trying to thread the bolt to the nut.
Old May 31, 2009 | 07:29 PM
RevItUpZ28's Avatar
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
Yeah, its all good until you drop the washers down the k-member and have to fish them out with a magnet! PITA haha, good luck.
Old May 31, 2009 | 09:15 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
LOL, exactly or it falls down and hits you in the face--doh.
Old May 31, 2009 | 09:16 PM
Shift06's Avatar
Awesome, worked like a charm. They actually came out quite easily, though I had a guy on the other side loosening while I held the nuts with the socket. Thanks again for the help guys.
My stock mounts had copper washers for whatever reason so that probably wouldn't work for me, though I didn't drop any anyways.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Elliswon
Aug 10, 2015 12:33 PM
3rdgenparts
Aug 8, 2015 07:09 PM
NBrehm
Aug 5, 2015 07:57 PM
