How big a cowl hood needed?
Old Jun 20, 2009 | 05:43 PM
Orangepeeler's Avatar
For those that have completed the swap. I have a Victor jr. and a 1" nitrous plate, was wondering how tall the cowl would need to be to clear the carb? I had a 6" cowl last time and didn't want to try to drive it on the street.
Old Jun 20, 2009 | 06:13 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: How big a cowl hood needed?
i'd imagine 2" with the proper drop base air cleaner would fit. I have a 4" and fit a 6" tall air cleaner with a drop base. So take that for what it's worth. personally I'd measure your setup and decide for yourself.
Old Jun 20, 2009 | 06:45 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
i have an ss hood and i cant run an air cleaner with a victor jr and a nitrous plate.
i now have a super victor and cant even run my plate.
ss hood isnt quite 2", but beware. dont know if 2 would get it done.
very close. tough call.
Old Jun 20, 2009 | 09:08 PM
Thanks for the replies. Just trying to get an idea from those who already have theirs together. I would like to use the shortest hood possible. I like the looks of the big cowls but the function leaves alot to be desired.
Old Jun 20, 2009 | 10:09 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
how tall is the average carb and air filter? I have the efi victor manifold with a intake elbow thats 6.5-7 inches taller and I needed a 4" to clear. Leaves about an inch of clearance underneath it so possible a 3" cowl would have cleared.
Old Jun 21, 2009 | 08:56 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
i had a 383 in the car with a victor jr, carb and a FOUR inch drop base setup.
with the ls1 and a victor jr, i had to run a 3" filter. with a nitrous plate and a hvh spacer, air cleaner wouldnt even think about fitting.
ls motor is a lil taller.
Old Jun 21, 2009 | 02:53 PM
xpndbl3's Avatar
Car: 1984 Z28
that's weird, my motor must be lower in the chassis because i have a 6" drop base air cleaner, vic jr, performer rpm nitrous plate and a 950 carb under my hood with about 1/4" gap under my glasstek 4" cowl
Old Jun 22, 2009 | 10:18 PM
xpndbl3, do you have any pics of you carb setup? Just curious what a 6" drop air cleaner looks like. Do you have any interferance issues with the linkage or solenoids?
Old Jun 23, 2009 | 10:42 AM
xpndbl3's Avatar
Car: 1984 Z28
the drop base is the same from a 3" drop base to the 6" drop base, it's just the filter that changes height the base is the same part.
crappy cell phone pic but it should show you what it looks like.
Old Jun 23, 2009 | 05:10 PM
Thanks, that gives me alot better idea of what I'm looking for.
Frozer!!!
Jan 19, 2024 04:55 PM
LittleFranks
Aug 20, 2015 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
