ls1 wiring help
Old Aug 5, 2009 | 08:02 PM
ScorchedPaint's Avatar
Car: 1992 Camaro RS
Engine: Ls1
Axle/Gears: 4th gen 3:43
ls1 wiring help
i am on to the worst part of the lsx swap! and i need help with the wiring!! i have cut the drivers side harness off at the firewall and need to know which wires need to be connected to the 4th gen pcm wiring harness?! what color wires are the swithed power and the always on power on the pcm harness itself? i just need to know the 5 wires to get the engine started and kicked over! i have the interior and accessories working but cant get the engine fired i just need to know those couple of wires!! HELP and thank you!!!
Old Aug 6, 2009 | 07:09 AM
kevinc's Avatar
Car: 1982 Z28
Re: ls1 wiring help
Not that I was considering becoming your personal research assistant and looking this repeatedly-posted information up for you, but a mention of what year your LS1 harness is might have been helpful.
Old Aug 6, 2009 | 09:30 AM
screeminchicken's Avatar
Re: ls1 wiring help
I replied to ur PM. Bad idea to cut it off at the firewall. It would have been just as easy to remove it . U know it also contains ckts for ur gauges that u have to wire up.
Old Aug 6, 2009 | 12:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The information is contained in the links in the LS1 swap sticky.
Old Aug 24, 2009 | 03:53 PM
Car: 1992 Camaro RS
Engine: Ls1
Re: ls1 wiring help
i took the advice and read alot and have wired up my own fuse box using the 4th gen relay box, question now is :
1. why is the purple starter wire coming out of the firewall not getting power when i turn it to the start position
2. where is the fuel pump relay, is the connector next to the a/c box on the passenger side? if so, can i just cut the red wire (power) and splice into a switeched source that is hot in start/run?
Thanks for the help!
Old Aug 24, 2009 | 11:17 PM
Pocket's Avatar
Car: 91 Trans Am
Re: ls1 wiring help
1) is the starter kill relay still intact or have you bypassed it yet?
2) The fuel pump relay is located near the brake booster. Identify it by the red prime lead. Do not splice into the prime wire, wire the relay the way it was from the factory
Old Aug 25, 2009 | 08:24 AM
andrew69_04's Avatar
Car: 92 Camaro RS
Re: ls1 wiring help
the purple wire comming out of the driver side firewall connector should run directly to your starter wire. iirc, the purple wire on the 4th gen harness runs to the 4th gen fuse block to the starter relay, your bypassing that relay. If your not getting power to the purple wire in the crank position, then you have another problem somewhere else, meaning either you dont have something that needs power or you have another issue all together.
Old Aug 25, 2009 | 05:14 PM
five7kid's Avatar
Did you do anything to/with the '92 VATS system?
Old Aug 26, 2009 | 10:09 AM
Re: ls1 wiring help
Cutting the 92 harness off at the firewall was a bad idea...but moving on.
Give details of what u have for wiring ?
What kind of fuse box are u planning ?
Do you have LS1 firewall harness ?
Old Aug 27, 2009 | 06:45 PM
Car: 1992 Camaro RS
Engine: Ls1
Re: ls1 wiring help
i wired the relay box using the walkthrough of team third gen that was posted in the lsx swap sticky,so that is where i am getting switched power and everything so my 4th gen harness is getting power and interior has power but the only wire that is not is the purple 1 coming out of the firewall.......
i did nothing with the vats system on the 92, and my friend decided to cut into the 4th gen harness so i was not able to use any part of the firewall harness.
do i need to bypass the starter kill relay or is it another problem?
thanks to all for the help, hope to get it fired this weekend!!
Old Aug 27, 2009 | 06:49 PM
Pocket's Avatar
Car: 91 Trans Am
Re: ls1 wiring help
If you havent messed with the relay, itll hold you up
Either connect the heavy gauge wires or ground the blk/yel wire
Old Aug 27, 2009 | 07:42 PM
Car: 1992 Camaro RS
Engine: Ls1
Re: ls1 wiring help
is the starter kill relay? if so i splice the green thick gauge and yellow thick gauge?
Old Aug 27, 2009 | 08:04 PM
Car: 1992 Camaro RS
Engine: Ls1
Re: ls1 wiring help
ok i figured it out it was the starter kill relay, and now i have power to the starter!!!!!!!!! woo hoo!!!! i guess it is on to the fuel pump relay..... then disabling vats which i bought 2 resistors that i will splice into the wire for vats to disable it.... then hopefully fire it up!!!!
Old Aug 27, 2009 | 08:09 PM
Car: 92 Camaro RS
Re: ls1 wiring help
you have to either build a vats bypass module for the ls1 pcm or tune it out. i dont know of any other ways to bypass it.
Old Aug 27, 2009 | 11:08 PM
Pocket's Avatar
Car: 91 Trans Am
Re: ls1 wiring help
As far as swaps go, once you overcome the starter kill relay, 3rd gen VATS is done for
You have to tune the LS1 PCM to be rid of the newer VATS system
Old Aug 28, 2009 | 09:15 AM
Car: 1992 Camaro RS
Engine: Ls1
Re: ls1 wiring help
i just bought the vats bypass module to take care of vats....
http://cgi.ebay.com/ebaymotors/ws/eB...m=320392148402
Old Aug 28, 2009 | 02:15 PM
Pocket's Avatar
Car: 91 Trans Am
Re: ls1 wiring help
Why?
The 3rd gen VATS is taken care of with one wiring change (join the wires or ground the relay)
LS1 VATS is taken care of via tune and you HAVE to tune the PCM to get the swap to work
Old Aug 28, 2009 | 06:28 PM
Car: 1992 Camaro RS
Engine: Ls1
Re: ls1 wiring help
so how do i go about getting my pcm tuned to the correct specs and how much am i looing at money wise?
Old Aug 29, 2009 | 07:52 AM
Pocket's Avatar
Car: 91 Trans Am
Re: ls1 wiring help
Find any friend with tuner software or mail the PCM to a company who tunes LSx engines like PCMforless
Cost should be case of beer to $150
Old Aug 29, 2009 | 10:55 AM
Car: 92 Camaro RS
Re: ls1 wiring help
I told you i could have tuned your vats out for you before i delivered your swap to you for $100. You told me you didnt want to.
Old Aug 29, 2009 | 03:59 PM
92tracker's Avatar
Car: 92 firebird formula
Engine: 2002 LS1/6 350 rwhp
Transmission: 4L60e
Axle/Gears: 342
Re: ls1 wiring help
JET performance has a tuner package that works well, I am in the middle of tuning mind and find it has all you will need it also will remove the vats.
Caspar
Jun 19, 2016 11:19 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
reiderz iroc
Aug 13, 2015 04:57 PM
