LSX, hole in block repairable??
Old Sep 18, 2009 | 09:24 PM
candle's Avatar
Car: '65 trk, '69 trk, neon
Engine: 283, 250, 2.0
Transmission: truck 4 speed, 3 spd, 5 spd
Axle/Gears: 14 bolt, 12 bolt, stock w/ 3.94
I found an lsx, not sure what it is, but is stamped with the 6.0L engine size, and it has the front driver's side block casting removed. It looks like an information plate or something was removed from the block, and now the water jacket is exposed. can this be welded? if so, does anyone know how it must be done? if it can't be done that's fine, but the engine over all besides that one hole is in excelent condition. I will post pictures of the hole later but curently don't have a picture of it. please any help will be great. I would like to buy this for an lsx swap
Old Sep 18, 2009 | 09:27 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Re: LSX, hole in block repairable??
If it's what I'm thinking of, the hole is supposed to be there. There should be 4 holes on the front of the block for the water pump. 3 of them look "normal" and the other one looks like it was cut at an angle, that's the only way I know how to describe it. Get a picture and I'll see if that's what I'm referring to.
Old Sep 18, 2009 | 09:36 PM
candle's Avatar
no this one was cut, whoever cut it did a bad job cause you can see the extra cut marks.
Old Sep 18, 2009 | 11:08 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Seriously man, don't even waste your time - it's not like 6L engines are ultra-rare!
How much would you be buying it for?? If the guy isn't giving you a couple hundred bucks to take it off his hands, I'd bet that it's not worth the hassle/time/expense involved...
Old Sep 18, 2009 | 11:58 PM
candle's Avatar
he would be sellin it for a few hundred, maybe cheaper. but it's almost a long block just no heads. it's in good shape just that one square hole cut into it... would it be weldable? and if it was could I just have a friend weld it for me, he has a complete tig welder and he can weld aluminum pretty good
Old Sep 18, 2009 | 11:59 PM
candle's Avatar
but it's not the point of the 6.0L being rare, it's the point of it's price. if I can get it for way cheaper than somewhere else if I can have that hole welded up, then why not? If I do keep the engine it's not going to see over 700 hp cause I wanna keep it mild anyway but still
Old Sep 19, 2009 | 11:05 AM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
He means you can get a GOOD 6.0L for cheap at most places. No sense buying a junk motor for 300 bucks or w/e and finding out it isn't gonna be repairable after all. Especially with all the other expenses you'll have trying to swap it into a 3rd gen.
Old Sep 19, 2009 | 03:04 PM
Pocket's Avatar
Car: 91 Trans Am
If its aluminum then its a LS2, which is NOT cheap compared to a truck 6.0L
Post a pic of the hole or point it out in one of the pics in here
http://forums.corvetteforum.com/c5-g...ac-arrest.html
If its not a factory hole then the block is scrap and all internal parts suspect. The cost of repairing a hole, esp when you dont have the missing piece is well beyond the price of a new block. Im speaking of doing the job correctly though
Old Sep 20, 2009 | 02:39 PM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
Gm Made 6.0l trucks genIII, in aluminum too... rare'er, in CAddy's and SS's... but you can get a new block from GM for around 1000 bucks NEW. Iron is like 700 bucks
Old Sep 20, 2009 | 02:47 PM
Ethan91's Avatar
Car: 1991 Camaro Z28
Engine: 6.2L LS3 to come
Transmission: 4L60E LVL2 700rwhp
I agree with Pocket from what I understand a hole in the block would cost alot to fix. A weld would not work.
Old Sep 20, 2009 | 05:11 PM
candle's Avatar
from what I can tell on those pictures, is that the hole in the block I want to get is the factory casting number on the front of the block... so I don't think it's worth it but the block with the internals is in a crate right now so I beleive he was going to have it shipped, maybe to gm to get a replacement one. and yes, the block is aluminum. I guess if he ships it to get a new block I'll be buying the new block from him, pics still coming but not till tuesday
Old Sep 20, 2009 | 10:31 PM
Pocket's Avatar
Car: 91 Trans Am
Do you mean the raised pad that says G1502?
Why the heck would anyone CUT that out unless it was a CFC car and the engine MUST be rendered useless
Old Sep 21, 2009 | 12:10 AM
V8Rumble's Avatar
Even that really doesn't make sense - here's the procedure they were supposed to use for that CFC bullcrap (written by one of my local F-buds)...
No, No, No... I work at a salvage yard, and I can tell you EXACTLY what is happening with these cars:
When it is bought into a dealer for the trade in, they are required to add a Sodium Silicate solution to the crankcase, and run the engine until it seizes. Then they affix a tag to the engine noting that is has been done and the engine is no longer good. The dealer then transfers the vehicle to a salvage auction or directly to a salvage yard for "scrap value".
So cutting a hole in the block is a lot more work than would be required. Something's REALLY screwy with that engine...
Old Sep 21, 2009 | 05:03 PM
candle's Avatar
well like v8 rumble said, that's not true for the cash for clunkers cars, and plus this engine has been there at his shop for a while, I beleive it's been there since before the cash for clunkers thing started. like I said pictues on tuesday, but he might be shipping it out to get a brand new one, in which case he would sell me that new block instead of the one that's currently sitting in the crate right now
Old Sep 28, 2009 | 09:52 PM
candle's Avatar
sorry for the delay in pictures but here they are
Attached Thumbnails LSX, hole in block repairable??-photo-0070.jpg   LSX, hole in block repairable??-photo-0071.jpg
Old Sep 28, 2009 | 10:11 PM
V8Rumble's Avatar
THAT is just screwy as hell...
Old Sep 28, 2009 | 10:26 PM
Pocket's Avatar
Car: 91 Trans Am
That block is officially wasted
It would make a good mock-up though, but thats all
Old Sep 28, 2009 | 10:30 PM
candle's Avatar
yeah, I know. I dont know what happened, a few people have said maybe they were trying to change that number and while they were tapping it it cracked, so they cut it out and maybe were going to reweld something onto it. but I can't tell since I have no idea
Old Sep 28, 2009 | 10:32 PM
candle's Avatar
well, i don't exactly have lots of money, so if I were to buy an ls block it would have to be one I could use not a mock up. I'm no drag race team that has the money to test several different types of pistons or different cams for just a couple of races
Old Sep 28, 2009 | 10:33 PM
candle's Avatar
the one thing that really sucks is that that was a perfectly good ls2, but they cut that piece out rendering it useless
Old Sep 28, 2009 | 11:01 PM
Shift06's Avatar
There was probably something wrong with it anyways or else they wouldn't have cut the hole in it. They probably wanted to make a keychain from the 6.0L badge lol.
Old Sep 29, 2009 | 12:35 AM
V8Rumble's Avatar
Y'know, that's the 1st explanation I've heard/thought of that makes even a bit of sense...
But as it is now, that block is just waiting to start its new life as several dozen beer cans...
Old Sep 29, 2009 | 01:26 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Make a coffee table out of it.
Old Sep 29, 2009 | 01:53 PM
Shift06's Avatar
Or a BBQ!
Old Oct 1, 2009 | 10:11 PM
west1nm's Avatar
Car: 91 Z28 Vert
Engine: LS3
Not worth attempting to repair. The reason for the cut was to remove the badging and also rendor the block useless. This was probably a development or test engine thats could also have other issues...
Old Oct 5, 2009 | 09:07 PM
candle's Avatar
It wasn't the 6.0 badge, it was the vin thingy... and now that you mention it. maybe I will make a keychain out of the 6.0 badge. haha. then make a coffe table with it
Old Oct 5, 2009 | 09:15 PM
Shift06's Avatar
Yeah! 2 novelty items from one engine. Great thinking
Old Oct 5, 2009 | 09:22 PM
TXFBODYGUY's Avatar
Car: 1986 I-ROC
Engine: TPI 305
Transmission: STOCK
Axle/Gears: STOCK
maybe it was stolen tryin to hide info about where it came from
Old Oct 5, 2009 | 09:30 PM
Shift06's Avatar
Maybe, but why steal a motor if you are gonna render it useless anyways? At least grind off the numbers or something lol.
candle's Avatar
eh, I doubt it. a lot of these explinations are a lot of wierd things. I honestly dont know why it was done or what happened or what but I do know that there's a ruined ls2 block at that shop thats crated up ready to be shipped somewhere... I'll try and see if he gets a brand new ls2 block cause I'll buy that, then buy a car to put it in
Old Oct 5, 2009 | 09:34 PM
candle's Avatar
there was an explination a guy gave me. that they were trying to restamp numbers and they cracked it, so they were going to fix it after they cut it off
Old Oct 5, 2009 | 10:33 PM
V8Rumble's Avatar
Originally Posted by candle
there was an explanation a guy gave me. that they were trying to restamp numbers and they cracked it, so they were going to fix it after they cut it off
Makes as much sense as anything else, I guess... But even with that, trying to re-stamp a block is a bit suspicious...
Old Oct 5, 2009 | 11:28 PM
TXFBODYGUY's Avatar
Car: 1986 I-ROC
Engine: TPI 305
Transmission: STOCK
Axle/Gears: STOCK
still odd to me y cut a big a$$ hole when you can just weld over the crack instead of all the bs cuting and weldin a big hole and y would you re stamp a motor to begin with
Old Oct 6, 2009 | 07:43 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Or a BBQ!
I definitely want one.
Old Oct 7, 2009 | 09:12 PM
candle's Avatar
well, that's exactly why I was asking if it's repairable. cause I don't know what happened to it
Old Oct 7, 2009 | 09:14 PM
candle's Avatar
eh, too much time on the block i found. it's just the short block. so pretty much will almost completely be useless if i make a bbq
Old Oct 8, 2009 | 01:35 AM
TXFBODYGUY's Avatar
Car: 1986 I-ROC
Engine: TPI 305
Transmission: STOCK
Axle/Gears: STOCK
it prob could be fixed but your gonna need someone who is a damn good welder might be cheaper just to find another
Old Oct 8, 2009 | 09:22 PM
candle's Avatar
well, I'm not so sure, if I can get this block off the guy for like 50 bucks, and how much would a welder charge me? cause I know a guy that's been welding almost since he was born, and he's damn good. He's a good friend of mine and if it is weldable I can probably get him to do it for a case of beer. Is it weldable? that's probably what I shouldve titled this thread ''Is it weldable''
Old Oct 11, 2009 | 12:54 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
if you browse around on ls1tech, you can typically find complete 6.0l shortblocks for around 200$
Old Oct 11, 2009 | 02:20 PM
Pocket's Avatar
Car: 91 Trans Am
You can weld whatever and it seal the hole fine
The problem comes with warping everything and putting internal stresses in the block
Like I said above, welding it isnt the issue. Fixing it correctly will be
Old Oct 11, 2009 | 09:34 PM
candle's Avatar
and shipping? the guy will let me build his block there if I buy it from him. and it's in my city
Old Oct 11, 2009 | 09:35 PM
  #42
candle's Avatar
Oh, I see what you mean. well if it weren't like twin turboed or supercharged would it be alright?
Old Oct 11, 2009 | 09:46 PM
  #43
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
Ive known some people that if they discover a block or transmission case has something seriously wrong with it that isnt very repairable, they purposely render it very obviously unusable (like by putting a hole in it). This prevents anybody who may run across it before it gets scraped from using it not knowing about a less obvious flaw.
I still remember how loud it was when my friends dad took a ballpin hammer to a th350 case, ouch.
Old Oct 11, 2009 | 09:55 PM
  #44
candle's Avatar
well i've inspected the block as thoroughly as I could while it still in the crate, and the rotating assembly still turns, and from what I can tell the only thing is that damned hole. I'll ask the guy again but i don't think it's something like that.
Old Oct 12, 2009 | 12:36 PM
  #45
Shift06's Avatar
It still is not worth it no matter how cheap you get it for. Like someone else said, buy a working shortblock off of LS1Tech for $200.
Old Oct 12, 2009 | 05:29 PM
  #46
Pocket's Avatar
Car: 91 Trans Am
Some cracks esp around the mains only show up when they are stressed, but you will never build oil pressure
That happened to a local racer's BBC
You will not see a crack there and even if it was visible it may not be blatantly obvious like a giant hole in the front of the block
Old Oct 12, 2009 | 09:52 PM
  #47
candle's Avatar
eh. I still need a car to put it in. the block was just going to sit for a while anyway
Old Oct 14, 2009 | 10:43 PM
  #48
candle's Avatar
well the guy ended up giving me the short block for free. he was just trying to clean out his garage today and he gave it to me
Old Oct 14, 2009 | 11:36 PM
  #49
Car: 1979 Malibu
Engine: Blown LSx
time to make a coffee table
Old Oct 15, 2009 | 03:03 PM
  #50
candle's Avatar
well I'm going to first see if I can get it repaired. if there's a machine shop crazy enough to. if not, I'll sell the bolts, the crank, rods maybe, and any other usable parts and I'll clean up the block and make my table or grill or whatever out of it
Nick McCardle
Sep 10, 2015 08:36 PM
84 TA NV
Sep 6, 2015 08:02 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
mrdevontay
Sep 2, 2015 08:04 PM
