LS1 connector pigtails
Old Sep 24, 2009 | 03:30 PM
screeminchicken's Avatar
I came across these on eficonnection website and kind surprised me!!!!!
His website lists 3 different connectors for Oil preasure sender/switch.
1. Oil Pressure Sender.
I have this one.
But.....Maybe i am ignorant but where does these 2 plug into ?
2. Oil Low Sensor LT1/LS1
3. Oil Pressure Sensor LSx
Old Sep 24, 2009 | 03:52 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Re: LS1 connector pigtails
You don't need the low oil level sensor (big sensor on oil pan) cause you don't even have a light for it in your dash. Number 3 is useless as well if you are using your 3rd gen oil pressure sensor.
Old Sep 24, 2009 | 04:07 PM
Did you mean to say Number 1 ?? thats the one I am going to replace with a 3rd gen oil pressure sensor connector.
I havent seen anything close to connector number 3 on the LS1 harness.
I am going to check my Ls1 pan for that connector. Did the LS1 dash have alight for that. I think my 82 had both a gauge and a low oil light. Wonder why they did not put it in the 89-92 dashes.
Old Sep 24, 2009 | 06:47 PM
Shift06's Avatar
3rd Gens didn't have an oil level sensor so there was no light .
No number one is the one you will use. Number one is for the 3rd gen, number 3 is the same thing for the 4th gen (I think lol).
Old Sep 24, 2009 | 11:15 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
We're talking about the oil sensor on the top of the block towards the back of the valley cover right, and not down on the oil pan?
Old Sep 25, 2009 | 08:45 AM
Pocket's Avatar
Car: 91 Trans Am
#1 is used
You should have this in your stock harness in 3 wire form. The function is the same
#2 is the big tan thing in your pan. Leave it unplugged, you have no provision for it
I have never seen #3 in any of the harnesses I have disassembled or modified
Old Sep 25, 2009 | 09:13 AM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
FWIW, I have #3 on my 2008 L92 harness.
Old Sep 25, 2009 | 09:24 AM
Originally Posted by Pocket
#1 is used
This is exactly I figured it would be until I saw those connectors and Shift06 reply.
Thanks pocket for the conformation
Old Sep 26, 2009 | 07:36 PM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
Well... Not all of them.
Old Sep 27, 2009 | 12:24 AM
Shift06's Avatar
Digital Dash?
Old Sep 29, 2009 | 10:23 PM
Agent13's Avatar
Engine: LG4
Digital Dash?
Standard cluster out of a '91 Formula. There wasn't a light in the socket. I wonder if it was functional on any of the cars??
Old Sep 29, 2009 | 10:40 PM
Pocket's Avatar
Car: 91 Trans Am
None that I saw, and Ive stripped quite a few
Oil level light requires a sensor mounted in the oil pan. No third gen that Ive ever seen had one
Old Oct 11, 2009 | 02:45 PM
S10Wildside's Avatar
Oil Pressure Sensor. This is used to bring the oil pressure into the data stream. The early LS use of this sensor is common among Corvette applications. Just about all LS engines today use an oil pressure sensor.
The 3rd gen cluster will only accept a one-wire sender.
Old Oct 12, 2009 | 01:53 AM
so these were used in LS1's in corvettes an not fbody's. what were they specisfically used for in corvettres?
any way to add them to fbody harness ?
Old Oct 12, 2009 | 06:37 AM
Corvette uses the sensor for the gauges and calibration data within PCM.
Why add it to the F-Body? The gauge can't read from the sensor.
wigmobile
Feb 26, 2025 02:56 PM
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
86White_T/A305
Sep 21, 2015 05:28 PM
FormulasOnly
Sep 10, 2015 09:07 PM
Slush92RS
Sep 2, 2015 08:56 PM
