LT1 Conversion into 92 Camaro
Old Oct 6, 2009 | 02:56 PM
carfreak614's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: Open 2.73
I found a 1994 Cadillac Fleetwood at a local junkyard with an LT1 in it for only $250.00 for the complete engine and wiring harness/ecm. I was wanting to know the differences between the LT1 in the caddy and an LT1 in a camaro. I know the caddy has cast iron heads and the camaro has aluminum. Also, would I be able to use my 700r4 with it?
Old Oct 6, 2009 | 06:56 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: LT1 Conversion into 92 Camaro
The camaro got a little bigger cam also other than that they are the same LT1. You can use your 700R but not the cheapest way to go.You need a 93 throttle bracket. You need a 93 tv cable. You need a 93 throttle body or you can have a stud bolted to your tb, lock-up kit for a 700r4.
Old Oct 6, 2009 | 09:04 PM
Firebat's Avatar
TCI is supposed to have a somewhat new product that eliminates the TV cable from a 700R4 and applies the correct pressure all the time. I would think it would be cheaper than a 93 tv cable bracket, 93 t.b., 93 tv cable, depending on if you buy a new t.b.
I don't know whether or not the new TCI product works great or not.
Old Oct 6, 2009 | 09:41 PM
Pocket's Avatar
Car: 91 Trans Am
Most of those parts can be sourced for under $100
I dont get how TCI can make a part that controls hydraulic pressure based on the throttle position/load WITHOUT a trans to TB cable. Next i dont get why one would need that as a new TV cable is $40
Old Oct 6, 2009 | 09:42 PM
RU1NER's Avatar
I heard the constant pressure was bad on the trans. Could be wrong
Old Oct 6, 2009 | 10:26 PM
Car: 92 Camaro RS
Engine: 305 TBI
OK. The whole car itself is still sittin their so in theory I could just get the tv cable and what not off that car right?
Old Oct 14, 2009 | 03:53 PM
Car: 92 Camaro RS
Engine: 305 TBI
Well the engine idea is scrapped as of right now, the guy that runs the junkyard was trying to screw me over. I went in to take another look at the engine with my friend and when i walked out he started talking about the engine being shot, not realizing that my friend was with me. So i took the oil pan off the bottom of the engine only to get rained on with metal shards galore, so there goes that idea.
Old Nov 8, 2009 | 09:10 PM
Car: 92 Camaro RS
Engine: 305 TBI
Found a LT1 from a 1994 camaro with only 80,000 on it. Comes with harness and computer for only $500. I havta remove it myself but at least Ill know it runs good before I take it out.
I'm gonna go look at it this weekend and hopefully its not someone tryin to pull wool over my eyes again
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
Thirim
Aug 9, 2015 06:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
