LS headers, anyone wanna try?
Old Jul 9, 2013 | 07:00 PM
  #101
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
Re: LS headers, anyone wanna try?
my hawks rubbed in the same spot. would not hear it until it idled at a redlight for a bit and then small vibration. any touch of throttle or cruising and i couldnt hear it. solid mounts too. those look like a direct copy other than the collectors.
Old Jul 9, 2013 | 07:10 PM
  #102
Pocket's Avatar
Car: 91 Trans Am
My hawks knockoffs look identical, down to the same crappy gaskets. My SSWs were right on the frame rail in the same location. I shifted the trans mount hole towards the drivers side for a little more clearance. Later on I got fed up with the aftermarket mounts and built my own solids solving the L/R and twisted position issues from the Spohn mounts
Old Jul 9, 2013 | 08:14 PM
  #103
SLING-BLADE's Avatar
awesome im glade to hear im not the only one with this issue, im sure with a few minor adjustments i could get it to quit rubbing there but other then that they seem to be the solution to the expensive header debate!! I very happy with this product.
Old Jul 9, 2013 | 09:25 PM
  #104
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
I've got a Right Hand Drive L98 Camaro, and clearance between headers and the steering shaft is always a problem.
As the GTO was originally a RHD car too, I'm thinking the GTO exhaust manifold might be a good option.
Hoe much work is involved bolting GTO exhaust manifolds on to an L98 350?
Old Sep 11, 2013 | 06:24 PM
  #105
Gregs_GSXR's Avatar
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
I just ordered a set of the R-I ones. Im hoping to get them early next week and installed in the car, I have the Spohn swap mounts and the hawks 4l60e trans double hump cross member. I will report back as soon as I know
Old Sep 20, 2013 | 08:18 AM
  #106
scottyj0621's Avatar
Car: 85 trans am
Engine: ls1
Transmission: t-56
I also bought the racing Innovation headers and they are going to be in today. Hope to get them on the car this weekend. I was surprised to find these headers for so cheap. Only $270.00 plus shipping.
Old Sep 20, 2013 | 11:07 AM
  #107
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
i bought some racing Innovation headers too, BUT, I have a 4L80e, this should be fun....
Old Sep 20, 2013 | 11:12 AM
  #108
cowansauto's Avatar
Originally Posted by Pocket
Yes, Ive used the knockoffs and SSWs. Both fit identical except for the O2 ports
Originally Posted by SLING-BLADE
I have them in my car now, they look good and the fitment is decent. These are the Ebay headers but there made by a company called racing Innovation and supply. If the link doesnt work google them. this is there link for the header= http://www.racinginnovationandsupply...der_p_189.html
How has the finish on these held up? Im thinking about going with a set of these myself. I just can't see paying over $800 for a set of headers.
Old Sep 20, 2013 | 04:41 PM
  #109
Pocket's Avatar
Car: 91 Trans Am
The polished headers changed colors as expected. No issues to report
Old Sep 20, 2013 | 09:13 PM
  #110
cowansauto's Avatar
I went ahead and ordered a set this afternoon. What gaskets and bolts would you all recommend?
Old Sep 21, 2013 | 07:35 AM
  #111
Gregs_GSXR's Avatar
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
I went ahead and bought a set of the RI polished for right around 280.00 shipped to my door, ordered came in about 2 days, packaged nicely, read about how the drivers side was giving some people issues and they had to go in from the bottom. Well I took the plug wires off and since I smoothed and painted my engine bay I didnt have the steering shaft installed so maybe that helped as well cause it took all of 3 mins to install the drivers side from the top. Took the starter off for the passenger side, went in like a breeze. I also have a 4l60e and didnt see any issues with fitment. I was on the fence about these cheaper ls swap headers but at the end of the day Im glad I did and saved a few hundred dollar bills.
Old Sep 24, 2013 | 09:39 PM
  #112
the Racing innovation headers come with gaskets, and you can use the same bolts that hold on your stock exhaust manifolds. I forgot to mention im running a TH350 behind my LSx set up. headers clear the trans and mount fine!
Old Oct 8, 2013 | 09:18 PM
  #113
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Someone shared this link with me, they appear to be the exact same polished headers that were listed on Hawk's site when they had a 1 5/8 set listed. I don't see that option listed on their site anymore, looks like all they sell now are 1 3/4+. Anyways, this is a great price for a set of headers for someone on a budget and doesn't need a big tube primary.
Old Oct 13, 2013 | 07:54 AM
  #114
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
i know its too late, but gm gaskets all the way. i dont like the felpro fiber gaskets or the embossed ones.
Old Nov 14, 2013 | 12:59 PM
  #115
bryanwood74's Avatar
Car: 1988 Camaro
Engine: 5.3L LM7
Axle/Gears: 3.73 1LE '90 Disc
Has anyone used them with Hawk's Y pipe? Just curious.
Old Nov 14, 2013 | 07:48 PM
  #116
cowansauto's Avatar
Of course I haven't seen the other brands but on the cheaper eBay ones I noticed that the welds aren't the cleanest and the welds have already flash rusted some. The flanges up next to the block aren't the cleanest either.
BUT I am pleased for the price! There's no way I'm paying $800 for a set of headers. Call me cheap or whatever but there's just no way!
Old Nov 14, 2013 | 09:23 PM
  #117
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
What's the consensus on ground clearance of the RI long tubes?
My thoughts on headers is, if the RI LT's work then i'll give them a try as that will free up more money for all the other parts my LS1/t56 swap requires. If they last forever great, if not, I'm sure they'll last a few years and I'll have the money to buy the better ones.
Old Feb 16, 2014 | 12:35 PM
  #118
they are a direct copy of the hawks headers, they give you optimal ground clearance you wont be disappointed
Old Feb 16, 2014 | 03:08 PM
  #119
Pocket's Avatar
Car: 91 Trans Am
They are a direct copy of SSW and mimic the same poor ground clearance of the pass collector
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
Tylermcclinton
Sep 17, 2015 07:50 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
