Washers for motor mounts?
Old Feb 12, 2010 | 08:58 PM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
I have new Grade 8 bolts for the clamshell motor mounts that were originally on my 305 TPI that i am now using on my 383 LT1 swap. See pic. The bolts are just a hair long and I need to use washers to make up the space. Anyone think this will be a problem?
I am using solid motor mounts - not sure if that matters or not.
Old Feb 12, 2010 | 10:23 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: Washers for motor mounts?
Do NOT put washers between the clamshell & the block - I can pretty much GUARANTEE that you'll have a HELL of a time trying to get the horizontal bolts through to mount the engine to the K-member (ask me how I know).
You should be able to place the washers under the bolt heads ("inside" the clamshells) without any problems though.
Old Feb 12, 2010 | 11:13 PM
Car: 1992 z28
I wonder why it would be a problem though? Because all it really does is cause the motor to be mounted 1/16" or 3/32" higher... the bolt holes should still aline perfectly fine. I am not saying you are wrong but that is just my thought, I think with the size of these washers I will not be able to get them inside the clamshell.
I guess its not worth to find out anyways but I am curious now...
Now I also ran into another problem, one of the bolts will not thread into the hole in the block. Looks like some of the threads are messed up and the bolt wont even catch the first threads. I can just run a tap through this to get it fixed up right? Anyone know which tap? I bought a bunch of bolts and now forget which exactly it is... i want to say 3/8-16 but I am not sure. Maybe 5/16-__?
Old Feb 12, 2010 | 11:28 PM
Pocket's Avatar
Car: 91 Trans Am
Retap it. Most SBC holes are 3/8-16
If you cant fit a washer in the clamshell, grind some length off the bolt and clean the tip up with a file or a die
You will pay hell getting the two mount bolts back through using washers under the mounts
Old Feb 12, 2010 | 11:45 PM
Car: 1992 z28
sounds good. Thanks for the help, I'll see if I can first find a shorter bolt tomorrow and if not then I will mess with the washers/bolts to make it fit in the clamshell.
Old Feb 12, 2010 | 11:52 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
If you're running solid moroso mounts, you should just buy the uppers and lowers and it'll bolt right up with no fab work.
Old Feb 13, 2010 | 10:12 AM
Car: 1992 z28
I bought the lowers from UMI but I dont think they sell the uppers, I actually could not find new ones anywhere but no need really. Got my old ones blasted and powder coated and they look great. I just bought shorter bolts and now everything is good to go. Just a pain to go back and forth to ACE all day...
Thanks for the help everyone
Old Feb 13, 2010 | 11:53 AM
V8Rumble's Avatar
Originally Posted by SomeGuy25thZ
I wonder why it would be a problem though? Because all it really does is cause the motor to be mounted 1/16" or 3/32" higher... the bolt holes should still aline perfectly fine. I am not saying you are wrong but that is just my thought...
It actually moves the clamshells "outward", farther from the centerline of the mounting axis. I had a little bit of correct alignment, just enough to see that the holes overlapped by about 33-40% - enough so that I could fit a tapered punch in to align the holes when I'd apply some force, but nowhere near enough to have even a chance of getting the actual bolt started.
Man, there's been several days that that's pretty much defined my swap...
Old Feb 13, 2010 | 12:21 PM
Car: 1992 z28
Ahh makes sense now...
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
