Who's running Hawks new crossmember?
Old Mar 15, 2010 | 11:29 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'm liking Hawk's new crossmember because it seems to provide ample room for exhaust pipes. My one concern is how rigid the crossmember is or isn't. It seems to be built from plate steel instead of boxed tubing, which makes me worry that the back of my transmission is going to be bobbing up and down like a $20 *****, especially if I decide to weld a torque arm mount to it.
Anybody running it with some serious horsepower? What are your thoughts on it?
Old Mar 15, 2010 | 01:34 PM
dynodanmanda79's Avatar
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
Re: Who's running Hawks new crossmember?
I'm using the new Hawk's crossmember and I like it. It's plenty strong though it may not seem that way. Idk about the torque arm, i'm using subframe connectors with a torque arm mount attached to it so I can't really give you any advice on that. It does have alot of clearance for exhaust which is why I went with it, here is a pic:
Old Mar 15, 2010 | 02:04 PM
Jim85IROC's Avatar
Thanks for the info. Are those Hawks headers too? In your pic they look like they sit up higher than the lowest point of the transmission. Is that the case, or is it just a funky camera angle that makes it look that way?
Old Mar 15, 2010 | 02:26 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Yeah I just ordered this crossmember, looks promising.
Old Mar 15, 2010 | 02:46 PM
Engine: LSx 5.3
Yeah they are the Hawk's headers, and it just looks funky because of the angle that the camera is at
Old Mar 15, 2010 | 02:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Hawks' 1-3/4"-2.5" headers, Skulte crossmember:
I'll probably be doing the Hawks' crossmember for the LS1/4L60E swap.
Old Mar 15, 2010 | 03:11 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
The hawks crossmember looks almost identical to the one I built for my camaro and I have no issues at all with flex and I am pretty sure I'm hitting it hard. Only difference is I don't have a bender so I just cut and weld in angled pieces, but the exact same design, after wasting 6 hours building it I probably would have been better off just buying theirs
Old Mar 15, 2010 | 09:04 PM
west1nm's Avatar
Car: 91 Z28 Vert
Engine: LS3
What torque arms are people using with this crossmember?
Old Mar 15, 2010 | 11:20 PM
five7kid's Avatar
Torque arm? We don't need no stinkin' torque arm!
Okay, for the LS1/4L60E, I'll probably use an adjustable. Would like to get the mount off of the transmission, but I'm not going to fret over it if I don't.
Old Mar 16, 2010 | 12:17 AM
phillip_helmet's Avatar
Car: '84 Camaro
Engine: 5.3l TSP 224r
Transmission: TH350 3600 stall
Axle/Gears: LS1 3.23
I'll be using this crossmember, albeit a slightly modified version since I'm running a th350. I've got the Jegster tunnel mounted torque arm.
Old Aug 30, 2010 | 01:00 PM
89blues's Avatar
Car: 1989 IROC
Axle/Gears: 3:23 Torsen 4th gen rear
I was looking into ordering this too for my t56 swap and just wanted good ground clearance, but I have Alston SFC's and it doesn't look like it will work.
Anyone get this to work yet with Alston SFC's?
Old Aug 30, 2010 | 01:09 PM
five7kid's Avatar
For the record, I'm not saying that anymore.
I did a trial fit of the Hawks 4L60E crossmember last night. For once, something that seems to fit without hassles - I'm really needing that right now.
Old Aug 30, 2010 | 02:16 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Only 4 of the 7 or 9 pieces have adequate lighting on them. Because of that, I like the Hawks version better so far.
Old Aug 30, 2010 | 04:08 PM
five7kid's Avatar
Lighting or no, I'm much happier with the Hawks version. But, it wasn't available when I started collecting parts for the LS1/T56. And, this Skulte was for the LT1 T56, and (I'm assuming for that reason) didn't fit very well.
Old Aug 30, 2010 | 06:38 PM
west1nm's Avatar
Car: 91 Z28 Vert
Engine: LS3
Has anyone mounted a torque arm to the tail-housing of of a T56? Or is it best to use a tunnel plate style? Any other options? I like it, but need a place to mount a torque arm....
Old Aug 30, 2010 | 07:40 PM
Yahtzee's Avatar
Car: 1989 IROC-Z28 Camaro
Engine: 403 LSX
Transmission: TH400
Axle/Gears: Moser 9" 3.25's
Hawks T56 X-member here, only running about 420rwhp but it has given me no troubles yet, and with the poly trans mount I recently installed I have no shifter bounce. For the price, it is definitely worth it imo.
Old Sep 1, 2010 | 01:04 PM
89blues's Avatar
Car: 1989 IROC
Are you getting rid of your Skulte x-member then? Cause I'm interested!
Old Sep 1, 2010 | 01:59 PM
five7kid's Avatar
I have thought about getting Hawk's T56 version. I'm not actively working on that car right now, though.
We can talk.
Old Feb 21, 2011 | 11:17 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
I just installed my hawks crossmember and have only one complaint, the driver side frame rail has brake and fuel lines running down it and the crossmember doesnt allow room for it. I slipped the crossmember behind the lines but now they look like they would be close to the exhaust ( I dont have headers yet so not an immediate problem). I see one guy up there just shoved the lines up but mine are perfectly straight and dont want to mess them up. It looks like the skulte x-member gives room to leave the lines untouched, can you speak on that five7.
Old Feb 22, 2011 | 11:46 AM
sargenewk17's Avatar
Car: 92 Camaro RS
Engine: LS2
Axle/Gears: 12-Bolt with 3.73
I, at one time, used the Skulte crossmember and it went right in, no issues with lines or anything (although I think I did have to egg out some of the holes). I have since modified a Hawks double-hump crossmember to include the Spohn torque arm mount and that's what I have on there now. Works great and allows the exhaust to tuck up in there a bit, and I've seen no issues with strength (although I'm only at 420rwhp).
Old Feb 22, 2011 | 01:01 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
I have pics of mine in my 5.3 to ls2 thread in this section.
Old Feb 22, 2011 | 02:11 PM
five7kid's Avatar
I tweaked the fuel line to clear the Hawks crossmember and stay away from the exhaust as much as possible. But, I also wrapped it in heat reflecting tape just to be sure.
With the Skulte, that car got all new fuel line, so I was able to route it as I pleased. I still wrapped it in heat tape.
Old Feb 22, 2011 | 07:03 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Anybody with pics of the Hawks' 4L60e piece?
Old Feb 25, 2011 | 02:34 PM
nick86bird''s Avatar
Car: 1984 Trans Am
Engine: 383 4 bbl
Axle/Gears: eaton posi w/ 4.11's
Sarge,
do you think you can post pics of this mod? Im running the spohn t-56 crossmember right now and i have terrible clearance. I was thinking of doing the same thing you did, getting the Hawks crossmember and welding up the spohn torque arm mount off of the spohn crossmember.
Old Feb 25, 2011 | 03:56 PM
five7kid's Avatar
I was in such a hurry for that project that I didn't take many pictures. I'll be pulling the engine soon, so I'll try to get a pic then.
Old Feb 25, 2011 | 09:17 PM
Car: 92 Camaro RS
Engine: LS2
Originally Posted by nick86bird'
Sarge,
I'll see if my dad or brother can get some pics (I'm in Afghanistan right now).
Old Feb 26, 2011 | 11:33 AM
Car: 1984 Trans Am
Engine: 383 4 bbl
Thanks Sarge I appreciate it. Get home safely. oo rah
Old Feb 27, 2011 | 05:53 PM
Car: 1987 GTA
Transmission: 4L60e
Thanks. It's funny that not even Hawks' has pictures of it... I'm running the Spohn piece now, and wondered if the Hawks' piece will give better clearance for headers.
Old Feb 27, 2011 | 06:16 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
heres a pic of mine with a fabricated mount on it. the exhaust runs right under the brace and i have ALOT more ground clearance vs. my spohn crossmember.
Old Feb 27, 2011 | 08:24 PM
Car: 1987 GTA
Transmission: 4L60e
Nice! Thanks.
Old May 30, 2011 | 10:27 PM
Bradlyj8Z28's Avatar
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
Where did you get the pieces to fab up your mount for the Spohn piece to go on your hawks trans crossmember?
Old Apr 1, 2012 | 11:21 PM
FullSendRacing's Avatar
Car: '85 Trans Am FAILBIRD
Axle/Gears: 4th gen torsen 3.42
Just fit up my LS1 in my '86 using SW 1-3/4 headers and had been considering building my own x-member. This looks like exactly what I had in mind... does Hawks also happen to sell a y-pipe designed to fit this x-member? Any other alternatives or am I stuck making one?
Old Apr 1, 2012 | 11:38 PM
daddy33's Avatar
Car: '85 Camaro
I don't think Hawks has a y-pipe separate to clear the x-member. The Hawks crossmember is a nice piece though, and has plenty of clearance for me to run dual 3" into a 4" merge.
Old Apr 1, 2012 | 11:41 PM
daddy33's Avatar
Car: '85 Camaro
x2
I have my TA currently mounted on my t56 but would love to find a way to have it floor mounted.
Old Apr 2, 2012 | 12:02 AM
Engine: 2002 SS LS1
I decided to run a Jegster torque arm. It floor mounts above the driveshaft. I am really happy with it and it is adjustable. I am running Hawks exhaust crossmember and long tubes but opted to make my own 3 inch y pipe. There are pics on my swap thread below.
https://www.thirdgen.org/forums/ltx-...28-swap-3.html
Old Apr 2, 2012 | 12:41 AM
daddy33's Avatar
Car: '85 Camaro
I'll have to check out that jegster torque arm. Does the tranny have to be out in order for it to be installed?
Old Apr 2, 2012 | 06:47 AM
Engine: 2002 SS LS1
Installs in a few hours, just Yank the driveshaft.
Old Apr 2, 2012 | 01:28 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
This is where im at so far
Old Apr 2, 2012 | 06:23 PM
coptzer's Avatar
Car: 1986 IROC-Z
Engine: LS1-ish
Transmission: T56 stage II
Axle/Gears: S60 4:10's
I love that Y pipe! I hope mine comes out that nice.
Looks good. Nice "V" band collectors! That is what I am thinking of doing.
Old Dec 1, 2015 | 02:02 PM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
Anyone get this Hawks crossmember and mount it to a 700R4? I need to get a crossmember with clearance for long tubes.
Old Mar 18, 2016 | 08:46 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
What sfc are people running with this x member?
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
69 Six Pack
Oct 5, 2015 07:51 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Elliswon
Aug 10, 2015 12:33 PM
