LT1 alternator hitting valve cover
Old Mar 21, 2010 | 02:43 AM
88monteSS's Avatar
Car: 92 RS/97 K3500/07 ISS
Engine: LT1/454/LS4
Transmission: 4L60E/4L80E/4T65E-HD
Axle/Gears: 2.73/4.10/3.29
So I'm about 85% through swapping a LT1 into my 92 RS, and I was bolting all the accessory brackets on to the engine today in preperation for dropping it in and I found that my alternator will not clear the aftermarket valve cover. I'd gotten a set of tall covers: http://www.summitracing.com/parts/PRO-141-131/ for 2 reasons, one they look better than the stock ones, and two I'd been told that since I was using full roller rockers that I'd need the additional clearance. I'm still using the stock cam, and the rockers are the stock 1.5 ratio. Has anyone ran into this situation? Do I have enough clearance with the stock covers for the rockers?
Old Mar 21, 2010 | 08:06 AM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: LT1 alternator hitting valve cover
You will have to grind the alternator there is a pic in this post he has the same valve covers.
https://www.thirdgen.org/forums/ltx-...p-project.html
Old Mar 21, 2010 | 09:39 PM
88monteSS's Avatar
Engine: LT1/454/LS4
Not sure I really want to go grinding on the alternator, so before I do that, does anyone know if roller rockers will clear the stock valve covers?
Old Mar 22, 2010 | 04:56 AM
Car: 1992 camaro
Axle/Gears: 3:73
They will just gotta cut them
db057
Sep 4, 2015 07:57 AM
NBrehm
Aug 25, 2015 11:49 PM
g.l.mos
Aug 22, 2015 12:02 AM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
