LS2 fuel rail covers w/ non-DBW swap
Old Mar 24, 2010 | 06:49 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I just bought these:
And when I set them on my motor I noticed that the passenger side hits the throttle cable bracket, I'm thinking because the Corvette they came off of was drive by wire? Has anyone made these fit without hacking them up too badly? Also, I think I'm gonna have to make a small hole in that same cover fo the dipstick because my dipstick hits the inside of the cover.
Old Mar 24, 2010 | 08:24 PM
dynodanmanda79's Avatar
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
Re: LS2 fuel rail covers w/ non-DBW swap
Iansane put the LS2 fuel rail covers on his 5.3 and it looks like he has a cable operated throttle body. Here is the link to his cardomain look on page 2, idk I can't tell from the pictures but im not sure if the covers are just sitting on the engine or if he has actually mounted them.
http://www.cardomain.com/ride/690751
Old Mar 24, 2010 | 08:58 PM
BlueZee28's Avatar
I want to say Ian's covers are from an LS1 which would have been a cable driven setup, but I will shoot him a PM to make sure. Thanks!
Old Mar 25, 2010 | 09:10 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
LS1 Corvettes weren't cable driven, they were DBW. My understanding is that it's necessary to trim any covers to clear the TB and/or cable when installing them on cable driven motors.
Old Mar 25, 2010 | 12:32 PM
Pocket's Avatar
Car: 91 Trans Am
Lets see em on there already!
Old Mar 25, 2010 | 12:37 PM
BlueZee28's Avatar
Pshhh...I don't have a magic wand! If I get a nice weekend this week I will try and test fit them so they will be ready for paint. I'm not installing them for good until they're painted though!
Old Mar 25, 2010 | 01:46 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i have the ls1 ones and can't wait to put them on my carbed motor, hopefully I won't have to hack them "too much"
those coils area ugly as they come the covers will really set it off I think.
Old Mar 25, 2010 | 03:04 PM
Engine: LSx 5.3
Did you get a pm back from iansane yet?
Old Mar 25, 2010 | 04:49 PM
BlueZee28's Avatar
Ya he said he had to do mod them a bit and was gonna try and take a picture for me (his are LS2)
Old Mar 25, 2010 | 05:03 PM
Engine: LSx 5.3
Sweet post some pics as you progress please!
Old Mar 30, 2010 | 10:34 AM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Guys,
to use the LS2 Fuel rail covers you need:
LS2 Fuel Rails
LS2 Coil packs
This is because the LS2 fuel rail is larger diameter, sits lowered and is slightly different shaped then the LS1 (Shorter injectors on LS2) and the coil packs sit higher on the motor and have tall ball end studs the covers hook onto. I found this out the hard way when i bought a set to fit on a LS1
You need to cut a slot in the covers to allow the throttle cable bracket to sit into it, like this (you can kinda see)
Old Mar 30, 2010 | 10:40 AM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
picture of LS2 fuel rails:
LS2 fuel rails wont work with a LS1/6 intake (trust me, thats why ive got a LS2 fuel rail setup sitting in my shop un used
Old Mar 30, 2010 | 03:35 PM
BlueZee28's Avatar
Hmm that's interesting. I'm gonna try and make it work anyways, I think I can do it, especially if what Pocket said about the coils being the same between the trucks and LS2's is true. I'll let you know what I find out, when I have time to work on it. I've even got a spare LS1 intake and fuel rail to mock it up with.
Old Mar 30, 2010 | 04:01 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
07+ trucks have the same coil as the LS2. 99-06 were either the round or triangle style.
LS1 intake/fuel rail are the reason the covers wont work.
Their fitable, but alot of cutting & hacking need to be done
Old Mar 30, 2010 | 04:54 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
I bet you if you used duct tape you could make them work, or at least make them look like they are mounted
Old Mar 30, 2010 | 05:02 PM
Pocket's Avatar
Car: 91 Trans Am
Do it
Old Mar 30, 2010 | 06:39 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by Shift06
I bet you if you used duct tape...
Originally Posted by Pocket
Do it
Hmmm, duct tape coil covers - now, there's an idea. . .
Old Mar 30, 2010 | 06:48 PM
BlueZee28's Avatar
Actually the thought did cross my mind...it sure would make changing the oil a lot easier than if they were mounted haha!
Old Mar 30, 2010 | 07:12 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
I dont know about duct tape...but some strips of good quality, strategically placed velcro could probably get the job done. There's always a way to make them fit.
You gotta clearance for the throttle lever even with the LS1 covers. IF you have a FAST 90mm or bigger intake, you'll need to also make the little cut outs that go against the intake bigger since the runners are bigger. Then depending on your heater hoses, you might have to cut in the back of the passenger side too.
Here are my LS1 covers on my old car.
On a side note...I cant wait to fill in the lettering and customize those covers. Seeing corvette bothers me.
J.
Old Mar 30, 2010 | 07:22 PM
Pocket's Avatar
Car: 91 Trans Am
On a side note, WHY did you use a neon green vacuum line?
Old Mar 30, 2010 | 07:28 PM
Car: 86 Trans AM
Haha..that was from the TPI motor. I had a vac gauge hooked up, and kept collapsing the lines I was trying to use. So I used a silicone line...in green, because thats all I had. It was hidden on the other car, and since I never hooked it up to the LS, it was all pulled out. Its gone now, and the gauge is still not hooked up because Im too lazy to run the stiff nylon line to a vac source.
I have to say..I have a TON of spectre and other importish crap laying around. I used to be a manager at autozone, and when the returned goods were "manager dispose", the went into the dumpster by way of my trunk. The stuff comes in handy sometimes, no matter how goofy it looks. I cant tell you how many cigarette plugs Ive used off of non-working neons and other stupid blinking lights hahaha.
J.
Old Mar 30, 2010 | 11:23 PM
BlueZee28's Avatar
I think my passenger side cover will end up looking a lot like yours, hacked up in the back side. My heater hoses run a very similar route.
Old Mar 31, 2010 | 06:43 AM
Car: 86 Trans AM
You shoudlnt use the phrase "hacked up"... Trimmed to fit sounds much better!
Im actually thinking about getting another cover. And Bending some coolant lines out of copper tubing and hard mounting them to the chassis rail. Then make the connection at the heater core and water pump with short sections of rubber hose. Not sure what that would do to my coolant flow, but it should work ok. Should avoid having to cut the cover, and should allow for a cleaner install. Sort of like the 4th gens had with their alum tubing.
You can make em fit... Ide like to see a dry run with them just laying in place to see how they look. I sorta like em better than the LS1 style that I have...
J.
Old Mar 31, 2010 | 09:33 AM
Pocket's Avatar
Car: 91 Trans Am
Id like to make some heater core tubes from bent conduit, but after fitting the HVAC box and seeing how little room there is behind the pass cyl head, I went with the standard hoses over top of everything. If the heatercore could be clocked differently and the outlets not directly over the engine, maybe rotated under the HVAC box it would be an excellent way to clean up the engine bay
I have to pull my heatercore this week, Ill see if it will fit in any other direction with new holes in the firewall
Old Mar 31, 2010 | 11:12 AM
BlueZee28's Avatar
I think I may be able to "trim to fit" the old heater core hard line from my car in a way that would be more visually appealing than my two over-the-top hoses. I think I can somehow make two short rubber hoses at the water pump end, into the hard line mounted on the frame, use a pipe bender to **** the line towards the heater core at the rear end of it, and use my 90* hoses to go into the heater core. I will see what I can come up with in the following weeks. Its about to be car show season and I really don't want to screw around too much, that and I am still persuing a full-time job, so my car money is all dried up haha
Old Mar 31, 2010 | 11:31 AM
Car: 86 Trans AM
Im thinking some short radius 90's off the heater core. Get them turned down as soon as possible coming off the firewall. Then ill custom bend some tubing to run it tight to the HVAC box, and down to the classis rail. From there, Ill run to the heater control valve, which Ill have to connect with rubber couplings. Then run the tubing over towards the water pump. Probably just bring them close, and then connect with some rubber elbows.
Im thinking about using copper. easiest to work with, dirt cheap, and I can just spray it flat black to make it blend in.
Just not much room over by my HVAC box. And Im afraid to put too many bends in the tubing because I dont know how well that has to flow. My gut tells me it'll be ok no matter what though.
If I didnt have that heater control valve, Ide be using russle 90* fittings off the heater core, and running stainless -an line.
J.
Old Mar 31, 2010 | 01:13 PM
BlueZee28's Avatar
Whoa, what the fudge? What fittings could I use if I went with Russell ones and stainless line? I think I like that idea better, and my setup doesn't use a heater control valve...*excited*
Old Mar 31, 2010 | 01:49 PM
Car: 86 Trans AM
Haha didnt get that far.. But I imagine you'd have to use compression fittings on the heater core. You can probably get something for the water pump side of things. I think you'd have to tap the water pump after you got the standard fittings out.
I guess you can weld/braze threads onto where you need em...but Russels has a TON of stuff. Something has to be able to work.
It was just a brain storming session though..I never dug into it.
J.
Old Mar 31, 2010 | 02:49 PM
Pocket's Avatar
Car: 91 Trans Am
Check out the heater core tubes for a 90-92 3.1 V6 Fbody, they stick pretty tight to the frame rail and stay as a pair
Old Mar 31, 2010 | 04:56 PM
Car: 86 Trans AM
Im going to look at my LS1 hoses tomorrow...IF I still have them. They are similar to the LT1 hoses..except at the water pump end.
Eh... actually...acording to the ebay add, these are for a 2000. I dont remember them being this funky, but if this is what I have, I dont think they'll do what I want. Back to the drawing board...
J.
RedLeader289
May 28, 2019 01:47 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
thunder57
Nov 7, 2015 02:28 PM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
