oil pressure
Old Apr 24, 2010 | 01:46 PM
jackaharmon's Avatar
Car: 1989 Pontic Trans Am GTA
Engine: old 350TPI/new LS1
Transmission: old 700R4/new 4L60E
Axle/Gears: 3.27 stock
oil pressure
what is everybody oil pressure at idle??also note what viscostiy oil you are using...I just rebuillt my 1999 LS1, oil pressure using a mechanical guage, @ idle operating temp, 25 psi, off idle 35-40 psi...i know that this isnt too low but i thought that it might be higher..im using 5w-20 to break it in, maybe its just the viscosity that is givin me this low oil pressure..also what is the recommended oil for these motors??thanks
Old Apr 24, 2010 | 03:59 PM
nobreaks254's Avatar
Re: oil pressure
Both of mine have around 50 at idle with 5w30. Yours sounds alittle low. Did you use a new oil pump? Or possibly damaged the o ring.
Old Apr 24, 2010 | 04:14 PM
Re: oil pressure
na...no new oil pump, i just took apart the old one a cleaned it out..i did however did get a new oring and no i didnt crush it..there really isnt anything to go bad with an old pump, the rotor looks good and the wasnt any score marks anywhere...
Old Apr 24, 2010 | 07:00 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: oil pressure
My '98 cold sits around 60 at idle and 40 when warmed up, after driving for 25+ miles at 75mph it drops to around 35 or so with 178k miles on the clock. These motors are supposed to run 5w30 in them, the 5w20 may be too thin.
Old Apr 24, 2010 | 10:22 PM
Pocket's Avatar
Car: 91 Trans Am
Re: oil pressure
Mine has similar oil pressure with a new pump. If its too low for you add some shims under the bypass spring
Old Apr 24, 2010 | 11:19 PM
Re: oil pressure
shims under the by-pass spring...ur kidding right, ugggggghhhhh i just got the motor in and running, last thing i wanna do is pull it back out..also what thickness of shims should i get....
Old Apr 27, 2010 | 06:48 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: oil pressure
Mine sits around 40-45 at idle when its warmed up. Cold its a good bit about 50 or 60. I run Castrol GTX 5w30.
I also have a ported oil pump.
Thats from the best of my memory anyway...
J.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
