LS to firewall clearence th400 trans??
Old Apr 28, 2010 | 10:45 PM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Okay i just got my engine in and i bought motor moutn adapters and had to cut the mounts off the K-member and wels solid mounts in.
Anyways I had to set the engine back 1 inch from the factory (according the the swap plates) Just so it would mount up with the TH400.
Basically once I got the mounts welded in I have about 1/2 inch clearence on the driver side head.
Is this normal when using a TH400 or 700r4 in the stock location?
I didnt wanna have to get another driveshaft made since my was basically new and i have already shortened it and have 600 into it.
Here is a pic of the clearence.
Jay
For anyone wonder....gonna be a forged 370ci with a single T6 turbo
Old Apr 29, 2010 | 08:12 AM
Pocket's Avatar
Car: 91 Trans Am
Re: LS to firewall clearence th400 trans??
Yes its tighter to the firewall than a SBC. For that reason I recommend installing the harness before putting it in the car or atleast the trans and rear cyl head ground wiring
Old Apr 29, 2010 | 09:00 AM
Jay_rich's Avatar
Car: 1987 Z28
okay I just wanted to make sure, i got it all in place and was like well it can go forward bc the trans is bolted in place from where the LT1 was...then i sttarted freaking out bc its so damn close!
Jay
Ikes 91Z
Dec 9, 2015 03:49 PM
stalkier
Dec 6, 2015 11:25 PM
fbirdroller
Sep 2, 2015 10:27 PM
86IROC112
Aug 17, 2015 07:57 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
