best lsx oil pump
Old Apr 29, 2010 | 06:55 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
best lsx oil pump
well whats everyones take? I was looking at the slp ported ones or the melling high flow or higher psi ones
Old Apr 29, 2010 | 08:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
How about relative merits of the various offerings?
I'm thinking I'll change the pump on my LS1/4L60E swap. I've got the Melling M295 on my Summit wish list.
Old Apr 29, 2010 | 09:46 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: best lsx oil pump
Stock GM unit, probably the best to use.
Old Apr 30, 2010 | 08:37 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
a lot of guys seem to run ported ls6 pumps, but i too am staying stock. if i decide to stray from a stock engine setup, i'd probably go this route
Old Apr 30, 2010 | 10:24 AM
Klortho's Avatar
Car: 1987 GTA
I don't know why someone would want a higher PSI pump, the stock one on my LS1 runs 40 psi idle, 40 psi at 1500 rpm at 75 mph and between 60 and 80 psi when cold or running the car up with 5w30 and 179k miles.
Pocket's Avatar
Car: 91 Trans Am
Port the LS6 for more flow. Shim the bypass spring for more pressure
Old Apr 30, 2010 | 05:17 PM
Engine: ls1, LB9
yeah i was leaning toward the ported ls6 pumps
Old Apr 30, 2010 | 05:58 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Melling pump here. Works like a dream, zero oil pressure issues whatsoever.
Old Apr 30, 2010 | 07:26 PM
Pocket's Avatar
Car: 91 Trans Am
Same... after I put it in
Old May 3, 2010 | 04:16 PM
five7kid's Avatar
What oil pressures have you observed? What oil are you using? I believe you started with a rebuilt 6.0, correct?
Old May 3, 2010 | 09:49 PM
BlueZee28's Avatar
I don't know exactly what PSI it is, my scan gauge doesn't read oil pressure, but on the dash gauge the needle points at about 2:00, maybe a little further to the right than that even. And yes it's a 100% new block inside.
Old May 3, 2010 | 11:19 PM
BlueZee28's Avatar
Sorry I forgot to say what oil, I use Brad Penn oil, "The Green Oil" its a partial synthetic, like 15%.
Old May 3, 2010 | 11:54 PM
five7kid's Avatar
What weight? Not that it helps a lot to know if you don't know what your oil pressure actually is.
The Melling is "standard" volume, I understand. Quite a bit less expensive than the "high volume" pumps I've seen. I haven't seen details, but I assume the Melling would at least be equal to a "ported" pump.
Old May 4, 2010 | 07:32 AM
Pocket's Avatar
Car: 91 Trans Am
Port and shim the melling. Those operations arent LS6 specific
Old May 4, 2010 | 08:55 PM
five7kid's Avatar
Wow, spend a hundred bucks, still need to work it over to make it worthy. . .
Old May 4, 2010 | 09:20 PM
five7kid's Avatar
Maybe I'll just port and shim my own pump.
Old May 4, 2010 | 09:52 PM
BlueZee28's Avatar
I didn't port or shim my pump, it's a race spec pump, I guess that means high volume, I'm not sure. The engine builder picked it out for me.
I want to say I was using 10w30 but the shop I get the oil from recommended something slightly thicker, so it might be 15w30.
Old May 4, 2010 | 09:57 PM
Pocket's Avatar
Car: 91 Trans Am
No different than most cyl heads that arent CNC'd. Its 5 mins with a dremel and adding a small nut/washer under a spring. Not exactly a long drawn out process
If theres nothing wrong with it, this is a great option
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
xxx3man`
Sep 23, 2015 10:37 PM
Navy8125
Aug 21, 2015 09:32 AM
