Blakes LSx swap - pic/vid heavy
Old Oct 4, 2012 | 01:31 PM
  #551
blakecharles's Avatar
Re: Blakes LSx swap - pic/vid heavy
Old Oct 5, 2012 | 09:10 AM
  #552
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
Just got through all these pages. You sir are an inspiration to all of us amateurs. I plan on doing the same with my car in about a year or two. I need to save up the money first. I would like to have most of the parts needed before I start the build so I don't have to wait. Seeing what others are doing helps me decide on the parts I want. I currently have a 350 TPI and wasn't sure if I wanted to keep it or go for the LSx. I really do like the look of yours though so I am leaning that way.
Keep up the good work!
Old Oct 7, 2012 | 03:33 AM
  #553
thecraze's Avatar
A little while ago, I had to let go of my 86. The engine went and I wouldn't have been able to keep it in that condition where I was living at. Now, we bought a house with a garage and I'm gung-ho about getting another Thirdgen and restoring it. What Blake has done gave me inspiration to do a complete tear down on a Camaro. What the hell, I have the garage to do it in now.
Old Dec 8, 2012 | 04:48 PM
  #554
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
I just finished reading this entire post and all I can say is DAMNIT Man!! Blake, Outstanding job!!!
Old Dec 14, 2012 | 02:23 PM
  #555
Plz forgive my ignorace... how the heck do I grease the bushings on my UMI a-arms??? How to I grease the roto-joints on my LCA and PHB??? Should I grease the Sway Bar bushings as well??? Do the endlinks need it??
How do I pack grease into the wheel bearings (LS1 Brake swap)??? I've been avoiding making any un-nessacary posts (this thread has been flooded more than enough). I just need a lil help.
Old Dec 14, 2012 | 02:31 PM
  #556
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
poly bushings you usually take off and grease between the bushing and metal, so for sway bars i usually grease between brakcet an bushing and bushing and sway bar. does that make any sense?
end links dont really need it but a tiny bit couldnt hurt as they may squeak. teh bushings on your a arms if they dont have a grease fitting then you get to take then off and do it how i mentioned before. the wheel bearing you take off the wheel take off the dust cap and just packe it in there with a grease gun or finger. i like to spin the wheel a little to moake sure it got in the and the give another squirt if it absorbed alot.
make unnecesary posts i though this thread died. ive been checking back for updates in case my notifications werent working.
Old Dec 14, 2012 | 03:08 PM
  #557
Old Dec 14, 2012 | 06:29 PM
  #558
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
sometimes grease is supplied otherwise id think wheel bearing grease for wheel bearings for sure. and either that/multipurpose/ or white lithium grease for the bushings. i think any will work.
Old Dec 14, 2012 | 09:01 PM
  #559
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
You want to use synthetic grease on your poly bushings.
Regular grease could cause them to deteriorate... that's the word from them that's supposed to know... Steve Spohn, etc.
Old Dec 15, 2012 | 12:57 AM
  #560
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
that i was unaware of ^
Old Dec 15, 2012 | 09:45 AM
  #561
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
when you do wheel bearins put a nice chunk of grease in the palm of your hand, and starting at the bottom of the bearing you "pack" it in there until it starts coming up the top., and do that around the whole bearing, this may get messy. Sorry but alittle grease on the end of it just wont due. Must be packed in there. Pics?
Old Dec 15, 2012 | 10:20 AM
  #562
dprest68's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
I believe the point is to get all of the air pockets out of the bearing so that it's packed completely full of grease. Then pack that hub full of it once you get it together.
Old Dec 15, 2012 | 11:24 AM
  #563
ransam's Avatar
Car: 88 trans am 72 olds cutlass
Engine: soon to be 5.3 455 olds
Transmission: soon to be t-56 2004r
Axle/Gears: 3.23 3.73
You can buy a tool at any parts store that has 2 plastic discs that unscrew and you put the bearing between them and it has a zerk fitting to pump grease in till it comes out through all the holes. After using this tool i will never hand pack bearings again. It was the best 8 bucks ive spent.
Old Dec 28, 2012 | 04:46 AM
  #564
Nitewulf98's Avatar
Car: 1989 IROC Z28
Engine: Empty
Definitely looks great! I hope to do half as good a job when I start on mine.
Old Jan 8, 2013 | 05:52 PM
  #565
jazzdadss's Avatar
Car: 1989 IROC LSX
Transmission: 4L65E
I thought ls1 swap brakes were sealed hub and bearings?
Old Jan 9, 2013 | 04:07 PM
  #566
Pocket's Avatar
Car: 91 Trans Am
4th gens use a sealed hub assembly, but it is not compatible at all with the 3rd gen spindle. For a brake conversion a disk brake rotors is trimmed down to a hub, but still retains the stock spindle and bearings
So, no. You use the stock bearings packed with grease
Old Jan 21, 2013 | 02:09 AM
  #567
thecraze's Avatar
Any pics of your progress, blakecharles?
Old Feb 4, 2013 | 07:19 PM
  #568
Old Feb 4, 2013 | 07:23 PM
  #569
Old Feb 4, 2013 | 07:45 PM
  #570
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Congraulations on your dedication to the project. Gaining experience (even if you have to do things twice) is what learning is all about. At least you can say with pride that you built it yourself. People can not truely appreciate the effort involved until they try to build one. Good luck with your project.
Old Feb 4, 2013 | 08:34 PM
  #571
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Glad to see your still moving along on this! Congrats on the baby girl too!! Sometimes life gets in the way of the hobby, but the car will always be there no matter how long of a break you take from working on it. Mine took 4 years to complete, and sometimes I'd go for a month or two without touching it much. With a project of this size though, you need those breaks in between. Keep the pics coming as you make progress man, and good luck as always.
Old Feb 4, 2013 | 08:42 PM
  #572
Flip 2's Avatar
Engine: C5 LS1
I had a baby so the car has been getting neglected for quite some time...
underbody was coated with bedliner... as you can see, I had to sand down some areas and go back over...
Congratulations, Dad.
Bedliner!
Great idea.
Looks good.
Old Feb 5, 2013 | 11:10 AM
  #573
Old Feb 5, 2013 | 11:12 AM
  #574
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Looks slick!
btw congrats on your new baby girl!
Old Feb 5, 2013 | 12:40 PM
  #575
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
i like the semi gloss. not quite flat.
Old Feb 17, 2013 | 01:28 AM
  #576
thecraze's Avatar
Congrats on your baby girl! We have a 7 month old girl.
Good to see the car progressing.
Old Feb 19, 2013 | 01:47 PM
  #577
Old Feb 19, 2013 | 01:56 PM
  #578
Old Feb 19, 2013 | 02:01 PM
  #579
Old Feb 19, 2013 | 02:15 PM
  #580
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
toss that ragjoint and go with an astro shaft.
Old Feb 19, 2013 | 02:57 PM
  #581
it bolts right in with no mods right??? real U joints?? I was going to delete the rag joint but it seems the Astro swap might be just as good or better.
Old Feb 19, 2013 | 03:24 PM
  #582
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
astro or jeep shaft splines are the same, have to grind the upper shaft that attaches to the column to allow the bolt to go through. i actually did this on my lifted 93 yukon. the bigger tires ate the rag joint to death i put a jeep shaft in withing 30 minutes and i have no slop whatsoever. if you need more details shoot me a pm my friend blasts and powders them to swap into cars.
Old Feb 19, 2013 | 03:46 PM
  #583
mille_3's Avatar
Car: 1986 Firebird
Engine: 6.0L LSX
This should help with the Astro steering swap
https://www.thirdgen.org/forums/susp...-steering.html
Old Feb 19, 2013 | 04:13 PM
  #584
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
looks really good keep up the work it sucks when you start a project like this because you want to get it done fast but reality kicks in and it takes months even years but you are doing it the right way once
Old Feb 19, 2013 | 04:49 PM
  #585
Car: 1986 Trans am
Engine: 5.3 LM7
I'm really diggin the semi-flat black finish with those wheels. Car is going to be super sleek when done man. MUCH better than the original white!! I can't wait to see it back from paint.
Old Feb 19, 2013 | 05:49 PM
  #586
Old Feb 19, 2013 | 09:58 PM
  #587
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
subscribed.
Old Feb 19, 2013 | 10:11 PM
  #588
Car: 1986 Trans am
Engine: 5.3 LM7
At first glance I thought the springs raised the car instead of lowering it. The front has a lot more fender gap than the rear. Then I remembered that these are staggered Vette wheels.
18x9.5 front
19x10 rear
Wheels seem to fit with 2" spacers all around w/o any rubbing. The difference in wheel wheel size makes the gap look big!! I need to raise the rear or lower the front.
see what I mean?
LOL have no fear. That will drop A LOT once you get the rest of the car together. Don't forget, there is no hood, tranny, radiator, fluids,or any of the accessories in the bay. The motor alone will not drop the car down much, but everything combined will. My car looked exactly the same height with just the bare motor in it, and adding everything else dropped it down substantially.
Old Feb 27, 2013 | 01:53 PM
  #589
EJHeavey's Avatar
Car: 1989 Chevrolet Camaro IROC-Z
Update?
Old Mar 1, 2013 | 03:57 PM
  #590
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
starting to look like a decent build!
Old Mar 10, 2013 | 12:34 AM
  #591
thecraze's Avatar
There's a mechanic who has an 89 with T Tops by me. He's pulling the engine and transmission (also a few other things). He wanted to scrap the rest, but I told him I'll take it and build onto that. If I'm able to get it, I hope my build goes as well as this one!
Old Mar 16, 2013 | 04:01 PM
  #592
thecraze's Avatar
Actually, it's a 91 and I was able to get it from him cheap! I'm going to utilize this thread for ideas. Great thread, by the way!
Old Mar 16, 2013 | 06:29 PM
  #593
Flip 2's Avatar
Engine: C5 LS1
Looks good. Give a good check for rust. This thread shows where you should look, and how extensive repairs can be.https://www.thirdgen.org/forums/ltx-...inal-88-a.html
Old Mar 17, 2013 | 12:14 AM
  #594
thecraze's Avatar
Thanks, Flip 2. Initial inspection didn't turn up anything extensive like in that thread, but I haven't torn it apart yet. My small thread is https://www.thirdgen.org/forums/body...uild-91-a.html so I don't bog down blakecharles' nice build.
Old Mar 19, 2013 | 06:16 PM
  #595
Old Mar 19, 2013 | 06:26 PM
  #596
Old Mar 19, 2013 | 08:18 PM
  #597
Engine: LB9 | LS1
Me gusta!
Old Mar 19, 2013 | 08:42 PM
  #598
thecraze's Avatar
Awesome!
Old Mar 19, 2013 | 10:23 PM
  #599
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
niceee do they make those for lifted trucks?
Old Mar 20, 2013 | 11:52 AM
  #600
