Blakes LSx swap - pic/vid heavy
Old Jul 13, 2010 | 10:52 AM
  #101
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Re: Blakes LSx swap - pic/vid heavy
Don't be afraid to post your methods. There's more than one way to skin this cat.
Old Jul 13, 2010 | 04:04 PM
  #102
Pocket's Avatar
Car: 91 Trans Am
I build it how you want it with whatever components you need
Old Aug 13, 2010 | 11:02 AM
  #103
blakecharles's Avatar
Old Aug 13, 2010 | 11:04 AM
  #104
Old Aug 13, 2010 | 03:29 PM
  #105
dynodanmanda79's Avatar
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
Damn! how the hell did you score an LS1/T56 combo with wiring harness and computer for $1700!?!?!?!? Is there anything wrong with the motor?
Old Aug 13, 2010 | 03:40 PM
  #106
DIRTY JERZY's Avatar
Car: 89 formula 350 & 2001 ws6 ta
Engine: 350 tpi & ls1
Transmission: 700r4, t56
Axle/Gears: 9 bolt ? & 10 bolt 3:42
2002 LS1 would not have a egr tube in the intake.
Old Aug 13, 2010 | 04:20 PM
  #107
Pocket's Avatar
Car: 91 Trans Am
Perimeter valve covers and 4 bolt WP say it's a 98
Still, you got the whole deal for what most get just the trans for. Wish i could find a deal like that
Old Aug 13, 2010 | 04:54 PM
  #108
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
yea thats definitely a 98 LS1. the perimeter bolt valve covers and individually bolted coils mean its a 98. Have fun with that harness and ecu...the 98s are not the best to use
Old Aug 13, 2010 | 04:56 PM
  #109
Old Aug 13, 2010 | 04:57 PM
  #110
Old Aug 13, 2010 | 09:34 PM
  #111
Pocket's Avatar
Car: 91 Trans Am
I can fix anything
Also, the PCM you see is 98 only too
Old Sep 13, 2010 | 03:33 PM
  #112
Old Sep 13, 2010 | 03:40 PM
  #113
vinny83's Avatar
Car: '83 Camaro Berlinetta
Engine: 305 with aluminum heads, voodoo cam
Transmission: 700r4 auto
Axle/Gears: 10 bolt w/ 3.73 gears
sweet ride..im following now. oh, and about the 1st gen camaro in the background, can i have? lol spilled my coke all over myself when i seen tht. beautiful car =]
Old Sep 13, 2010 | 07:28 PM
  #114
Old Sep 13, 2010 | 08:06 PM
  #115
Old Sep 14, 2010 | 07:59 AM
  #116
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Great work blake!
Regardless of the year of the motor/trans, you still got a good deal. You can deal with the wiring and PCM when the time comes...but I certainly wouldnt have turned that deal down. Especially if you heard/saw the motor run prior to it being pulled. Were you able to drive it or see it move? Just to make sure the trans worked...
On your patch panels. So this is the first time you've welded? If so...I have to say. Ive seen WAYYYYYY worse from someone trying to shave their doors and being a new welder.
You did it correctly. Tack welding to keep from warping the metal. You didnt seem to leave too many gaps or holes, so you did pretty good. Just make sure you get a good sealer primer on there to keep it from rusting.
This is the time to have patience and take your time. The final quality of the paintjob will be much better if you take your time and get things as nice and flat as you can now. Get those welds nice and flat. The less filler you need to make it straight the better. Tho..it seems you already grasped that concept so good work!!
You seem to be putting a good amount of work into this car...and I see no reason why you shouldnt yank the front suspension and get the k-member out for mods/paint. Its not hard, especially with no motor or trans. Heck a buddy and you can probably lift the front of the car at this point no problem. This would be a good time to clean up your steering parts, replace anything thats worn, clean and repack the wheel bearings etc etc. Just dont turn any of the tie rods, and keep the strut mounts in the same place and you wont have alignment issues when it goes back together. The front ends are really easy to take apart/reassemble....
J.
Old Sep 14, 2010 | 08:13 AM
  #117
Pocket's Avatar
Car: 91 Trans Am
Thats an understatement. He paid for the trans and got a free engine and harness. Id call that a steal
He's going to need an alignment anyways after the swap. The Alum engine lifts the nose up quite a bit, so he'll have to do something to the springs to lower it back down. You cant guess the ride height accurately enough for the alignment to be in specs
Old Sep 14, 2010 | 08:38 AM
  #118
bcl3rdgen's Avatar
Engine: LT1 Hotcam only
Axle/Gears: 9" 4.30 gears and a Locker
It's been a while since I have made my way over to the site, man you have completed a lot of work, cars is looking good! Nice progress!
Old Sep 14, 2010 | 08:52 AM
  #119
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
Good job so far.
Old Sep 14, 2010 | 10:13 AM
  #120
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Looks good! Just went throught your whole thread. Cant wait to see it more completed!
Old Sep 14, 2010 | 07:43 PM
  #121
Old Sep 14, 2010 | 07:51 PM
  #122
Old Sep 14, 2010 | 07:56 PM
  #123
Old Sep 14, 2010 | 08:34 PM
  #124
Old Sep 14, 2010 | 08:54 PM
  #125
Old Sep 15, 2010 | 12:01 AM
  #126
Engine: LSx 5.3
Originally Posted by blakecharles
Your brother might not be too happy with all that sanding dust getting all over his chevelle!
Old Sep 15, 2010 | 12:35 AM
  #127
Old Sep 21, 2010 | 05:16 PM
  #128
Old Sep 23, 2010 | 01:59 PM
  #129
Old Sep 23, 2010 | 02:01 PM
  #130
Old Sep 23, 2010 | 04:34 PM
  #131
bcl3rdgen's Avatar
Looking good continue to take your time and don't get in a rush!
Old Oct 3, 2010 | 06:58 PM
  #132
BlueMagicSS's Avatar
Car: 2000 Camaro SS/86 Iroc/89 Iroc(x2)
Transmission: 6 Speed
Axle/Gears: 4.10
Nice work... take your time on it. I know body work can be tedious though. It'll be worth it in the end
Old Oct 4, 2010 | 03:30 AM
  #133
Old Oct 4, 2010 | 11:04 PM
  #134
Axle/Gears: 4.10
Thanx, I'm taking my time (it's getting ugly out there tho), you wouldn't happen to know anything about passing smog with these swaps would you? I want to use an MS3 cam and BBK intake. I don't think that will pass, any suggestions (I see your in OAK is why I ask).
You wont pass with an MS3, or the BBK. All emissions systems have to be in place, and since your engine was from a 1998 F-Body you will need the AIR, EGR, CATS, HO2S and EVAP set up, which includes using the Fuel tank since it has the evap canister on top of it. There are some cams that will pass CA emissions but I'm not sure which ones will. It's funny that you ask me because I'm in Oak, since I'm also a smog tech.
Old Oct 5, 2010 | 12:46 PM
  #135
I have seen your car a few times, your with the Oakland Maro Boyz right? ummm I guess that means no LS6 intake then... has anyone put EGR on an LS6 intake? With EGR would it even make sense to do so??? What mods can I make to this engine and still pass CA smog??
Please let me know if I understand this right:
98-00 LS1 w/ EGR on intake and slightly larger cam (mild loss of power due to EGR)
01-04 LS1 w/ LS6 intake, no EGR and smaller 5.3 truck cam (smaller cam compensates for loss in power and passes emissions w/o EGR)
Old Oct 5, 2010 | 12:57 PM
  #136
Axle/Gears: 4.10
worse come to worse you can tell them it's out of a 2002 F-Body, they won't be able to tell the difference. and then you can use the LS6 intake and no EGR.
And yeah I'm with the Maro Boyz.... so you've seen me.... lol
Old Nov 19, 2010 | 02:10 AM
  #137
Old Nov 19, 2010 | 08:39 AM
  #138
mwfrels's Avatar
Car: '86 Z28
Engine: SDPC TPI 350
Transmission: WC T5
Axle/Gears: 3.23 posi
I been trying hella hard to find a complete plastic LS1 tank with all the sensors evap and sending unit. I can't even find it in parts.. You know anyone that has one?
Anyone?
Go the the bay of fleas and use "99-02 camaro fuel tank" for a search. The seller is in Florida. That is where I got mine from.
Mike
Old Nov 19, 2010 | 08:50 AM
  #139
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
You do some good work! Subscribed. Im going to pull my motor and trans by lifting my car off.
Cant wait to see this car done.
Old Nov 19, 2010 | 11:10 PM
  #140
Old Feb 16, 2011 | 05:27 PM
  #141
Old Feb 16, 2011 | 05:33 PM
  #142
bcl3rdgen's Avatar
That is a solid find! Nice dash pads are hard to come by!
Old Feb 16, 2011 | 05:34 PM
  #143
Old Feb 16, 2011 | 09:12 PM
  #144
Engine: LSx 5.3
I remember you talking about keeping emissions, are you going to use the 4th gen cluster in that third gen dash?
Here's why i'm asking:
Originally Posted by ghettocruiser
However...the important parts to keep it SMOG legal, are just the electronics from the LS1 dash. You need the cluster because it uses serial data from the PCM for certain functions. Mainly, the EVAP. The PCM uses the fuel level and pressures, then sends serial data to your fuel gauge. You cant have an aftermarket fuel gauge and functioning EVAP...etc etc. Things like that.
Old Feb 16, 2011 | 10:24 PM
  #145
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
no hes ganna have pocket make him a conversion harness..
Old Feb 16, 2011 | 10:58 PM
  #146
Duane's 91 Z/28's Avatar
Car: 1991 red Z/28
Transmission: T5 swap
Oh how I love this thread. This is going to be an awesome ride once you're done. Subscribed!! I love your 69 Camaro too.
Old Feb 16, 2011 | 11:12 PM
  #147
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Looks good so far! I need to do this to my Formy one day...
Old Feb 16, 2011 | 11:47 PM
  #148
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Here is the "Front end Bolt Kit". This kit came with bolt for everything... Every bolt I will need for my front end. Some ppl say to just buy screws from anywhere, well... I had a few extra dollars.
where did you get this bolt kit from? o and btw nice build,and great job documenting everything
Old Feb 17, 2011 | 11:12 AM
  #149
Engine: LSx 5.3
That's all fine and dandy but you still need to run the 4th gen gauge cluster in order to keep it smog/emissions legal, Unless he has decided against making it smog legal?
Old Feb 17, 2011 | 03:46 PM
  #150
