LT1 wiring problem
Old May 15, 2010 | 06:45 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
LT1 wiring problem
I am helping a buddy wire up his LT1 and we have no power on the ppl starter wire off his c-100.
We have power on the starter and every where else it's been awhile since I wired mine up and dont rember what I did but had the same problem, If you try to start it still no power on it any ideals on what to do?
Old May 15, 2010 | 08:11 PM
Pocket's Avatar
Car: 91 Trans Am
Re: LT1 wiring problem
This comes up alot
You need to find where in the line you lose 12v. Grab a meter or test light
http://www.austinthirdgen.org/mkport...n8_starter.jpg
Fusible link
IGN switch
Starter relay
P/Neutral switch or clutch switch
Starter
Sometimes a PO will have installed an alarm system then partially removed it adding more switches along the line
Old May 15, 2010 | 08:39 PM
Car: 1992 camaro
Axle/Gears: 3:73
We dont even have power on the fuse box for the starter wire, I dont think we did the starter relay bypass. We have power on IGN, starter,and the fusible link not checked the others.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
sreZ28
Aug 14, 2015 07:48 PM
