quick lt1 question
Old May 20, 2010 | 07:40 PM
jwright32's Avatar
Engine: Lt1
Transmission: TH400
Axle/Gears: 4.11
quick lt1 question
A 95 roadmaster lt1 with a PCM is going to be running OBD1 software, even if it has an obd2 style connector?
Getting ready to order my software and wanna get the right stuff. Thanks for any input
Old May 20, 2010 | 08:28 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: quick lt1 question
i thought the roadmaster was a L99. anyway check out the impala ss forum. lots of good info there on these.
Old May 20, 2010 | 08:37 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
You need the OBD1 software, and pick the plug for which style you are using, the OBD2 plug or the OBD1 plug. I'm using the OBD1 plug in my car, so I chose that plug for my kit.
Old May 20, 2010 | 09:25 PM
jwright32's Avatar
Engine: Lt1
Transmission: TH400
Axle/Gears: 4.11
yes this is what i was thinking thanks
Old May 20, 2010 | 09:44 PM
Pocket's Avatar
Car: 91 Trans Am
Easier to add an OBDI ALDL than to add the OBDII ALDL and then have to make a special cable for it. Not like ALDLs are overly complicated
Old May 20, 2010 | 10:13 PM
jwright32's Avatar
Engine: Lt1
Transmission: TH400
Axle/Gears: 4.11
well to my understanding, and i may be wrong, but some late model 95's have obd2 connectors but run obd1 software. i believe my situation fits under this guideline
Old May 21, 2010 | 05:48 AM
Pocket's Avatar
Car: 91 Trans Am
Correct
Your harness wont come with the ALDL, you must add it
The car will come with an OBDII ALDL, just add a OBDI piece or use the existing one under your dash
Old May 21, 2010 | 08:10 PM
jwright32's Avatar
Engine: Lt1
Transmission: TH400
Axle/Gears: 4.11
here is an update for anyone who googles thru here in the future with the same question. 1991-1996 buick roadmasters should all be 12 pin obd1 connectors with obd1 software. I thought they switched to 16 pins in 95 but from my research it did not happen with buick roadmasters
Old May 21, 2010 | 11:20 PM
Pocket's Avatar
Car: 91 Trans Am
It really doesnt matter. The ALDL is not part of the engine harness. You must add it later. For OBDI swaps its pretty easy, connect two wires to the stock ALDL through the C207
midge54
Dec 27, 2019 04:14 PM
87iroctheo
Dec 4, 2016 11:47 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
