LSX/4L60E swap Shift Linkage?
Old May 24, 2010 | 09:24 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
What should I do to get the linkage to work on my 4l60e? I have the original shift linkage from the 700R4. Can the 4th gen linkage be used or is there a way to use the 700r4 linkage with the 4l60e? (Trans has a male screw type connector, as does the linkage) Male on male.
Old May 24, 2010 | 10:45 PM
Don1180's Avatar
Car: 88 Trans Am
Engine: 98 LS1 TQRv2 Loudmouth
Transmission: GTO T56 & MGW shifter
Axle/Gears: 8.8 from a ranger with LS1 Tubes
Re: LSX/4L60E swap Shift Linkage?
Just use the shift arm off the 700r and the linkage bolts on. The 700r uses the same pan as a 4L60E.
Old May 25, 2010 | 05:17 AM
Shift06's Avatar
I dont have the 700r4 anymore.
Old May 25, 2010 | 08:16 PM
Pocket's Avatar
Car: 91 Trans Am
Get one from a JY or trans shop. The 700R4 cable fits fine, just move the bracket one bolt forward
I would suggest attaching the cable end to the inside of the arm for maximum exhaust clearance. It's going to be tight in there
Old May 25, 2010 | 09:13 PM
Don1180's Avatar
Car: 88 Trans Am
I have an extra shift arm, PM me your address and I'll mail it to ya.
InfinityShade
Aug 22, 2015 08:00 PM
spaigo
Aug 21, 2015 07:46 PM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
