LT1 swap
Old Jun 14, 2010 | 10:19 AM
frankensteinGTA's Avatar
Car: 89 GTA
Engine: 94 LT1 with Painless Perf. cam kit
Transmission: 700r4 2100 stall conv. Vette servo
LT1 swap
do any of you guys know what part of the old harness i need to keep when swapping a LT1 into a 89 GTA? I bought a painless harness which makes it somewhat simple but just need to know what to keep from the old harness. I'm not keeping the A/C or the emissions.
thanks,
gb
Old Jun 14, 2010 | 04:13 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: LT1 swap
You could have saved alot of money by avoiding the Painless here see if this helps there is a c-100 and a c207 pinout on it for a 89.
https://www.thirdgen.org/forums/ltx-...formation.html
Old Jun 19, 2010 | 04:46 AM
Car: 89 GTA
Re: LT1 swap
thank you for the input. the chart says 90-92 at the top. will it still apply for a 89 year harness?
Old Jun 19, 2010 | 10:54 PM
Car: 1992 camaro
Axle/Gears: 3:73
Re: LT1 swap
If you will look down toward the bottom it has them for the 89.
Old Jun 19, 2010 | 11:27 PM
Pocket's Avatar
Car: 91 Trans Am
Re: LT1 swap
I posted all the years further down the page
http://www.fbodyrescue.com/forum/vie....php?f=34&t=78
Check out this page for the abridged version
Old Jun 26, 2010 | 01:57 PM
Car: 89 GTA
Re: LT1 swap
i see you did a similar swap. Did you use the original harness or the harness from the donor car? How did the swap turn out?
Old Jun 26, 2010 | 02:01 PM
Car: 89 GTA
Re: LT1 swap
thanks for the help. As i understand it, i need to keep the HVAC (or not because i'm deleting the A/C), the cruise, and the front light harnesses and get rid of the fuel injection harness? Remember, i bought the painless harness.
Old Jun 26, 2010 | 02:08 PM
Pocket's Avatar
Car: 91 Trans Am
Re: LT1 swap
Painless harness should be stand alone. That means you hook up Batt, IGN, Fuel and gauges
Follow the 3rd gen prep thread and use the pinouts page to identify each of the necessary splices from the painless harness
Use a non-AC HVAC box to delete AC the right way. Simply unhooking the AC lines and leaving the big box works, but looks terrible. No changes to the wiring are required in switching when you swap the original blower motor in and change the bird cage. To use the non-AC fan, youll need to cut the fan connector off and crimp spade terminals on the 12v and grd points
I can just about guarantee the painless harness will have NO provisions for cruise control, so anything added will be by you. Read my thread about digital cruise with ltx/lsx swaps about hooking the wiring up and making a cable. Some have rigged up a system to reuse the old vacuum cruise unit, but its easier to assemble a new harness and use the digital box designed around the newer PCMs. Using the new box, the old cruise harness comes out
Front light harness is untouched in any type of swap, EFI, carb or otherwise
Old Jun 27, 2010 | 10:41 AM
Car: 89 GTA
Re: LT1 swap
thanks Pocket, think i'll go without the cruise control. It's never worked anyway so why bother?
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
