slp dual inlet cold air on a ls1
Old Jul 11, 2010 | 08:25 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
well here is a sneak peak! Ive got a little more sanding and filling to do befor i start painting it
[IMG][/IMG]
[IMG][/IMG]
then I will have to decide if I want to put my slp sticker on it.. I have the old style slp one still
Old Jul 11, 2010 | 08:42 PM
Engine: ls1, LB9
Re: slp dual inlet cold air on a ls1
this is my old setup here...
[IMG][/IMG]
and for those of you who didn't know what the original looked like here is a picture another member gave me back when I bought the dual setup..
[IMG][/IMG]
I made several prototypes befor I settled on this one..
as you can see I had to change the center section so it was usable with the ls6 MAF setup plus I made a few improvments such as no seam or casting marks
Old Jul 11, 2010 | 11:05 PM
Camarslow's Avatar
Car: 1984 Z28
Engine: none
Transmission: none
Looking good man, what's the specs on that ls1?
Old Jul 12, 2010 | 02:40 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
that's looking pretty good.
Old Jul 12, 2010 | 05:59 PM
Engine: ls1, LB9
thanks! I think this will be the only one with that style cold air
as for the specs. its a 3.70 BW rear, 6-speed, ls1 with Arp rod bolts, HD bearings, ported Melling pump, ported Throttle body, 224/228 .588/.588 cam with cleaned up 241 heads (stock ls1 heads for 2001/2002) and better springs
Old Jul 12, 2010 | 06:33 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
That is nice. Very good job.
Old Jul 18, 2010 | 09:46 AM
Engine: ls1, LB9
More updated pictures, its almost done but I wanted to see how well it fit with the MAF..... room.. looks close in the pictures but the hump-hose wont even need to be cut much so I think that gives an idea that there is more room than it looks
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
