Pics of Twin turbo LSX
Old Aug 24, 2010 | 01:16 PM
383tpimachine's Avatar
Car: Corvette
Engine: 383
Axle/Gears: D36 w/ 3.08
Did a search and didnt come up with what I wanted.
Looking for pics of a twin turbo LSX in a camaro. Looking more for intake and turbo locations than anything. Thanks
Old Aug 24, 2010 | 05:22 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
Re: Pics of Twin turbo LSX
id put them behind the headlights. i sat one day and thought ab the best location for them and thats what i came up with
Old Aug 24, 2010 | 05:50 PM
Car: Corvette
Engine: 383
sideways? or turbines faces forward?
Im thinking space is limited. twin 6Xmm seem pretty big in my head
Old Aug 24, 2010 | 05:55 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
in the headlight areas, the turbo would be sideways, only way it would really fit.
Old Aug 24, 2010 | 05:58 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
something like this. but move the compressor side alittle more toward the fender. gives plenty of room for the exhaust and downpipe. helps when you have a turbo on hand to look at.
Old Aug 24, 2010 | 05:59 PM
Car: Corvette
Engine: 383
Would you take out one of the headlights?
Need to stay "streetlegal"
Old Aug 24, 2010 | 06:06 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
no leave it in. use a short filter and cut a hole where the battery and the evap canister used to be. you'll need to relocate the battery to do this. and run the boost pipes through the cut holes and have a 2 inlet (one on each side intercooler with a exit on one side. id suggest it come out the top but it would likely hit the hood latch. the exhaust should clear going by the motor just depends on what size pipe. this is why i chose to go n/a soooooo much less stuff to worry about. this is a setup on a 94 camaro.
Old Aug 24, 2010 | 06:17 PM
Car: Corvette
Engine: 383
Battery is going to be relocated to the trunk area anyway.
And no hood latch. Hood pins will hold it down.
So the top exit for the intercooler would be used.
Sounds like a good idea mounting them sideways.
no fenders wells. May be an option. and that intake a super or regular vic?
Old Aug 24, 2010 | 06:22 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Unless you do extensive fabrication and hand make your front suspension, you have to keep the inner fender wells. They are part of the "frame" since the struts mount to them.
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
looks like a victor jr. but id try and keep the fenderwells. the sideways sitting turbo's work good like on the 94
Old Aug 24, 2010 | 06:31 PM
Car: Corvette
Engine: 383
It would be a last ditch effort to get them to fit. I would rather keep them and seems like I should unless I want to get nasty with the welder
Is there anyway to mount the air inlet like the 5.0 foxbody guys in the fender?
Old Aug 24, 2010 | 06:48 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
yes you could. you'd just have to remove the stock horn. and move some relays. then build you a plate to mount the filter to
Old Aug 24, 2010 | 07:04 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Ohh it can be done. Just takes some welding and bending.
http://www.cecoatings.com/images/oth...p/000_0324.jpg
Some pic's for the OP. You can make anything fit.
Old Aug 24, 2010 | 07:06 PM
Car: Corvette
Engine: 383
Very nice 1 piece front u made there. Hood going to mount with dzuits? (sp?)
Old Aug 24, 2010 | 07:08 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
few more ideas for ya. just adapt it how ya need for lsx. etc..
http://www.cecoatings.com/images/oth...uction%202.jpg
http://www.cecoatings.com/images/oth...uction%201.jpg
Old Feb 12, 2014 | 09:21 AM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
I need some info on your front end.. I've been looking into ways of doing that.. basically like today's drift cars.
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Nick McCardle
Sep 10, 2015 08:36 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
