no start! need help!
Old Oct 17, 2010 | 08:56 AM
bigals87z28's Avatar
Car: Check The Sig
Alright we got everything hooked up and we tuned out vats. The car cranks but doesn't start. Fuel pump primes and everything but no start. Any help?
Old Oct 17, 2010 | 09:51 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
Re: no start! need help!
have you verified that it is getting spark?
Old Oct 17, 2010 | 11:04 AM
Car: Check The Sig
Well we isolated that the fuel filter is not letting fuel past the inlet. I can blow through the return line and the exit tube but not through the inlet. Any tips on the corvette filter install
Old Oct 17, 2010 | 12:17 PM
Car: Check The Sig
Ok well im an ahole. I mixed up the fitting to the filter.
Old Oct 17, 2010 | 02:02 PM
Car: Check The Sig
Well thatdidnt fix it but we do have fuel. Spark is a no go we aregetting no spark to the plug? Wtf?
Old Oct 17, 2010 | 10:15 PM
Car: Check The Sig
Typing on my droid is a pain.
We are getting zero spark. Zero at any coil. I am picking up some RPM, but not enough. Im gunna replace the crank sensor and hope for the best.
Old Oct 17, 2010 | 10:40 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
It seems as though this is a continuous cycle that a good number of us swappers have went through....and it seems like 90% of the time the culprit is the crankshaft sensor. Replace it and see if it doesn't fix the problem. That's exactly why mine had the same symptoms as yours.
Old Oct 18, 2010 | 11:53 AM
Car: Check The Sig
Im putting all my eggs and hope into the Crank sensor basket. Ill let you guys know tonight.
Old Oct 18, 2010 | 06:11 PM
Car: Check The Sig
Well, it's not the crank sensor. Narrows it down to the PCM or the harness.
Old Oct 18, 2010 | 06:41 PM
dynodanmanda79's Avatar
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
Did you happen to do a crank re-learn? Seems like some people are having to do that, I didn't have to do it on mine
Old Oct 18, 2010 | 07:02 PM
Pocket's Avatar
Car: 91 Trans Am
It will fire still needing a relearn. With the new engine/PCM/Tune Gm recommends doing a relearn, but you have to get it running first
Start with the basics, fuel air and fire. Are you sure the injectors are firing, are you sure the plug are dead
VATS doesnt control spark, heck as long as the PCM is receiving crank pos signal and the IGN is on, the PCM commands the coils to fire regardless of anything else
Test your PCM by hooking up a scan tool like TECH2 to the ALDL. Flick the IGN on and see what your sensors are showing. TPS, RPMs, IGN adv, CTS, IAT, O2s etc should all show live data
Old Oct 18, 2010 | 08:40 PM
Car: Check The Sig
Pulled the plugs and they are getting fuel. Pressure gauge at the rail is showing 50+psi. Spark is missing. That's it. Spark =start
Old Oct 18, 2010 | 09:09 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I know i need a crank relearn bad. It starts but idles like **** and everything else. To move it into SW's garage i had to give it gas and brake at the same time and creep in.
Old Oct 18, 2010 | 09:53 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Transmission: gto t56 (mn12)
Have you checked to make sure you are getting 12 volts to the coil packs? Should be a pink wire that connects at the ignition coil bracket on the large connector in the middle. I got my money on a missing ground to the ignition coils. On the 4th gen f-bodys the ground for the coils goes all the way to the headlight and headlight door ground. Check it out.
Old Oct 18, 2010 | 10:44 PM
Car: Check The Sig
Yeah I have power to both sides. Checked each coil too. I have the harness ground to the back of the head. I also have a large 4ga cable as a ground mounted to the block that runs right to chassis. I also have the factoy ground on the driver side grounded to the K. All grounds have been checked with a test lead.
Old Oct 19, 2010 | 07:41 AM
Pocket's Avatar
Car: 91 Trans Am
Do a continuity test from each of the coil pins to the PCM
Old Oct 19, 2010 | 08:50 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
im having a simuler problem, i have spark, and gas but no start. just cranks and fires.
Old Oct 19, 2010 | 08:53 AM
Pocket's Avatar
Car: 91 Trans Am
If it fires and immediately dies, then look to VATS
Old Oct 19, 2010 | 02:11 PM
Engine: L31 350
it fired but doesnt start, my cars an 86 so it doesnt have vats
Old Oct 19, 2010 | 02:48 PM
Engine: LSx 5.3
He meant the VATS in the PCM, did you have that tuned out?
Old Oct 19, 2010 | 03:22 PM
Car: Check The Sig
That's what im gunna have to do. Im gunna put my ecm in a friends ls1 car and see if it runs.
Old Oct 19, 2010 | 08:33 PM
Car: Check The Sig
Ok I put my adm in my friends LS1 car and it ran better with my ecm then his. We even swapped coils. We went over all grounds and it all checks out. Still no start. Only thing left is the Speartech harness.
Old Oct 19, 2010 | 09:06 PM
Car: Check The Sig
http://www.youtube.com/watch?v=zD_P3hUIlXg
Here is the vid of the start...or trying to start.
Old Oct 19, 2010 | 09:50 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
I think that pocket was suggesting that you unplug the ecm and check each wire coming from the ecm going to the coil harness connector. Don't actually check the ecm but just the wires. You're checking to make sure there are no opens or shorts in the wires.
Old Oct 19, 2010 | 10:10 PM
Car: Check The Sig
Yeah, Im gunna do that tomorrow when we have access to test leads.
Looking over at LS1 tech, I see that I might want to check to see if teh coils are getting power when cranking.
Old Oct 20, 2010 | 09:43 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
EDIT...I read the whole thread, and somehow missed the very last sentence above this post haha. Sounds like you already got clued into the 12v while cranking... Oh well. I typed it, so Ill leave it...
You have 12v to the coils and all...but is that WHILE cranking???
I made this mistake on my first go around. You have to make sure you are using a "hot while cranking" circuit. There is one that comes out of the big firewall connector. I believe its a larger gauge pink wire.
I have to say...that thing is cranking really fast. It almost sounds like you have the plugs out or something. I guess you could just have a really good battery/wires/starter combo goin on.
Check to make sure you're getting 12v while cranking to ALL of the pink wires in the engine bay. You can disconnect your starter to do this test, so that you can crank it without running the starter.
Its also VERY easy to break connection to the pink wires if you simplified the harness. Another mistake I made. Ended up having to jumper a wire from a known good pink wire, to the dead circuit. Mine was my MAF sensor and a couple other things. But my car still fired at that point. Check all the grounds like others have said too.
Good luck!
J.
Old Oct 20, 2010 | 10:12 AM
Car: Check The Sig
Yeah im pretty sure we hooked into that pink wire. Battery has 750cca and I have a 2ga wire running right to the battery. Im gunna test tonight to see if this is what's clinton.
Old Oct 21, 2010 | 12:50 AM
Car: Check The Sig
Well it RUNS!
http://www.youtube.com/watch?feature...&v=5XP_Und-dD4
Old Oct 21, 2010 | 06:24 AM
Car: 86 Trans AM
Haha congrats... now what the heck was it???
Old Oct 21, 2010 | 08:45 AM
Car: Check The Sig
12v switched is not the same as 12v cranking. Just an fyi
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
