Spy Pic - Optispark Relocation mod
Old Nov 20, 2010 | 01:10 PM
Firebat's Avatar
Old Nov 22, 2010 | 07:37 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Spy Pic - Optispark Relocation mod
very interesting, cool to see some ingenuity
Old Nov 22, 2010 | 08:20 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Subscribing!! very interested in this swap.
Old Nov 23, 2010 | 07:23 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
LT1: Now powered by Corn Pops!
Old Nov 23, 2010 | 09:01 AM
HAHAHAHAHA!
Old Nov 26, 2010 | 05:20 PM
Transamthunder's Avatar
That is pretty clever. Now if I hadnt already put on my breadbox intake, my vic jr would have been perfect as I found someone to drill all my holes for sbc to LT1 for 75 bucks, and I am sure for a lil more he would be happy to drill out my injector bungs too.
Old Nov 26, 2010 | 06:46 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
I knew there was a way to do it! I just didn't think it involved Corn Pops :S
Old Nov 26, 2010 | 07:01 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
you should send me that too lol.
But really you should send me that
Old Dec 9, 2010 | 07:36 PM
Firebat's Avatar
The key to getting this whole thing to work is to know Top Dead Center. On the back of the optispark, there is a numeral 1 with a circle around it that indicates TDC #1.
Old Dec 9, 2010 | 11:17 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Originally Posted by Firebat
That gets a ROFL. Some great imagination. But I think I would abandon LTx if you have to change the optispark often enough to have to go this far.
Old Dec 10, 2010 | 01:39 AM
Firebat's Avatar
Old Dec 11, 2010 | 02:06 PM
Firebat's Avatar
Old Dec 11, 2010 | 02:14 PM
Uumm, what is it?
Old Dec 11, 2010 | 02:30 PM
Shift06's Avatar
You're gonna give up and put it on the shelf? lol
Old Dec 11, 2010 | 02:40 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
looks like he is going to push it down the stairs
Old Dec 11, 2010 | 03:46 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Looks like a belt tensioner...but pushing it down the stairs is good too, might solve that problem with the optispark rotating
Old Dec 11, 2010 | 06:19 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
this is a great idea... however even if you used a small distributer, the EGR valve will not fit, you will also need to remove the studs too. So for people that need to keep the smog parts on, this is not an option.
Old Dec 13, 2010 | 05:23 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
I thought the vortec truck dizzy was pretty much an opti spark mounted on a distributor shaft? would one of those work as a strait replacement?
Old Dec 13, 2010 | 10:21 PM
Firebat's Avatar
No. Vortec truck dizzy uses a hall effect sensor (magnetic). Completely different than the optispark that senses slots cut in a round disc (optical?). That and the output signals from an optispark are different.
Old Dec 13, 2010 | 10:38 PM
ericjon262's Avatar
ok, well, new question, the opti is designed to be bolted to the timing cover so that timing cant change, how to you plan to ensure that the cam and dizzy are aligned correct?
Old Dec 13, 2010 | 10:55 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Same as you do with a sbc...turn it till it runs good then tighten it down.
Old Dec 13, 2010 | 10:59 PM
Firebat's Avatar
Old Dec 14, 2010 | 02:41 PM
ericjon262's Avatar
Originally Posted by robertfrank
Uumm, what is it?
looks like a toilet flange.
Old Mar 12, 2011 | 11:57 AM
ULTM8Z's Avatar
Any progress on this? I'm looking to go to SEFI soon. I read through the threads on the EFI connection setup, but I think the opti-relocation would be far easier and cheaper since I can easily repin my TPI harness over to an LT1/LT4 and add the necessary additional circuits.
Old Mar 12, 2011 | 03:30 PM
Firebat's Avatar
Old Mar 12, 2011 | 04:35 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I used to want to do that whebn i had a LT1, but never found details.
Old Mar 12, 2011 | 04:54 PM
ULTM8Z's Avatar
Opti relocation won't work without modifying the housing of the optispark or the firewall of the car because either the coil wire or the harness hits the back of the firewall.
I did find something easier/better and then found something better than that.
What I found first was that it was better to put the optispark internals inside of a TPI HEI distributor. However, not being able to machine a part, have to use a lot of little parts bolted together, have to make sure everything is exact isn't the easiest thing to do either. Plus, still keeps the optispark disc and sensor.
Then I found the 4X conversion using the LS1 style PCM (12200411). Better but not cheaper but still cheaper than the best brand new aftermarket optisparks. Like the EFI Connections 24X but doesn't use coil packs, it uses the vortec dizzy. For a complete 95 LT1, I estimate it will cost about $400 for a 4X conversion if the harness is just repinned and a couple wires added. About $300 for the conversion on a 96-97 LT1 and probably less for a SBC but that's if you figure out the harness yourself and buy all the parts used except the ebay vortec dizzy. I'm going 4X or 24X but leaning towards 24x since I found a set of cheap coil packs.
Here's how I figure the cost for a LT1 4X 0411 setup and probably missing a few small parts-
$100 96-97 Timing Cover, Hub, crank key, 4X Crank Sensor & Reluctor
$50 0411 PCM (I got one cheap for $38)
$100 Ebay Vortec Dizzy with 1X Cam sensor and spark plug wires (could use a used dizzy to cut costs)
$25 lopsided machined spacer for rear dizzy for stock LT1 intake
$100 Univeral timing pointer & aftermarket balancer since no timing marks on stock LT1 balancer and homemade optispark plug cover(sheet metal and Rtv)
Total $375
24X
$275 Above minus universal timing pointer/balancer
$275 24X reluctor
$10 24X sensor
$40 Coil packs (most cost $100)
Total: $600
One setback I have found for both 4X and 24X setups on the LT1 is that they will not work with a 94 or 95 4l60e unless you change out valve body, 3-2 solenoid with 96-97 parts. And on the 94 would need to change the front pump I believe. The 94 4l60e does not have a pwm pump and both 94 and 95 use a different kind of 3-2 solenoid.
Here's what I'm starting with...
An $8D 7730 system
ZZ4 which has the Vortec timing chain cover and 8" damper 12555879
Large cap HEI distributor
I'm not beyond repinning my harness as I'm very good with wiring and schematics.
So what would I need for a 4X conversion? P/N's would help too!
I don't want to go with the coil packs as I'd like to do this as inexpensively as possible.
Old Mar 13, 2011 | 02:28 PM
Firebat's Avatar
Old Mar 13, 2011 | 05:52 PM
ULTM8Z's Avatar
I think I'm probably going to do the Opti-into-HEI conversion. It'll be easier and cheaper I think. I already have an idea on how I can do it pretty simply.
Question, is that magnetic pickup sensor replaceable? Such that there's a separate part number for it?
I don't want to spend a boat load of money on a new Optispark. Would rather get a malfunctioning one really cheap just to get the mechanical guts out of it and then put a new sensor in it.
Thanks.
