LT1 + 700R4?
Old Dec 16, 2010 | 08:51 PM
sk8r fer life's Avatar
Car: 1990 camaro rs
Engine: 305 tbi
LT1 + 700R4?
can I bolt a LT1 out of a '96 caprice to the 700R4 in my '90 RS?
Old Dec 16, 2010 | 08:57 PM
scrubbin627's Avatar
Car: 1995 Camaro z28
Engine: 355 LTX
Axle/Gears: 4.10
Re: LT1 + 700R4?
yes
Old Dec 16, 2010 | 09:54 PM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Re: LT1 + 700R4?
Yes it will bolt on. Making it work right will require you to purchase about $250 in parts. Ranging from detent cable, intake bracket, throttle body add on bracket, Tcc lock up and vss things. All this of course for a proper swap.
Old Dec 17, 2010 | 11:10 AM
Pocket's Avatar
Car: 91 Trans Am
Re: LT1 + 700R4?
Another reason why the 4L60E that comes with the LT1 is a better candidate
Old Dec 17, 2010 | 02:18 PM
Engine: 355 LTX
Axle/Gears: 4.10
Re: LT1 + 700R4?
LT1's came stock with a 700r4 in 92-93
Old Dec 17, 2010 | 04:53 PM
Pocket's Avatar
Car: 91 Trans Am
Re: LT1 + 700R4?
His 96 LT1 came with a 4L60E
92-93 LT1s came with a 4L60
Old Dec 17, 2010 | 05:18 PM
Car: 1990 camaro rs
Engine: 305 tbi
Re: LT1 + 700R4?
well this is prolly going to be digging into my pockets wayy deeper than I can, so looks like I'll just have to find a regular 350
Old Dec 17, 2010 | 05:21 PM
Engine: 355 LTX
Axle/Gears: 4.10
Re: LT1 + 700R4?
700r4 and 4l60 are the same thing. It may have been 'called' a 4l60 in 92-93 but its the same transmission.
To answer the op's original question: Will a 96 LT1 bolt to a 700r4 - YES
Old Dec 17, 2010 | 05:24 PM
Carlos773's Avatar
Re: LT1 + 700R4?
Why not pick up a L05? Upgrade the cam to a l98 add some 1.6 rr and have a tune sent to you? Would of been my route if I stayed with gen 1. Tpi is nice but even 305s can go for 400-600 and l98s I see go for 400-750. This for good ones (under 110k).
Old Dec 17, 2010 | 07:32 PM
1bdbrd's Avatar
Car: 1991 Trans Am
Re: LT1 + 700R4?
What are the parts that cost the most? I figured you just needed the stock cables and such from a 93 lt1 fbody and the stock 93 throttle body? What are the proper parts for it?
Old Dec 17, 2010 | 07:40 PM
Carlos773's Avatar
Re: LT1 + 700R4?
You do but finding thpse parts for me and the past 3 weeks have been impossible. Next up are aftermarket offerings. Throttle bodys range anywhere from $130-$200 and even stock ones I have seen go from $75-$125.
Old Dec 18, 2010 | 10:18 PM
1bdbrd's Avatar
Car: 1991 Trans Am
Re: LT1 + 700R4?
Oh wow. I've seen those parts literally given away for free locally. Wish I had known..
Old Dec 18, 2010 | 10:38 PM
Carlos773's Avatar
Re: LT1 + 700R4?
Keep in mind this is only 92-93 Lt1specific items.
Old Dec 18, 2010 | 11:10 PM
DAREDEVIL 1's Avatar
Car: CAMARO,GMC SUBURBAN DUALLY,RACEBOA
Engine: 305 TBI( soon 383),350Vortec
Transmission: 700 turbo
Re: LT1 + 700R4?
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
