K member brace with A/C notch?
Old Dec 30, 2010 | 10:32 AM
mille_3's Avatar
Car: 1986 Firebird
Engine: 6.0L LSX
Just wanting to confirm. Once I notch the K-member for a/c will I be able to reuse the brace? From the looks of it seems the bolt hole gets cut away and the brace itself would be in the way.
Old Dec 30, 2010 | 12:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Can't use the factory brace.
Old Dec 30, 2010 | 05:35 PM
mille_3's Avatar
Car: 1986 Firebird
Engine: 6.0L LSX
Re: K member brace with A/C notch?
Any other solutions beside a tubular K-member?
Old Dec 30, 2010 | 05:51 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
modify/trim the brace?
Old Dec 30, 2010 | 06:12 PM
mille_3's Avatar
Car: 1986 Firebird
Engine: 6.0L LSX
I haven't really looked at it too closely yet, but you lose the bolt hole for the brace once you notch. Maybe weld straight to the K-member?
Old Dec 30, 2010 | 11:08 PM
sargenewk17's Avatar
Car: 92 Camaro RS
Engine: LS2
Axle/Gears: 12-Bolt with 3.73
I have a tubular K-member that I ordered with the brackets to attach the braces ... but to fit my LS2 (GTO, stock accessories) in there I had to cut off the inner bolt stud for the brace. There is still room to make a brace using only the outside bolt, but the inside bolt is gone. I plan on making custom braces, but I haven't done it yet.
(I hope that wasn't too terribly confusing)
Old Dec 31, 2010 | 01:44 AM
Firebat's Avatar
You may not have to do the "notch." I just pounded the section in with a 20 oz hammer where you would notch and made a big enough indention for the a/c compressor to clear. Still have factory braces installed and don't remember them being any problem. My a/c is for LT1 though so LSx a/c compressor location may be in a slightly different spot.
Old Dec 31, 2010 | 09:41 AM
mille_3's Avatar
Car: 1986 Firebird
Engine: 6.0L LSX
Hmm. How different are the compressors?
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
luvofjah
Sep 10, 2015 10:41 AM
Ian Irvine
Sep 4, 2015 08:08 AM
