Need a torque converter
Old Jan 26, 2011 | 06:07 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
I gave up on the 700R4 after close consideration. Found myself a 4L60E and now I need a torque converter for it. Motor is a 5.7L and will be completely stock(for now). I have been told that the stock converter was something like 1,650 stall?
I found this one for a fair price and seems like it would get the job done. And I don't know a darn thing about transmissions so its time to learn. http://racetransmissions.com/store/p...roducts_id/252
Car will be daily driven this summer so nothing crazy. So should I spring the extra $40 bucks and buy one with a slightly larger stall? I will probably throw in an LS6 cam in the near future.
Old Jan 26, 2011 | 06:22 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
Re: Need a torque converter
2800-3200. i couldnt tell mine had a 3600 in it really.
Old Jan 26, 2011 | 06:29 PM
chevelle600's Avatar
Car: '87 IROC-Z/28
Engine: 357 HSR
Axle/Gears: 3:73 w/Eaton Posi
if you've got a 30 spline input shaft on your tranny, i have a converter that fits the 30 spline 700r4. so long as the bolt pattern is the same, itll bolt right up. its a brand new never installed TCI converter. im looking for 200 shipped. its got an 1800 stall
Old Jan 26, 2011 | 06:31 PM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
do you mind my asking why you gave up using the 700r4?
Old Jan 26, 2011 | 06:33 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Hmm...I may take you up on that. Does anyone know whether or not the flywheel bolt pattern is the same?
Old Jan 26, 2011 | 06:38 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Well the fact that my trans was bone stock with 140K was reason #1. Plus I ended up paying $600 for a rebuilt Ls1 f-body trans so having adjustable shift points was just a bonus.
Old Jan 26, 2011 | 06:42 PM
Car: '87 IROC-Z/28
Engine: 357 HSR
that i am unsure of, i think the lt1 style yes, but not sure about the ls platform. post up a pic of your flywheel you're using
edit just checked the jegs product page for it, says it does not fit the ls1..
thunder85's Avatar
Engine: 5.7L w/hsr
ah.. that makes perfect sense. 600 is an awesome price
Old Jan 26, 2011 | 06:56 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
I don't really give Jeg's or Summit's websites credit for anything.....however I haven't sold my 700R4 yet so tomorrow I'll take my flywheel over and check, she's been alone in the garage for awhile and could use a talkin' to anyway .
Edit: I take that back. I believe something about the converter was different when the switched to the 3 piece case, can any else verify this?
Old Jan 26, 2011 | 07:15 PM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
exactly what i was going to say, even a 3400.
you can check out yank, vigilante, or circle d converters.
Old Jan 26, 2011 | 11:50 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
circle d has come nice quality parts!
Old Jan 26, 2011 | 11:58 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
I would snag a 3600-ish even for a stock motor, peak torque is 4500 on a stock ls1, so anything under that would be perfect actually. The trans still has lockup so go big if you like, it'll still lockup and get great highway manners.
Old Jan 27, 2011 | 12:32 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You need an LS1-specific torque converter, or use an adapter with a TH700 converter. 1800 stall is not near enough, though, even for a stock LS1.
(I'd point out that a member recently posted he has a 3600 stall Yank for sale, but I'm hoping I can get it... )
Old Jan 27, 2011 | 12:36 AM
xpndbl3's Avatar
Car: 1984 Z28
Just sold a 3800 yank not too long ago, bet your car would have loved it.
Old Jan 27, 2011 | 09:49 AM
Convoy25's Avatar
fwiw i plan on putting in a 3600 stall on my stock motor, i plan on doing more things as well, but i'm pretty much set on 3600
seiplentz
Aug 19, 2019 06:02 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
