modifying clamshell for ac
Old Jun 6, 2011 | 11:00 AM
diablizzard's Avatar
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
I know I found the link somewhere, but I can't remember where. I need the link to the post for modifying the clamshell for the low mount LT1 AC compressor.
Old Jun 6, 2011 | 08:08 PM
Car: 86 Camaro Z28
Re: modifying clamshell for ac
I found the link with a little more searching. If this link could be added to the frequent QA for LT1 swap that would be great. It also includes notching the subframe, with pictures.
http://www.hpsalvage.com/3rdGen.htm
Old Jun 6, 2011 | 11:54 PM
Firebat's Avatar
Good stuff but I wouldn't put a bolt through the motor mount that attaches to the back of the compressor like in this pic.
http://www.hpsalvage.com/pic5.jpg
I can see its purpose in that it provides extra support. The reason I wouldn't is because if you ever needed to remove the main accessory bracket for any reason and wanted to the ac compressor to have a little more play while removing stuff if ever needed to. I think the long motor mount bolt would need to be removed then the engine jacked up to get to the bolt that I don't think is needed. Could be wrong though.
Old Jun 8, 2011 | 06:00 PM
Car: 86 Camaro Z28
I understand your point, but that is the cheapest solution I've found so far. The relocation bracket isn't in the budget right now. there is a chance that the bolt can be snuck out.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
