5.3L with truck intake/tb, which throttle cable?
Old Jun 17, 2011 | 06:35 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Do I need a 98-00 camaro throttle cable or a later year one, going in a 87 fullsize that had tbi. I have searched and saw that one without traction control is needed, just don't know which year camaro one or one off a silverado to run the truck intake/tb.
Old Jun 17, 2011 | 06:44 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 5.3L with truck intake/tb, which throttle cable?
the difference in years is due to the difference in throttle cam shape/size; that will more depend on what year your tb is off of. i still haven't fit mine on to my ls3 intake /edelbrock tb and never installed the cable when i had the ls1 intake / 2000 silverado tb, so that's about as far as i'm going to be able to help....
Old Jun 17, 2011 | 06:51 PM
xpndbl3's Avatar
Car: 1984 Z28
fair enough, I have to assume the tb is from 99-01 since after that time frame they switched to DBW setups. Just wanted to knock one more thing off the list of crap to order before I drop it in.
Old Jun 17, 2011 | 06:53 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Arent the LS1 TB's similar/same as the truck TB's? Only difference is like said above, there were 2 variations in throttle cam and one had a blue spring and one had a brown one for different throttle cams. Based on that, you should use the fbody throttle cable for that year TB.
I have a 98-99 brown springed TB I think and i used the 98-99 factory throttle cable on my car. I'd have to search my old notes to see exactly what I did get but I think thats right. I know its not an LS1 intake setup but the throttle body is in about the same location as it would be on a Truck/LS1 manifold. Cable was perfect fit for my gas pedal and perfect length for my TB
Old Jun 17, 2011 | 07:04 PM
INTIMIDATOR Z's Avatar
Car: 1987 IROC
Engine: Turbo 293ci 4.8l
i used a bicycle brake cable. works fine.
Old Jun 17, 2011 | 07:10 PM
xpndbl3's Avatar
Car: 1984 Z28
ok i'll order up the cable, we'll see what happens, I guess worst case I can resell it on here...lol.
Old Jun 21, 2011 | 12:57 AM
xpndbl3's Avatar
Car: 1984 Z28
Just so everyone knows the f-body cable came in today, it is NOT a direct fit with the truck throttle cable bracket, there was some interesting cutting, welding and drilling of a hole to make it all function to an acceptable level for me. Hopefully it is all good now, we'll see once the motor hits the chassis
Amillionoh7
Sep 11, 2015 11:36 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
Randomtask2
Sep 7, 2015 05:06 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
