Hawks 1 5/8" vs. SSW 1 3/4" headers, opinions?
Old Aug 18, 2011 | 01:01 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I've been using the polished Hawks headers for my swap that are the smaller primaries. I talked to Bruce and upgraded to the SSW 1 3/4, they're waiting for me to pick up at fedex today. So I'm kind of curious what you guys think I might gain at the wheels with the better headers on a big cam 6.0 with ls6 intake, 6spd. Right now it puts down 420/407. It would be cool to see those numbers jump to 430/415, but what do you guys think?
I'll dyno it later this fall after I recheck my pushrods and rockers, thing is noisy so I don't want to risk hurting something. A dyno test will show the real proof between the two but I am just really curious.
Old Aug 18, 2011 | 01:26 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: Hawks 1 5/8" vs. SSW 1 3/4" headers, opinions?
What RPM is your peak horsepower at right now?
My guess is that you'll pick up some higher RPM horsepower, and your peak torque might come up a couple hundred rpm, but the number won't change.
Old Aug 18, 2011 | 01:31 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
Well I have 1 3/4 on my car.. And if they made a 1 7/8 that would fit id ditch the 1 3/4... Ls1's pick up power going from 1 3/4 to 1 7/8.. So a 6.0 would surely benefit
Old Aug 22, 2011 | 05:04 PM
STREETDEMON's Avatar
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
wow i didn't realize you were using the smaller headers when you put those numbers down....impressive.
Old Aug 22, 2011 | 05:16 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
get them on yet?????????????
Old Aug 22, 2011 | 05:27 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Heck I made a run last week and beat the 397 mark. 414 Now same tune with 1 3/4 WITH 2.5 collectors and 2.5 Y pipe! I'm sure I have 420 in there with more tuning.
Old Aug 22, 2011 | 05:48 PM
BlueZee28's Avatar
Thanks, I kinda thought they were good numbers, all things considered.
Not yet. I will have them on sometime this week or this weekend. I took the extra set of polished ones out of the box and set them up next to the SSW headers, and they're the exact same length, so I may get away with having to add any material to my y pipe after all. Bruce seemed to think I'd have to add 2-3" of pipe between my existing y pipe and the collectors.
Old Aug 27, 2011 | 11:13 PM
BlueZee28's Avatar
New headers are on, they're the real SSW 1 3/4" primary headers with 3" collectors. They quality is awesome on them, except I never had a problem with my o2's hitting the floor until I put these in. I had to pry the header down away from the car in order to get the o2's in their bungs. Hopefully the shaking from the car won't break them...If so i may end up putting caps on the bungs and moving them down stream a bit.
Here's some photos for you guys.I currently have 3 sets of longtubes in my garage. The polished 1 5/8" set that came off the car, a brand new set of 1 5/8" that was sent to me by accident back in April, and the true SSW set I just got like a week and a half ago.
This is one of the ones off the car. The flanges started rusting on me which is the main reason why I wasn't satisfied with them.
Old Aug 27, 2011 | 11:15 PM
BlueZee28's Avatar
Oh yea, and these were literally trapped insid my passenger side header when i pulled the old set of. They didn't go through the engine because they're not chewed up. But when I removed the header I heard something rattling around. I was like what the french toast is that? I shook it and they wouldn't fall out of the collector, i had to tip it upside down and these fell out of one of the primaries.
I don't know what's up with that....
Old Aug 29, 2011 | 05:56 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I've heard of having a screw loose, but come on...
There doesn't seem to be anything good to say about the 1-5/8" headers. I've got the 1-3/4" x 2-1/2" units on both cars, and have no complaints. Well, except for the #3 spark plug wire boot resting on the tube (doesn't seem necessary to pass it that close to the plug).
Old Aug 29, 2011 | 09:25 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Your car + headers are looking sweet Nick.
Old Aug 30, 2011 | 10:09 AM
skiwrench's Avatar
Car: 2015 Chevy SS
Engine: LS3
Transmission: 6L80E
Looks good. I was not able to get the 1 5/8 headers to work at all.
Old Aug 30, 2011 | 10:23 AM
jbone's Avatar
Car: 1984 Z/28
Engine: L92 6.2L
Transmission: M12 T56
I have the 1 5/8 headers and they fit great. How did yours not work at all?? I figure when my pockets are a bit deeper I will get the 2" headers, and pass the 1 5/8 headers off to someone else. I figure though that with ls3 intake and 90mm throttle body and stock cam that I am running, the 1 5/8 headers will be great.
Old Aug 30, 2011 | 02:30 PM
skiwrench's Avatar
Car: 2015 Chevy SS
Engine: LS3
Transmission: 6L80E
The collectors were hitting the frame rail.
Old Aug 30, 2011 | 06:17 PM
BlueZee28's Avatar
I didn't have that problem with the cheaper set. The only problem I have is actually with the SSW set with the o2 bungs being too close to the trans tunnel.
Old Oct 29, 2011 | 11:02 AM
jbone's Avatar
Car: 1984 Z/28
Engine: L92 6.2L
Funny thing I just had my car dynoed and the owner of the dynotuner shop said that he's gotten the most hp out of a stock ls3 with the 1 5/8 headers and a custom intake and cam.
Old Oct 29, 2011 | 11:14 AM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Funny thing I just had my car dynoed and the owner of the dynotuner shop said that he's gotten the most hp out of a stock ls3 with the 1 5/8 headers and a custom intake.
I dont see how thats possible since the stock ls1's make more power with a larger header.
Old Oct 29, 2011 | 04:05 PM
jbone's Avatar
Car: 1984 Z/28
Engine: L92 6.2L
Yea, I thought it was odd as well. The ls3 does have way different heads than the ls1.
Old Oct 29, 2011 | 06:29 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
maybe he misspoke , as in the wrong size came out when he was talking
Old Oct 29, 2011 | 06:36 PM
daddy33's Avatar
Car: '85 Camaro
So what headers are these from left to right? Mine looks exactly like the ones on the left.
Fronzizzle
Feb 9, 2017 09:31 AM
Chad Speier
Sep 24, 2015 12:32 PM
Jlanz55
Sep 8, 2015 11:28 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
