stupid wiring question.
Old Oct 8, 2011 | 04:27 PM
rock861261's Avatar
where did you put the f4 c100 ignition wire on a ls1 swap?
Old Oct 8, 2011 | 10:07 PM
Pocket's Avatar
Car: 91 Trans Am
Re: stupid wiring question.
Anything that needs 12v IGN, but doesnt have to be fused. If you need to add a fuseblock/relay center use it to trigger the IGN relay and power up the fuseblock
Old Oct 8, 2011 | 10:56 PM
rock861261's Avatar
when you did your swap what did you hook it up too?
Old Oct 9, 2011 | 12:31 AM
rock861261's Avatar
Im looking for a good spot for the 4l60e ignition whats a good spot? old vats fuse?
Old Oct 9, 2011 | 09:30 AM
Pocket's Avatar
Car: 91 Trans Am
Emissions fuse from the C100, PNK/BLK
Old Oct 9, 2011 | 11:11 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Another stupid question:
Hi Pocket. I still don't understand what I'm supposed to do with the reverse lockout wiring on my LT1 with T56.
I am retarded when it comes to wiring.
One wire goes from the plug on the tranny to the PCM right? and the other wire from the plug on the tranny goes WHERE--is it to the pink wire on the 4L60e harness or somewhere else?
Thanks!
Old Oct 9, 2011 | 11:17 AM
rock861261's Avatar
thats what I was going to do But I want to still run emissions and iim trying not to lengthen the trans harness i was going to drill a hole by the shifter and run it straight up.
Old Oct 9, 2011 | 03:17 PM
Pocket's Avatar
Car: 91 Trans Am
4L60E pin E is IGN, run this to your rev lock PNK wire
Old Oct 9, 2011 | 04:52 PM
rock861261's Avatar
rev lock?
Old Oct 9, 2011 | 05:04 PM
Pocket's Avatar
Car: 91 Trans Am
Reverse lock out solenoid for T56 users
Old Oct 9, 2011 | 05:07 PM
rock861261's Avatar
Oh I know which wire is the ign wire on the trans harness Im asking wheres the best place on the interior to tap into to get it power
Old Oct 9, 2011 | 05:18 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
OK so the reverse lockout wire on the T56 side pigtail is pink and I run this to pin E on the 4L60e plug on the engine harness? Then the other wire on the T56 side pigtail I run to somewhere on the PCM?
Sorry Jon...I really am retarded with wiring. The only time I can do it myself is if there are exact instructions with color to color suggestions he he he.
Thanks for your help!
quote=Pocket;5062394]4L60E pin E is IGN, run this to your rev lock PNK wire[/quote]
Old Oct 9, 2011 | 06:57 PM
Pocket's Avatar
Car: 91 Trans Am
Not really a good place to tap into aside from the emissions common
Yes, PCM pin is D6 (blue connector, grn wire)
Old Oct 9, 2011 | 08:01 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Thanks Jon I appreciate your help a great deal!
Old Oct 9, 2011 | 10:02 PM
rock861261's Avatar
what about the old vats fuse? now that its a ls1 no vats will be used... unless the emissions common would support emissions and trans together?
Old Oct 9, 2011 | 10:13 PM
Pocket's Avatar
Car: 91 Trans Am
Its 12v constant not IGN, plus it doesnt end at any body connector. You'd have to run an external wire to it
Cleotiz
Jan 6, 2018 08:56 PM
RedLeader289
Jan 22, 2016 03:05 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Fronzizzle
Aug 19, 2015 01:36 PM
Bryan F
Aug 18, 2015 02:28 PM
