LSX w/ 3rd Gen Fuel Gauge Question
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
I searched around but im wondering what the stock 3rd gen gauge reads or of what kind of reading at all it gives BEFORE any mods (resistors or sender)? Mines pegged, cant tell if its an open circuit or just the way it acts before modding it. I'm moding it now with resistors but im wondering if the sending unit was DOA/stuck from my work.
Re: LSX w/ 3rd Gen Fuel Gauge Question
4th gen tank with 4th gen guts, gonna modify gauge with resistors to use stock gauge, trying to decifer if its normal for the gauge to peg with the wrong resistors in there or if my sender is bad, rapped on the tank a few times just to see if the gauge would move, nothin.
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
This is what I did https://www.thirdgen.org/forums/ltx-...s1-fuel-3.html post # 105
The resitor part of the thread confused me. The only benifit that I saw with the resistors would be the guy who wants to retain the stock guages as well as emisions.
nope still pegged at full. confused... jacking up car now to check tank wiring.
Car: '89 Firebird
Engine: 7.0L
4th gen sender is about 40 Ohms resistance on empty, and 'full' on the 3rd gen gauge is calibrated to about 90 Ohms resistance. I think the original gauge will read around 1/2 full when the 4th gen sender is at empty. And the gauge will not even come off full until there is well less than 1/2 tank left.
i dont if this will help someone help me, but the resistors i took out were:
20ohms 5% 2watt
and
120 ohms 5% 2watt
20ohms 5% 2watt
and
120 ohms 5% 2watt
Car: '89 Firebird
Engine: 7.0L
The two purple wires from the 4th gen tank are the fuel level sender. Tell us how you have those two wires routed. It seems to be behaving as if you don't have the 2nd purple wire connected to ground.
The pink wire was originally the B+ power supply to your pump. It has nothing to do with the fuel gauge. The gauge didn't move because it is just responding to whatever circuit resistance is on that circuit. I'd be more worried about damaging your cluster with what you did.
gauge is currently reading around 3/4... im gonna go see if its accurate.
Car: '89 Firebird
Engine: 7.0L
Picture below is a LS1 F-body pump module. Note the 2 purple wires to and from the level sensor. Those go to the 4-pin white connector. 2 of the pins are the level sensor and 2 of the pins are power for the pump.
Resistors are not directional. Doesn't matter which way installed.
weird thing is the gauge shows 3/4, even after topping it off...
Car: '89 Firebird
Engine: 7.0L
I suspect you have open circuit to the fuel sender (not grounded correctly using 2nd purple wire).
The fuel gauge operates on a trio of resistors with the fuel sender being the center leg with variable resistance depending on level of fuel float. I think the fuel sender is not grounded correctly (2nd purple wire) and is open circuit. The needle is sweeping to whatever the position dictated by the value of the two resistors you soldered into the guage. When you swapped the resistors the needle switched sides with it. Not having the center leg working is also why your fuel gauge never moves.
Maybe I have some details incorrect (I've not done my swap yet), but it sure seems the problem is somewhere in the wiring at the tank.
well heres the thing, i opted this route from 750 L98's thread, search fuel gauge or something (in this forum), it comes right up about changing the gauges resistors, its only 2 resistors and fairly easy to change them. also, if you check around, searching "fuel tank wiring" you'll find a couple threads on the 4th gen tank wiring, no mentioning of a 2nd purple wire, i do Not have a 2nd purple wire. my next step is to drop the tank and check the sender and maybe even buy a another fuel gauge to modify just incase.
For QwkTrip:
Post #4 https://www.thirdgen.org/forums/ltx-...ear-brake.html
Thread from 750 L98:
https://www.thirdgen.org/forums/ltx-...auge-40-a.html
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I think you did like I did originally. The purple wire is supposed to be connected to the purple and then there is another wire (I Believe it was grey) that needed to be grounded from the sender, BUT there are two grey wires from the bulkhead, one is for the pump. Should be easy to identify since the pump wire is a lot thicker.
When I put mine in I screwed up and had a full tank ALL the time too, though I dont remember what I did that was wrong now. I actually ran out of gas and then I realized my mistake.
I think you did like I did originally. The purple wire is supposed to be connected to the purple and then there is another wire (I Believe it was grey) that needed to be grounded from the sender, BUT there are two grey wires from the bulkhead, one is for the pump and you can NOT ground that one. Should be easy to identify since the pump wire is a lot thicker.
Car: 91 z28
Transmission: 4L60e
Pin B is fuel pump 12v, splice this direct from the 3rd gen harness gry to gry
Pins C blk and D blk/wht are grds for the pump and sender respectively. Splice these to the 3rd gen grd wire blk
Pin A ppl is fuel level sender signal. Splice this to the last wire on the 3rd gen pigtail ppl to ppl
One of the purple wires (the ground) from the level sender in the tank, changes color from purple to blk/wht when it exits the top of the sender. I think thats where you two are confusing each other.
88Formula, I still recomend going to the Grand Prix sender and leaving the resistors alone.
Car: '89 Firebird
Engine: 7.0L
AkDrifted
Aug 17, 2015 07:45 PM
