Help For LS1 Swap
Old Dec 5, 2011 | 07:08 PM
fatalicshock's Avatar
Car: 87 Trans Am
Help For LS1 Swap
I Have an 87 TA with a 305 and T5 with 2.73 gears and i wanna do a LS1 swap in it and i pick up an Ls1 Camero for 3500 turned the key and drove it home i wanted to use what ever i could of that car and then sell the shell. So what all could i use from the Ls1 car over into my TA for the swap because money is really tight but i want an LSx 3rd gen. Thanks.
Old Dec 5, 2011 | 07:20 PM
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
Re: Help For LS1 Swap
Check out the sticky, best place to get started.
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
https://www.thirdgen.org/forums/ltx-...third-gen.html
Old Dec 5, 2011 | 07:21 PM
travis401's Avatar
Car: 91 Camaro RS
damn, you beat me too it blue
Old Dec 5, 2011 | 07:22 PM
Car: 87 Trans Am
Thanks Guys
Old Dec 5, 2011 | 08:28 PM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
seat dash center consol pedals gas tank (will have to shorten the neck by 1 inch) rear end front brakes brake booster and master engine trans door panels (with mods) ecu wireing wheels with adapters for front not needed if you use the rearend
the list is endless it all depends on your skill
I have swaped all of the above to my car so I know they will work
Old Dec 6, 2011 | 05:28 PM
Car: 87 Trans Am
This is my first engine Swap ever so lol kinda flyin in the dark
Old Dec 6, 2011 | 05:30 PM
travis401's Avatar
Car: 91 Camaro RS
do ALOT of reading before even unlugging the first connector or lossening the first bolt.
Old Dec 6, 2011 | 06:26 PM
UnstableAviator's Avatar
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
Quoted for truth. Every piece of information you need to do the swap is on this board, or avaliable with a basic google search. Read, study, contemplat...you know, "built it in your head".
If its your first engine swap or first real mechanical job, I wouldn't recommend it without some experienced help.
Old Dec 6, 2011 | 06:41 PM
Car: 87 Trans Am
i went to school for automotive so its not like its my first time picking up a wrench and ive change more trannys than i can count lol
Old Dec 6, 2011 | 06:55 PM
lunati397's Avatar
I did it all on my very first engine swap no experience no garage no tools had to work out of a buddys shop it took me 3 months
Old Dec 6, 2011 | 08:59 PM
Car: 1984 Camaro
Excellent, then the swap should be within your capabilities. I know I've found the LS1 swap one of the most rewarding car projects I've done. Good luck man, and get a build thread going when you start!1!
Old Dec 6, 2011 | 09:52 PM
lunati397's Avatar
I am a fan of build threads not only can you see the before and after but all the tricks and headaches along the way and you learn a whole lot more I give alot of credit to the guys that take the time to stop take a pic and post later on and trust me its a pain to stop and think Progress pic time lol
I know
https://www.thirdgen.org/forums/engi...dgen-swap.html
1984HO
Mar 19, 2021 11:59 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
