Got the ls6 coolant crossover pipes now what??
Old Jan 30, 2012 | 03:43 PM
POP6482's Avatar
Car: 1989 Iroc-Z Convertible
Engine: 6.0 LQ4 LSX
Axle/Gears: Moser 12 bolt w/4.11s
I'm not exactly sure what else I need to get this together. I know I have to run the rear hose to the front, t it off, and run to the radiator. Does anyone have a pic or an idea of what size hose I need. Along with that I need the 4 bolts for the coolant lines. I read on tech that they might be m6x1x30mm. Does that sound right??
Old Jan 30, 2012 | 04:05 PM
Thridgen60's Avatar
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Axle/Gears: 9 inch, 3.50
Re: Got the ls6 coolant crossover pipes now what??
I believe it is 1/4in hose and the bolts are m6 but not sure on the length. Just go in your garage and measure for the length, easy enough.
This is how i have always ran mine, just clamped a piece of gas pipe into the radiator hose with a tapped hole and barb fitting in it.
Old Jan 30, 2012 | 04:20 PM
Iroc'nthe87's Avatar
Dude, please stop creating a new thread every time you have a question or problem.
Old Jan 30, 2012 | 05:54 PM
POP6482's Avatar
Engine: 6.0 LQ4 LSX
So what am I supposed to do if I have a question about something?
Old Jan 30, 2012 | 06:01 PM
mille_3's Avatar
Car: 1986 Firebird
Engine: 6.0L LSX
I think what he is trying to say is to create a thread for your swap and ask all questions in that thread.
Old Jan 30, 2012 | 06:02 PM
Just localize all your questions into a single thread or start a build thread. You could post pictures and document your progress which would be cool too.
Old Jan 30, 2012 | 06:04 PM
POP6482's Avatar
Engine: 6.0 LQ4 LSX
Gotcha
Old Jan 30, 2012 | 06:11 PM
Thridgen60's Avatar
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Also it is usually faster to look for the answer in a search either on here or on ls1tech.
Old Jan 30, 2012 | 06:19 PM
POP6482's Avatar
Engine: 6.0 LQ4 LSX
I looked around quick today.........
sheachopper
Jul 31, 2019 11:27 AM
LT1Formula
Oct 8, 2015 08:34 PM
