will these LS swap engine mounts work?
Old Feb 12, 2012 | 06:55 AM
camarozz383's Avatar
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
hey guys i was wondering if you might know if these Moroso LS Series Motor Mount Adapter Plates will work with my older style engine mounts? any info will help, thanks
Old Feb 12, 2012 | 07:18 AM
Z28 MeTaL HeAd's Avatar
Engine: Carb'd LT1 w/ a Cam :)
Axle/Gears: Moser 9" w/ 3.75 gears
Re: will these work?
Attachment 234136
Yes, they will.
Old Feb 12, 2012 | 07:40 AM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
great! thanks for the reply.
Old Feb 13, 2012 | 04:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I used a different brand, but same concept.
Only hitch is you can't use the LS1 AC compressor with them.
Old Feb 13, 2012 | 04:11 PM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
Re: will these LS swap engine mounts work?
yeah but cmon now Five7, A/C is overrated anyway
Old Feb 13, 2012 | 04:29 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
bolt holes aren't staggered they won't fit properly. You need ones like the car shop inc 1" setback plates
Old Feb 13, 2012 | 05:36 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
+1
Old Feb 13, 2012 | 06:25 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
the non-setbacks work, you just gotta notch more outta the kmember. i used them on my 5.3L. however, if you havent bought anything yet, go with the 1" setbacks, it'll put your engine and trans where they belong.
Old Feb 13, 2012 | 08:11 PM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
cant i just set my holes back 1" ? that should do the same thing? i want everything to go just as it was in the beginning, thanks guys for the help
Old Feb 14, 2012 | 06:54 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
if you buy the right ones the first time, you dont have to mod. if you're going to buy the plates, get the 1" setback ones and be done.
Old Feb 14, 2012 | 07:20 AM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
I hear ya, but I love to fabricate and weld so makeing my own would just be fun, but you are right, if i was to buy them, get the right ones the first time, im looking for measurements and info to make it a little easier. thanks
Old Feb 14, 2012 | 07:27 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
if that's the case, i know i've seen dimensions somewhere over on 'tech for building your own swap plates. just can't seem to find them at the moment.....
Old Feb 14, 2012 | 07:28 AM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
ok great, thanks for your help!
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
