Motor mount Help!
Old Mar 2, 2012 | 09:04 PM
Speedfreak391's Avatar
Car: 87 iroc Arctic White w/gold ss stri
Engine: Turbo'd 5.3 in process
Transmission: T-56 w/SPEC stage 3+ clutch
Axle/Gears: 9" Moser w/3.25's
Motor mount Help!
Ok guys, I am having a hell of a time with my motor mount plates. I got a set of 1" set back plates from jeggs. But I have just about had it with these efing mounts and plates. I am already $75 deep into these mounts and I would like to get my motor in my car like asap. I am trying to upload some pics to show you what I am working with. I guess they are to big to upload.
I guess the question I need to be asking is, Are my clam shells supposed to be below the front 2 exhaust ports? Or do I have these mounting plates on wrong. I feel like a complete idiot asking this.
Old Mar 3, 2012 | 07:01 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: Motor mount Help!
use photo bucket.
im not sure i understand the issue? the idea of the offset is to set the motor back towards the firewall
Old Mar 3, 2012 | 07:48 AM
POP6482's Avatar
Car: 1989 Iroc-Z Convertible
Engine: 6.0 LQ4 LSX
Axle/Gears: Moser 12 bolt w/4.11s
not really sure either, but the clamshells only have one place to go on the block. I used the Spohn swap mounts with the only issue being the second mount bolt being a PITA to line up (seems to be pretty common). I know many others have used 1" set backs with their swaps also. Search around the swap threads.
Old Mar 3, 2012 | 06:37 PM
The problem I am having is the pass side clam shell hit the threaded boss on the block for the truck accessories.
Attached Thumbnails Motor mount Help!-20120303_124830-1-.jpg   Motor mount Help!-20120303_124852-1-.jpg
Old Mar 3, 2012 | 08:21 PM
ransam's Avatar
Car: 88 trans am 72 olds cutlass
Engine: soon to be 5.3 455 olds
Transmission: soon to be t-56 2004r
Axle/Gears: 3.23 3.73
I had the same problem and i just took a grinder and made a half circle notch to clear the bolt boss.
Old Mar 3, 2012 | 09:14 PM
I already have the plasma cutter out for the morning. And that was the plan.
Old Mar 4, 2012 | 08:26 AM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
YEA!!! gotta love the plasma
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
