ls1 injectors on 5.3 tune
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
My tuner is tellin me that the ecu doesn't need to be tuned for the ls1 inj. He says the ecu can compensate for the slight change. Is this true?
Car: '91 TA vert
Engine: turboLSx
Re: ls1 injectors on 5.3 tune
What are the flow differences between the two?
A better question, it only takes a few seconds to change the value, why not?
I think he forgot to do it to be honest with you and he is just tellin me this so he doesn't have to mess with it.
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
which LS1 injectors? 28 or 26#? when i ordered my Tuned ECM from spareecm on ebay, he asked me which specific injectors i was using so i assume its important. Tune runs my 5.3 awesome.
Noob question... How do I tell what lb injectors I have
I forgot to look at my injectors last night but is there any trueth to what he is saying? This car is going on 2 road trips next month and i cant afford to be down.
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
it should be "callibrated" for the correct lb/hr injector. otherwise it can't control the fuel efficiently.
Transmission: 4L80E/4L80E
