1992 LSx swap
Old Mar 20, 2012 | 01:16 AM
crimsoncomedian's Avatar
1992 LSx swap
Hi. I am new to the forums and new to building/swapping/working on/etc. engines. I recently purchased a 2003 5.3l Vortec from a wrecked silverado. I will be purchasing a 1992 z28 later this week, I hope. It will be a 82-92 IROC style for sure tho. I am not looking to do anything too crazy right off. I basically am just looking to swap the engine into the chassis and get it running well, then I will start tweaking performance etc.
what i have:
-2003 5.3l vortec (LM7) complete from oil pan to intake
-wiring harness and ecm matching the motor
-all the brackets for the truck accessory layout
-alternator and a/c compressor
what is missing:
-power steering pump
-chassis
-transmission
So basically, what I need to know is:
-will the basic F-body accessory layout fit into any 82-92 chassis?
-which motor mounts should i get from where?
-will the stock truck intake, fuel rods, etc. work? (chassis i should be getting has a cowl hood)
-will the stock truck exhaust manifold fit into a 82-92?
-what oil pan should i go with?
-can i run the mechanical fan that came on the engine?
-will a 4l60e bolt up to the engine without modification? and do the stock wiring harnesses work with them?
-do i need to do anything with the fuel system? i am not sure if what was in the 82-92 camaros would work with my engine.
My car will be closest to a daily driver more than anything. It won't be driven daily, but it will be driven often. I have about $1500-2000 to play with. And like I said I am not looking for anything more than just what the stock performance from the engine is, for now. I just want to get it in and driving for the time being. Any help/info is GREATLY appreciated. Thanks. Let me know if I left out anything pertinent.
Old Mar 20, 2012 | 08:36 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: 1992 LSx swap
https://www.thirdgen.org/forums/ltx-...third-gen.html
Old Mar 20, 2012 | 09:42 AM
Re: 1992 LSx swap
Yea, I stayed up late as crap last night reading every bit of the guide. But the main things I did not find are:
-will the stock truck exhaust headers fit into a 92 z28 chassis?
-will a mechanical fan setup that is stock on the engine fit?
Old Mar 20, 2012 | 09:47 AM
Jim85IROC's Avatar
Re: 1992 LSx swap
I'm not sure on the truck manifolds, but I know it's been discussed, so doing a search in that forum should give you all the answers you need.
As for the mechanical fan, that poses a bit of a challenge. I'm sure it'll line up fairly well with the stock radiator. You may just need to make a new fan shroud. The problem is that the trucks are the only LS motors with mechanical fans, and their water pump outlet causes other issues, as well as the fact that the truck accessories don't fit well in the cars, and the truck water pump won't work with f-body accessories. Plus the 92Z already has electric fans, so it doesn't really make sense to revert back to a mechanical fan. Just utilize the stock 92 fans.
Old Mar 20, 2012 | 09:49 AM
UnstableAviator's Avatar
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
Re: 1992 LSx swap
No on both questions. The good news is 4th gen manifolds do indeed work, and you can buy those for $50 on ebay, LS1tech, etc etc. You can't use the O2 sensor on the driver side though, gotta plug it and install one downstream.
The fans are no big deal since the stock 3rd gen dual fans work great. Or stock 4th gen dual fans. Or any other "custom" electric fan setup you'd like.
Old Mar 20, 2012 | 09:50 AM
Re: 1992 LSx swap
Thanks, both of you.
Old Mar 23, 2012 | 09:31 AM
Re: 1992 LSx swap
Getting my chassis this weekend and just making sure what all mounts are needed. Do I need all these listed below?
(left) engine mounts on engine when i got it, (mid) 3rd gen clamshells for camaro and (right) motor mounts for a 3rd gen LSx swap
Attached Thumbnails 1992 LSx swap-1582920715829208.jpg   1992 LSx swap-gmlsclamshell.jpg   1992 LSx swap-sp971.jpg
Last edited by crimsoncomedian; Mar 23, 2012 at 09:35 AM. Reason: photos not showing up
Old Mar 23, 2012 | 11:57 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 1992 LSx swap
mounts on the left can be tossed, won't do any good in a 3rd gen swap. the ones in the middle appear to be 4th gen mounts, but are what you'd need to use the conversion mounts you shown on the right.
Old Mar 23, 2012 | 12:00 PM
Re: 1992 LSx swap
ok, so the ones on the right take place of the original stock mount brackets that bolt onto the engine and then you mount the middle to the crossmember. is that right?
Old Mar 23, 2012 | 01:32 PM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
Re: 1992 LSx swap
other way around, the red stands mount to X member, clamshells mount to engine, better off buying the clamshells used on LS1tech, cheaper.
Old Mar 23, 2012 | 01:34 PM
Re: 1992 LSx swap
yea, i figured they were reversed. thanks a ton for the info on them cheaper at ls1tech!
Vintageracer
Jan 10, 2020 05:33 PM
1992CamaroGirl
Dec 25, 2017 08:45 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
zayne0
Aug 24, 2015 07:22 PM
