can't get ls to fit
Old Mar 25, 2012 | 01:39 PM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
can't get ls to fit
okay i am using a spohn k frame and their mounts to a set of clamshells with unknown origin when i got them was told they were f body.the problem is i cant get the mount holes to line up. i left everything loose and went as far as going from 7/16 bolt to a 3/8 just to see what i am up against,doing that i am about a hole out from the engine mount to k frame.i would by new clamshells but i am not sure.just wondering if anyone else has had this problem
Old Mar 25, 2012 | 05:28 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: can't get ls to fit
any chance you could get a shot of the mounts and clamshells? no need to keep fighting if something's not correct.
on topic, i had the wrestle with both my 5.3 and my 6.0 when it came time to get them seated. i ended installing the kmember side of things loose so i could adjust in any direction possible and still fought for about 30 min to get things bolted up
Old Mar 25, 2012 | 07:49 PM
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
Yea, pics would help us help you, sometimes these 'bolt in' swaps need a bit of persuading!
Old Mar 25, 2012 | 07:50 PM
88blackiroc's Avatar
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
I have heard of alot of problems with most of these aftermarket cross members.
Old Mar 25, 2012 | 08:01 PM
driver101's Avatar
will take some pictures tomorrow i have had enough of the car today,may also see what a set of factory fbody mounts cost
Old Mar 26, 2012 | 07:38 PM
driver101's Avatar
how do i post pics??
Old Mar 26, 2012 | 11:18 PM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Use a photobucket account.
Old Mar 27, 2012 | 12:17 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Upload the pics to photobucket, then copy the HTML and paste it here. It'll start with [img]
Old Mar 27, 2012 | 04:11 PM
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
Just email it to some one here. My email is jasontejada@yahoo.com
Old Mar 28, 2012 | 10:07 PM
driver101's Avatar
will send pics shortly i figured the easiest way was to chop up the right hand mount and move the postion of mount.i have a buddy coming by tomorrow with a welder to weld everything up.it cost me a heater box but this is by fas the easiest way to make it fit with out remming out holes and trying to make it work
Old Mar 28, 2012 | 11:56 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I had a similar issue with mine, but only when I had removed the stock Fbody clamshells with rubber bushings to put in Prothane bushings. That was the hardest job I've ever done. I had the bolt one hole's width off from where it needed to be, ended up having to jack the engine up a bit from the oil pan and using two crow bars (used the help of my dad and my uncle), and it still took me like 4 hrs of fighting the darn thing to get it to go in finally. It's definitely a job that you only want to do once.
Old Mar 29, 2012 | 06:20 PM
POP6482's Avatar
Car: 1989 Iroc-Z Convertible
Engine: 6.0 LQ4 LSX
Axle/Gears: Moser 12 bolt w/4.11s
Blue...I also had to give the motor a little persuasion to get the second bolt through the mount. What a B&*^%!! Couple hours and beers later, it was in. That was probably the hardest part of the entire swap for me.
Did this by myself with 2 crowbars and 2 jacks
Old Mar 30, 2012 | 11:45 PM
driver101's Avatar
got mount remade fits awesome
Old Mar 31, 2012 | 07:24 AM
POP6482's Avatar
Engine: 6.0 LQ4 LSX
Glad to hear!
Fronzizzle
Feb 9, 2017 09:31 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
