lt1 swap: motor wont completely start
Old May 7, 2012 | 09:55 PM
SS350scott's Avatar
Car: 1988 camaro
Engine: 350 ci LT1
Axle/Gears: Ford 9in w/ Strange 3.70s
hi everyone,
i have been doing a complete restoration on my 1988 camaro, as well as swaping a 1996 impala ss lt1 w/ 4l60E tranny. motor is in the car and wired up, however the transmission is not and i currently have the old v6 and the impala wiring harnesses in it. so my questions are: where do i get a complete wiring harness to fit a 1996 lt1 in a 1988 camaro, and the car will only turn over, not actually start. i was wondering if the tranny sensors and what not are throwing off the ecm or if the chip in the key is the reason it will not start because i do not have the impala key. please help and please let me know if it is something different or if anyone else has crossed these issues.
thanks a lot,
Chase
Old May 7, 2012 | 11:12 PM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
Re: lt1 swap: motor wont completely start
well it is reading a vac leak the 4.3 sucks up less air that a 5.7. So all the extra air is like a massive leak so it will never run. U need a lt1 ecu from a ss imp. That's what I was told. But I'm sure u need a lt1 ecu
Old May 8, 2012 | 07:49 AM
SS350scott's Avatar
Car: 1988 camaro
Engine: 350 ci LT1
well im told i have a 5.7 ecu.
anything else you could think of?
thanks for the help!
Old May 8, 2012 | 01:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Do you have the LT1 PCM? Or, a 350 ECM from a 3rd gen?
I'm assuming the LT1 PCM, but what you're saying is confusing.
The easiest way to handle VATS is to have it programmed out of the PCM.
Old May 8, 2012 | 10:19 PM
SS350scott's Avatar
Car: 1988 camaro
Engine: 350 ci LT1
i bought a 1996 lt1 that was originally in an impala ss. to my knowledge, it is the original lt1 ecm
Old May 9, 2012 | 07:43 AM
Z28 MeTaL HeAd's Avatar
Engine: Carb'd LT1 w/ a Cam :)
Axle/Gears: Moser 9" w/ 3.75 gears
Its not working because you cant just take an LT1 harness and plug it into a 3rd gen. It doesnt work that way. You need a CONVERSION harness. You need to make this by combining the LT1 engine harness with the factory 3rd gen harness.
Read pockets thread on how to do this yourself:
https://www.thirdgen.org/forums/ltx-...p-3rd-gen.html
Old May 9, 2012 | 08:24 AM
SS350scott's Avatar
Car: 1988 camaro
Engine: 350 ci LT1
well i do have both harnesses in the car but ill take a look at your link
thanks!
Old May 9, 2012 | 08:08 PM
cerhart's Avatar
Car: berlinetta
Engine: Lt1
Transmission: t56
I Think we all need a little more info on what u have done up to this point what wiring is hooked up/if you've mated the harnesses and yes vats will hold u up definitely a priority before first start
Terrell351
Jun 13, 2021 01:13 PM
midge54
Dec 27, 2019 04:14 PM
Casey Meyers
Mar 2, 2016 10:46 AM
TheExaminer
Aug 26, 2015 04:59 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
