Poly Motor mounts and BMR LS1 K-Member Issues
Old May 20, 2012 | 08:13 PM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
Well I went to put my motor in yesterday and I had purchased a BMR k-member and a set of Prothane poly engine mounts for the LS1. When I went to install the 2 together there was no way to get the motor to fit in the k-member. The poly mounts made it so the mount itself was a good half of an inch from dropping in. I tried to pry it back and for it in and I could never even get it close. I could get one side in but there was no way to get the other one in. I even bent the tabs on the side i could get in and still nothing. I put the stock rubber mounts back in and it went right in. Anyone else have this problem? Should I try a different brand of poly mount? I really do not want to shave down the poly mounts if that is a solution.
Old May 21, 2012 | 02:45 PM
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
Transmission: T56 Magnum
Axle/Gears: Strange S60, 4.10s
Re: Poly Motor mounts and BMR LS1 K-Member Issues
Any pics? Shouldn't have to bend any tabs on the mounts.
Are you sure you had the Prothane mounts oriented correctly when installing them into the clam shells themselves?
Old May 21, 2012 | 07:06 PM
rickyzZ28's Avatar
Car: 1990 RS
I did not snap any pics of it and I just put the stock mounts back in and put the motor in. The tabs actually bent when I was prying it trying to get the one side to drop in. I tried to drop them both in at the same time, one at a time, even unbolted the mount from the block and into the k-member and it still would not line up. The mounts are both the same so the orientation can only go one way. To me it almost looked like the mount itself was made wrong so the steel part where the bolt goes through did not sit in the middle. Maybe they are supposed to be like that, but who knows. Thanks for your help.
Old Aug 28, 2012 | 10:17 AM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
Sounds similar to the question I have. Looking at these mounts in their clamshells, How do you know which one will go on the drivers side vs the passenger? The offset of the insert realy is confusing? I am still looking for the answer. Prothane could not help.
Attached Thumbnails Poly Motor mounts and BMR LS1 K-Member Issues-img_0101.jpg
Old Aug 28, 2012 | 10:32 AM
Tinbender59's Avatar
Car: 1997 K1500 SS/SB
Engine: LT1 with TPI on top
Transmission: 4L60E/np241,
I will have to look but I believe that the bushings are in backwards. As I recall when using the "3" hole mounting, the "2" adjacent holes are on the top, or outside. Which according to your pictures has the "bars" setting High when they should be setting low, the whole geometry is off. I'll get pictures later today.
Old Aug 28, 2012 | 11:03 AM
jazzdadss's Avatar
Car: 1989 IROC LSX
Transmission: 4L65E
Thanks Tinbender, And not to hijack your thread RickyzZ28. As per the instructions they should be in the clamshells correctly. The question is what side does the insert stick out to the front, Driver or passenger?
Attached Thumbnails Poly Motor mounts and BMR LS1 K-Member Issues-img_0495.jpg
Old Aug 28, 2012 | 11:39 AM
blakecharles's Avatar
bump... I'm about to upgrade to poly lsx mounts and need to know the same thing
Old Aug 28, 2012 | 12:03 PM
rickyzZ28's Avatar
Car: 1990 RS
No problem and its not a hijack. I never could get my poly mounts to fit in the K-member. I just put the stock mounts back in. I am going to order a different brand this winter and see if they fit any better. As for the orientation if I remember correctly once you install them on the motor they will only bolt on one way. Yours look correct in the picture jazzdadss. There is no way to flip them as they really only fit in the mount one way.
Old Aug 28, 2012 | 02:40 PM
jazzdadss's Avatar
Car: 1989 IROC LSX
Transmission: 4L65E
Just a couple more pics to show the delema which is illogical and cant physicaly be correct. With the drivers side the insert is to the rear, with the passenger side the insert is to the front.
Attached Thumbnails Poly Motor mounts and BMR LS1 K-Member Issues-img_7127.jpg   Poly Motor mounts and BMR LS1 K-Member Issues-img_9512.jpg
Old Aug 28, 2012 | 10:22 PM
oh man, you got it all wrong those pieces go on the frame, they are called the saddles, I will get the pictures of both halves in the morning (if I have time) Cataract surgery at 12 noon, ye Haw!!!
Old Aug 29, 2012 | 01:31 AM
ok here is the motor mount uppers, "clam shells" "rider 1 & Rider2 and the lower Or saddle is here as well. you need 3 holes 2 high and 1 low to bolt the Saddles to the frame, further you will notice that the Clam shells have 3 holes that match perfectly to the motor mount bosses on the motor. I will see if I can get better pictures if needed. I have a couple of motors out that I can use. the saddle is actually a V6 unit but the V8 sets the same way 2 bolts high single low, and if you have only 1 bar on the rubber I goes low, so as not to be in the way when the clam shells on the motor are lowered into place.
Attached Thumbnails Poly Motor mounts and BMR LS1 K-Member Issues-rider2.jpg   Poly Motor mounts and BMR LS1 K-Member Issues-rider-1.jpg   Poly Motor mounts and BMR LS1 K-Member Issues-saddle-1.jpg
Old Aug 29, 2012 | 06:04 AM
jazzdadss's Avatar
Car: 1989 IROC LSX
Transmission: 4L65E
Thats the old style, for my LS swap I am using the new style. This is a borrowed pic from dpresd68. I.m hoping he can chime in.
Old Aug 29, 2012 | 11:24 AM
rickyzZ28's Avatar
Car: 1990 RS
jazzdadss I think that the pictures you posted are the only way the mounts will fit. Mine are exactly like that and even the stock one looks like 1 side sticks out further than the other. On the part of the mount that bolts to the engine block there was a tab so you could only install them on the motor one way and the poly mounts only fit in it one way as well. I think you have them right.
Old Aug 29, 2012 | 06:26 PM
dprest68's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
I thought that pic looked familiar. I am out of town, but I will look for other pics when I get home that may help.
Old Aug 29, 2012 | 10:10 PM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
I have the BMR K. Trying to remember, think I used stock mounts because the polys would not fit. Can not check, for sure, as I am away from the car right now, but I am pretty sure that is the case. Here's the thread, but it's window dressing. No pics of the motor mounts.
https://www.thirdgen.org/forums/ltx-...u-gets-c5.html
The K should add a bunch of stiffness. Not having poly motor mounts should not be a big deal. Good luck.
Frozer!!!
Jan 19, 2024 04:55 PM
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
