Where I am so far.. [Iron L76 clone swap]
Old May 30, 2012 | 03:19 PM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
ALMOST ready for paint:
cylinder block should be done this week. got custom ring set: HTD top, Napier 2nd, Std oil. 4.020 bored.
still need cam bearings..
Old May 30, 2012 | 04:24 PM
dprest68's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
Re: Where I am so far.. [Iron L76 clone swap]
Wow! Looks like you put a lot of work into getting that cleaned-up for paint! What color are you going to paint it? Are you planning on painting the rusty K-member?
Old May 30, 2012 | 04:37 PM
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
for now, im not worrying about the K. eventually itll get a new k so im not going to waste my time on it. the engine bay is going to be satin black. im using eastwoods 2k ceramic chassis paint. masking off the car port was a pita
Old May 30, 2012 | 05:37 PM
dprest68's Avatar
Engine: cammed LS1
Ah, okay. I'm sure it was. Do you have an engine ready to put in it?
Old May 30, 2012 | 07:26 PM
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
block will be back this week so i can assemble (will have pics of that too)
Old May 31, 2012 | 05:34 PM
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
Primer laid bitches, not bad for first time spraying. one big screw up on the radiator support but ill sand it to blend and should hide well:
Me with Respirator on, i ave a separate one for the base coat which has isocynates in it:
Old May 31, 2012 | 06:42 PM
dprest68's Avatar
Engine: cammed LS1
Hey... I'm no bitch! LOL
Seriously though, It looks like you did a great job to me.
I like the last pic... "Luke, I am your father!" Hopefully you're old enough to get that one!
Old May 31, 2012 | 09:54 PM
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
i went through the primer in a couple spots sanding but im going to touch it up with some rustoleum sandable primer i have
Old Jun 3, 2012 | 08:38 PM
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
first coat laid, waiting for it to flash. waiting til im done spraying to put up the pics.
Old Jun 5, 2012 | 03:36 PM
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
Chuck84TA
Jul 15, 2016 09:05 PM
InfinityShade
Feb 21, 2016 01:29 PM
sailtexas186548
Jan 19, 2016 12:21 PM
InfinityShade
Aug 22, 2015 08:00 PM
