corvette lt1 question
Old Jun 13, 2012 | 01:59 PM
Method_z28's Avatar
Car: 92 camaro z28
Any difference in swapping a camaro lt1 or a corvette lt1?
Old Jun 13, 2012 | 03:32 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
Re: corvette lt1 question
Depends on what you mean?
If the motor comes with accessories the corvette has the a/c at the top right facing the motor and f bodys had them on the bottom left so you have to notch the k-member a little.
Intake wise the fuel rail on a vette comes in on the passenger side so I think you'd be better off with an f-body fuel rail. not sure if it fits the vettes intake though.
If you mean motor wise some have 4 bolt mains if it was a vette other than that they are mostly the same.
I went with the f-body one and it was really straightforward just do alot of research on here and you'll be fine.
Old Jun 13, 2012 | 04:03 PM
Method_z28's Avatar
Car: 92 camaro z28
Thanks. I was just seeing what was an easier swap.
Old Jun 13, 2012 | 05:49 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
I want the vette accessory bracket system so I can have a/c and not not h the k member.
Old Jun 13, 2012 | 06:23 PM
Car: Camaro RS
All I did to clear mine was smack it with a ball peen hammer a few times. only needed an inch dent at maximum. Not saying vette accessories aren't worth it but I usually just go with what I have. I would recommend starting with a donor car. made my life much easier.
Love your wheel choice btw
Old Jun 14, 2012 | 06:25 AM
Method_z28's Avatar
Car: 92 camaro z28
thanks. So it doesnt really matter where I get this lt1 if its out a vette,camaro, or a roadmaster since im gonna be rebuilding it and buying aftermarket heads? I can just get a hell of a deal on a vette lt1 thus why I am asking.
Old Jun 14, 2012 | 05:32 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Harness is going to have a different layout, from experience doing harness conversions the caprice/impala harness is the best for the thirdgen chassis.
Front accessorys the corvette stuff eliminates the notching of the crossmember, but also requires longer a/c hoses and running stuff across the bay, personally i'd rather stick with the fbody stuff for layout and cleanliness, realistically if the deal is right though, everything for the LT1's is cheap.
Old Jun 20, 2012 | 11:54 PM
FASTERTHANUMARK's Avatar
Car: 1970 Nova
Engine: 850HP 383
Transmission: TH400 w/ Brake
Axle/Gears: 4.88 12 Bolt
Got any more questions hit me up cuz Ive been there also Lol. Heres some pics
https://www.thirdgen.org/forums/vbga...=view&id=25683
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
87iroctheo
Dec 4, 2016 11:47 AM
redmaroz
Aug 16, 2015 11:40 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
