Question for you who have/has swap to a lt1 from a 350 tpi.
Old Jul 13, 2012 | 01:15 PM
evo-offer's Avatar
how did you´ve guys feel after swaping to a lt1 engine? do you use your car on the streets or track? best answer for me is from them who uses it on the streets. If i´m not got i wrong so has the lt1 engine more torque on higher rpms than the 350. i´m thinking of swaping to a lt1 but i´m not sure if it worth it or if it´s better to upgrade the 350 tpi? I can say that the car will only roll on the streets and maybe sometimes on the track.
Old Jul 13, 2012 | 01:46 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: Question for you who have/has swap to a lt1 from a 350 tpi.
10 times out of 10 the LT1 is a better choice.
Old Jul 13, 2012 | 01:57 PM
evo-offer's Avatar
could you explain why?
Old Jul 13, 2012 | 02:03 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I may be better to just install a better head and intake (stealth/miniram) on your 350TPI than deal with the headache (opticrap/remote mount coolant hoses/an more) of that swap.
If your going to swap go LS.
Old Jul 13, 2012 | 02:25 PM
evo-offer's Avatar
okey. can you recomend some good alu heads? Is this a good intake:
http://www.summitracing.com/parts/EDL-71383/
or this:
http://www.ebay.com/itm/Weiand-Intak...item4d02f545f2
Old Jul 13, 2012 | 02:50 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Far better flowing heads, and a far better ecu are two of the biggest.
Nice compact front accessory drive with 124 or 140A alternator are a big plus also.
Sure you can hack this and that together and eventually upgrade the TPI engine to perform the same, but in the end you'll have spent more and done a lot more work.
Old Jul 13, 2012 | 02:51 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Remote mount coolant hoses ?
What in the world are you talking about ?
Have you actually done any LTx / LSx swaps ?
Old Jul 13, 2012 | 03:16 PM
TTOP350's Avatar
Was posting while cooking/eating.
I'm talking about the nasty remote T-stat and related hoses.
Yes, I have done several swaps. Working as a planner/ install tech in performance shops on an off for 20 plus yrs, one tends to pic up a few pointers here an there.
Even stuffed a built LT1 into a newer S10. What a pain.
I stand by my statment that a simple head, intake an maybe a cam swap will be cheaper and make as much power if not more power than a LT swap.
The LS is a faaar better way to spend your money if you want 2 do a swap.
Old Jul 13, 2012 | 03:30 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
He clearly stated that he was looking to swap the whole engine.
A remote thermostat is nowhere in the requirements, nor is there any reason to make him think that he'd need one.
The Coolant hoses for an LT1 into a thirdgen are quite simple.
Old Jul 13, 2012 | 03:42 PM
evo-offer's Avatar
Yes i meant to swap the whole engine vs upgrade the 350 tpi. who people who done that experience it after the swap.
Old Jul 13, 2012 | 03:45 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Main things you need / will need to do:
Harness modification
ps hoses
fuel lines
LT1 radiator hoses
If you want a/c you'll need to notch the engine crossmember and need custom hoses, preferribly for this use edelbrocks headers, if you arent doing a/c, use the biggest you can find reasonably.
Old Jul 13, 2012 | 04:04 PM
evo-offer's Avatar
ps hoses
fuel lines
LT1 radiator hoses
good to know. so in the end, it is tha same work to put in a ls1 as a lt1 engine basicly?
Old Jul 13, 2012 | 04:07 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Yes and no.
LS1 at min will require a custom Y pipe / exhaust work, lots of thirdgen header/ypipes will bolt right up with the LT1.
LT1 just uses thirdgen mounts and done.
Old Jul 13, 2012 | 04:14 PM
TTOP350's Avatar
Hoooly crap... I got crossed up and was thinking about swaping just the Intake on a older SBC. I need some sleep badly.
Sooo anyway I'll still stand by statements (other than the t-stat)
If your going to swap, step up and go LS.
Old Jul 13, 2012 | 04:42 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
While the LS1 is nice, and does make great power, blindly overlooking the LT1 benefits like you are isnt the greatest plan.
Realistically for something sub 430 whp NA, the LT1 is going to cost less.
Beyond that, yes an LS1 is the way to go, but for the majority of people, $/hp matters.
Old Jul 13, 2012 | 05:10 PM
TTOP350's Avatar
Changing opti sparks all the time isnt my idea of a good time. I've seen them last but they can be a big $$ problem.
A stock LS is 300-400hp(depending on yr an model) A LT is 275-340ish (depending on yr an model)?
For either swap,By selling the stock items, if you buy a complete donr car, you can just about part the doner out and pay 4 your swap.
Old Jul 17, 2012 | 04:10 PM
evo-offer's Avatar
the problem for me that i can´t put in a ls1 engine legal unless i change the drivetrain,suspension and brakes that costs a lots of money BUT if i´ll go with the lt1 i dont need that. the car will more o less only go on the streets and maybe on track. so what do you guys think, is it worth the swap? i can sell the 350 tpi engine here in sweden for the same price that a lt1 cost in usa. i´ve also gonna put in a 4 gen dash board and ect so it should be easier also with the wiring?
midge54
Sep 2, 2020 07:13 PM
midge54
Jan 29, 2017 07:00 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
st.evel07
Aug 13, 2015 06:15 PM
