LS6 swap but need adivce
Old Aug 1, 2012 | 08:36 PM
DiabolicalRS's Avatar
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
so my dad has an ls6 from his vette but he did a lsx swap and has this engine on the stand. im not goin to start yet but i do want to start on my wiring harness my plan is to go to the jy and get a truck harness...BUT...i read some were on here that you would need a certain harness. but while on youtube searching on how to do my harness these guys just cut and splice what they needed so i answered that question, now but what about the computer from the truck would it matter if it a truck computer cause it will get tuned anyways am i right? ill be goin tomorrow to thejy to get the harness are there any special tools i need to take certain connections off?
some of the vids i looked at:
Old Aug 1, 2012 | 11:38 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Re: LS6 swap but need adivce
You can use a truck harness if you like but you need to be careful what year truck harness you get.Same with using a truck ecm.But if you plan on buying a ecm seperately then get one from a vender that will have a better base map for what you will be running.I bought mine on ebay i think from spareecm and just told them what motor i was using and what changes I needed.It was cheap too.
Pinouts between the truck vs car harnesses arent a major deal aside from the normal mods needed to be done for the swap in general.Start reading the stickies in here instead of those youtube videos as the stickies are more direct of where to make your connections in the car for full functionality.
As far as removing connectors.. small simple flathead for some of the security locks and then squeeze and pull lol.
Old Aug 2, 2012 | 02:50 AM
Car: '90 Camaro
Engine: 305 tbi
thanks for replying! i did reread the stickies again and i remember some where last time i read i seen which truck pcm i need but cant find it now, any way you can steer me in the right direction?
EDIT: i did some research and seems like they covered using a truck LS motor with the ls1 wiring harness but not what im lookin for, or atleast thats what i think. i need to know which truck harness can i use for a LS6.
Old Aug 2, 2012 | 07:25 PM
Pocket's Avatar
Car: 91 Trans Am
Any GEN III
To make a truck harness look anything but a disaster under the 3rd gen hood, you'll have to strip and rebuild it. Which method you use is irrelevant as the end is result is the same. No truck harness will work on a car style intake without changes, no getting around that, so buy the cheapest LSx harness you can get your hands on and go to town
Old Aug 2, 2012 | 08:35 PM
Car: '90 Camaro
Engine: 305 tbi
ahh ok see theres my answer haha alright well ill do some lookin around for a car harness i've also thought bout goin the carb route are there any difference in hp and tq between the two if the same engine had everything the same but one had a carb and the other was fi?
Old Aug 4, 2012 | 03:01 PM
Pocket's Avatar
Car: 91 Trans Am
For the camaro half of the harness, you need one from a 90-92 Fbody. V6, TBI, TPI does not matter
The body pinouts changed year to year, so you have to choose one within a year range. Going outside the range will still work, but you must repin them prior to even using them. Not fun
Old Aug 4, 2012 | 05:36 PM
Car: '90 Camaro
Engine: 305 tbi
yea i see, i have a friens doing a ls1 swap but he's getting his stuff from speartech but i heard of their prices and idk what i want just yet. i know i need to do alot more research but im still tinkering with the idea of carb ls6 with milled 5.3 heads. now for the carb lsx guys can you run a dizzy or do you not have to go with one?
Old Aug 4, 2012 | 08:36 PM
UnstableAviator's Avatar
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
Do more research and don't run a carb! MSD makes an engine controller which takes care of the ignition for carbed vehicles, but dang man...with a compete ls6 on the stand there's no way is even think about a metered fuel leak (carb) for fueling.
The wiring seems intimidating at first but it really isn't that difficult. Plus, with fuel injection you'll drive the car more and love the throttle response and economy. I've out more miles on my LS1 swap this summer (~3,000) than I ever did with the carbed old sbc engines I had in the past.
Old Aug 7, 2012 | 02:01 AM
Car: '90 Camaro
Engine: 305 tbi
yea i understand, i think i have to make the holes on the intake ovals because of the 5.3 heads but again research!
deracer
Apr 11, 2016 12:04 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
