LT1 EFI vs LSx 5.3 carb
Old Aug 14, 2012 | 07:11 AM
haisud's Avatar
Hi!
Which swap gets better MPG LT1 with EFI or LM7 5.3 carb?
Old Aug 14, 2012 | 07:26 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: LT1 EFI vs LSx 5.3 carb
Guys will claim lsx carbs will get mileage but id rather put money on lt1 efi since there will be greater control of fuel and spark inputs which are needed when shooting for max mpg
Old Aug 14, 2012 | 07:48 AM
DIGGLER's Avatar
hands down the LT1 efi. LS1 efi tends to get a little better than the LT1 efi.
Old Aug 14, 2012 | 08:17 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
LT1 efi
Old Aug 14, 2012 | 10:37 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
5.3 with a well tuned carb knocking down economy as good as a lt1 still needs a cowl hood to run an air cleaner. Otherwise, odd comparrison. Great economy can be had from a carb, but efi as mentioned can have better tuning ability the is irrelevant to some and important to others.
Old Aug 14, 2012 | 10:43 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Good point about the hood and cleaner. Not sure how tall the carb lsx setups are. Carb can get mileage but it would take a good bit of time to do it and still dont have the greatest control of fuel and timing but not sure how the lsx timing boxes work. Zone89 could tell. Can it control timing versus rpm vs map like in the efi systems?
Old Aug 14, 2012 | 11:51 AM
haisud's Avatar
So i cant use stock hood with lt1 setup?
Old Aug 14, 2012 | 11:53 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
You can use lt1 efi with stock hood it sits lower than the tpi intakes. No one said anything about it not fitting.
The carbed intakes may or may not fit. The lm7 lsx style intakes usually sit high up
Old Aug 14, 2012 | 12:04 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Honestly depends if one is running fatter than the other throughout your RPM band...
Old Aug 14, 2012 | 12:06 PM
haisud's Avatar
What you guy thinks about ebay lt1 stand alone engine wiring harness kits?
http://www.ebay.com/itm/1994-95-LT1-...6fdefc&vxp=mtr
I have v6 camaro, i think its better use this kit than mess with v6 wiring harness?
Sorry for my bad english, im from europe
Old Aug 14, 2012 | 12:11 PM
Why not stick with what you got and go with a turbo, just an idea to throw at ya? By keeping the V6 you'll get the best gas mileage possible when the engine is under vacuum.
https://www.thirdgen.org/forums/powe...o-time-v3.html
Old Aug 14, 2012 | 12:18 PM
haisud's Avatar
But what about 3.8 v6 buick turbo engine? I know guy who sell his good stock condition 3.8 engine for 600euro. Is this easy swap?
Old Aug 14, 2012 | 12:27 PM
Yes, very easy swap. You can either run a V8 700R4 by using an adapter plate, or run the stock 200R4 with it. I would highly recommend the 200R4 simply because it doesn't lockout 4th gear at wide open throttle, but that's just me, as I'm a highway buff. For the computer look into Dynamic EFI's SFI-6, excellent price, and excellent product, or you can run the stock '7148 ECM, which is very easy to modify using a Turbo Tweak chip...
Old Aug 14, 2012 | 12:45 PM
haisud's Avatar
3.8 buick in fbody need custom fabricated engine mountings?
Old Aug 14, 2012 | 12:56 PM
No, just adapting the bellhousing to the 700R4 transmission because of the different BOP pattern, unless you of course just run the 200R4 that came with the Buick engine. Remember that the 3.8 Buick Turbo came in the '89 Trans Am, it bolts right in. Very easy swap. Here is NeilB's Camaro w/swap, find his build thread on the V6 board...
Old Aug 14, 2012 | 01:04 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
You can disable 4th gear lock out with 700r4 using the 80's efi computer control. Retrofitting that to a buick gn ecm i am not sure. Lt1 stuff also not sure as they started gettin electronic trannies at some point
Old Aug 14, 2012 | 01:14 PM
You can disable 4th gear lock out with 700r4 using the 80's efi computer control...
The only problem with that is that 4th gear is very weak in the 700R4, that is the only reason why I hesitate w/mine during higher RPM. Dana at ProBuilt would definitely have the fix for that of course. However, if he goes w/the 200R4 he won't have to worry about it...
Old Aug 14, 2012 | 01:42 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
True i just have yet to run into a situation where id want to be in 4th at high rpm.... I was doin 128 in the 1/4 in 3rd with plenty of room. No need to go faster. If so just gear it taller
200 does have a more favorable gear spread tho
Old Aug 14, 2012 | 01:48 PM
That's cuz you haven't come across that arrogant GT-R owner on the highway yet...
Old Aug 14, 2012 | 01:51 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Theres one around here from what i heard... Supras too. I have to worry alittle. Its why i still have 2.73 gears
Old Aug 14, 2012 | 01:58 PM
Its why i still have 2.73 gears...
I didn't know you were still running that tall of a gear ratio, where is your RPM at 80-mph?
Old Aug 14, 2012 | 02:12 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I will be swapping but i have th400 trans so it helps on highway. 80 would be 2800 rpm by the tire size but my converter would likely be slippin a tad higher and id be on verge of boost lol
This new combo doesnt like tall gears. Turbos like load but not this much. 3.08 or 3.31 may be in order
Sorry for the threadjack
Old Aug 14, 2012 | 05:09 PM
haisud's Avatar
Where i can find wiring harness for 3.8 buick engine? My Camaro is 2.8 V6 or can modified my own car harness do work with 3.8 SFI engine? I need know easiest way to wire hareness.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Buggy Disaster
Sep 22, 2015 01:15 PM
Amillionoh7
Sep 11, 2015 11:36 AM
L0tuS
Sep 4, 2015 11:16 PM
