IDEA: STOP WATER PUMP FROM PUKING ON THE OPTI
Old Nov 4, 2012 | 11:44 PM
Tinbender59's Avatar
Car: 1997 K1500 SS/SB
Engine: LT1 with TPI on top
Transmission: 4L60E/np241,
today I got a start on my Water pump dumping on the opti idea. here is the front of the motor as it looked when pulled, then the second picture is to show the water weep hole in the water pump. tomorrow I will get to the parts house , pick up a drill bit a 1/4 NPT tap, a short 1/4 NPT nipple, 1/4 NPT elbow and a 1/4 NPT/barb. the plan is to drill the weep hole out , tap it, install the pipe fittings, re-install the pump, check clearance and get pictures for you all to see. Once this is all done you will be able to clamp a piece of hose to the barb and run it down under the motor out of harms way. more pictures tomorrow.
P.S. The initial clearance checks look like plenty of room
Attached Thumbnails IDEA: STOP WATER PUMP FROM PUKING ON THE OPTI-2012-11-04_13-18   IDEA: STOP WATER PUMP FROM PUKING ON THE OPTI-2012-11-04_13-27
Old Nov 5, 2012 | 07:36 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: IDEA: STOP WATER PUMP FROM PUKING ON THE OPTI
I like it... Never owned an LT...but I changed the water pump on one once. Not a fun job haha.
Just be careful how far you drill in for that pipe tap. Ide drill a little, tap, see how the nipple fits, then go some more. If you have a junk pump, might do a test run.
Not sure why the factory didnt come up with something similar!
J.
Old Nov 5, 2012 | 10:52 AM
Success!!! it actually works and clears!!! actually went with 1/8th pipe, not 1/4, drilling and tapping, drilled about 1/2 to 3/4 inch deap, never found the bottom of the hole.
Attached Thumbnails IDEA: STOP WATER PUMP FROM PUKING ON THE OPTI-2012-11-05_10-25   IDEA: STOP WATER PUMP FROM PUKING ON THE OPTI-2012-11-05_10-27   IDEA: STOP WATER PUMP FROM PUKING ON THE OPTI-2012-11-05_10-32
Old Nov 5, 2012 | 10:54 AM
in this picture you can see how close the "street L" is to the housing
Attached Thumbnails IDEA: STOP WATER PUMP FROM PUKING ON THE OPTI-2012-11-05_10-34
Old Nov 5, 2012 | 10:55 AM
this is the final before install install on the motor, had to rotate it 90 deg more to work like I wanted
Attached Thumbnails IDEA: STOP WATER PUMP FROM PUKING ON THE OPTI-2012-11-05_10-39
Old Nov 5, 2012 | 11:02 AM
here is the final installed on the motor
Attached Thumbnails IDEA: STOP WATER PUMP FROM PUKING ON THE OPTI-2012-11-05_10-40   IDEA: STOP WATER PUMP FROM PUKING ON THE OPTI-2012-11-05_10-40   IDEA: STOP WATER PUMP FROM PUKING ON THE OPTI-2012-11-05_10-41
Old Nov 5, 2012 | 11:06 AM
I certainly hope that the pictures aren't as distorted on your screen as they are on mine. if they are let me know , I will post them on Flikr.
Old Nov 6, 2012 | 12:00 PM
I thought that this was a great Idea???? save everybody a bunch of money and trouble ?????????????
Old Nov 7, 2012 | 07:39 AM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
seems like a good mod, but what if the waterpump gasket fails?
Old Nov 7, 2012 | 09:30 AM
I have never seen that one??? I don't know - possibly fire the mechanic LOL
Old Nov 7, 2012 | 10:44 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Are all the optispark issues just from the weep hole? Seems silly that the factory thought it was okay to leave it like that...
Old Nov 7, 2012 | 11:21 AM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
Another option is to just get an electric pump drive and it removes the possibility of the shaft seal going bad and leaking out the weep hole.
One thing I have seen with LT1 pumps as well is the pressed in heater hose tube fittings coming loose from the pump housing. I know of 3 local cars that this has happened to and on one car they fixed one side and then later had to turn around and fix the other.
Old Nov 7, 2012 | 11:30 AM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
No the issues are not only from the weep hole only, but getting wet from any water source or even moisture will almost certainly ruin it.
Also I did this years ago with my old LT1, but I just used a 1/8 NPT barb fitting and it was great. Now the car has a electric pump on it but it is a great idea.
Old Nov 9, 2012 | 01:43 AM
cool thanks man
Old Nov 9, 2012 | 07:16 AM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
think im going to give this mod a shot when my opti comes in the mail. Where did you run the coolant hose to from the barb fitting?
Old Nov 9, 2012 | 05:48 PM
haven't yet, it is still on the engine stand, it was just a crazzy idea that I thought would help y'all out. if I build my Convertible like I did my pick-up, this is not nessary for me
Old Nov 9, 2012 | 07:47 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
No one has an LT1 anymore lol. Good idea tho
Old Nov 9, 2012 | 08:20 PM
I know that makes them easier and cheaper for me. LOL
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
