lm7 into 90 camaro and boost...pic heavy
Old Feb 7, 2012 | 11:27 PM
accordlxrj's Avatar
hello all!! I'm new here but not new to automobiles nor fabrication.
I have a 90 camaro rs, It's been in my family since 91. About 6 years ago my father took it into Sears for a quick oil change before going to a family reunion. When he left, it got about 3 miles down the road and it started smoking like a train so he went back to Sears and they drained 5 of the 10 quarts of oil back out of it.....good bye piston rings.
They refused to do anything about it so its been sitting for 6 years waiting for me to play with it.
I have huge plans for this thing starting with the motor.
I am swapping in a lm7 from a 2003 burban and 4l60e from a 95 impala ss.
Coil over suspension with tubular A arms
Shaved bay
Cage
2010 camaro tail lights
And boost!
if anyone has done this or is in the process, can anyone provide me with info(a very detailed drawing) of the mounts you are running? I want to make my own mounts.
My goal with this car is to buy the least possible.
If anyone can help me that would be amazing. ! I will post pics of the car ASAP.
Old Feb 8, 2012 | 01:22 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Overfilling the crankcase did not wipe out the rings. It just pumped more oil into the combustion chamber. It would clean out fairly quickly if it was just driven. Might need to change the spark plugs due to oil fouling, but that's about it.
Now, LM7 is an LS-series swap. So, read the sticky. Pay particular attention to the link about starting with a truck engine.
The '95 4L60E isn't the best idea, as the Gen I/II crank-to-front-pump spacing is slightly different than Gen III. You either need a spacer for the flexplate, or a torque converter made for a Gen II transmission behind a Gen III engine.
Many people have done what you're talking about. Read the sticky and search the LTX and LSX engine swap subforum (where this is now). If you want to do boost, then check out the Power Adder forum (just don't plan on scrimping with that part).
I hope nobody has done Gen V tail lights in a 3rd gen, but that's probably been done, too. But, it wouldn't be detailed in the Engine Swap forum.
Old Feb 8, 2012 | 11:10 AM
accordlxrj's Avatar
Re: lm7 into 90 camaro. mount question.
I already bought the spacer and the motor is bolted to the tranny. I have already made my stand alone harness and fuel lines. I just need the mounts.
Old Feb 8, 2012 | 01:45 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
mount part numbers/info can be found here:
https://www.thirdgen.org/forums/ltx-...und-these.html
or you can look around at the 'tech forum, believe someone posted up measurements on that page
Old Mar 4, 2012 | 09:53 PM
accordlxrj's Avatar
Alright well im back and have some of my pics on the computer to share. Here are a couple.
not a very good pic but this is the car when i first pulled it in the garage.
CAMARO.jpg?t=1330311818
old motor
OLDMOTORCOMINGOUT.jpg?t=1330311999
old motor gone
EMPTYBAY.jpg?t=1330311850
mounts i made.
FINISHEDMOUNTS.jpg?t=1330311918
new motor
NEWMOTOR.jpg?t=1330311985
Old Mar 4, 2012 | 10:01 PM
accordlxrj's Avatar
harness
HARNESSAPART.jpg?t=1330311956
routing harness
ROUTINGHARNESS.jpg?t=1330312020
evap block off i made
EVAPBLOCKOFF.jpg?t=1330311883
modifying pan
CUTPAN.jpg?t=1330311851
FINISHEDPAN.jpg?t=1330311920
test fit mounts
MOUNTTESTFIT.jpg?t=1330311968
ENGINETESTFIT.jpg?t=1330311882
Old Mar 4, 2012 | 10:07 PM
accordlxrj's Avatar
now for the good stuff
turbo2.jpg?t=1330663376
turbo1.jpg?t=1330663374
mani2.jpg?t=1330919114
mani1.jpg?t=1330919107
it will all be finished in a couple days. i will be ready to take it out, finish weld it and clean and polish the welds and pipe.
Old Mar 5, 2012 | 02:08 AM
BlueMagicSS's Avatar
Car: 2000 Camaro SS/86 Iroc/89 Iroc(x2)
Transmission: 6 Speed
Axle/Gears: 4.10
Re: lm7 into 90 camaro and boost...pic heavy
You're going to have to find an LS1 intake and LS accessories, the truck setup wont work in the 3rd gen
Old Mar 5, 2012 | 07:31 AM
accordlxrj's Avatar
They work fine
Old Mar 5, 2012 | 07:53 AM
coptzer's Avatar
Car: 1986 IROC-Z
Engine: LS1-ish
Transmission: T56 stage II
Axle/Gears: S60 4:10's
Originally Posted by accordlxrj
They work fine
What are you going to be running for a hood? And nice welding by the way!
Old Mar 5, 2012 | 10:08 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
subbed!
Old Mar 5, 2012 | 11:02 AM
accordlxrj's Avatar
I'm going to run a cowl hood I guess or just cut a hole.
Thanks, i weld all day. I have a small fab business.
Old Mar 5, 2012 | 01:28 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Yes it will
Old Mar 5, 2012 | 07:18 PM
accordlxrj's Avatar
My turbo mani is built to work with all the accessories and in the stock location in third gen
Old Mar 5, 2012 | 07:23 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
are you still gonna put in 5th gen tails? please dont they wont look right. also you used solid mounts basically and you are still using all the truck accesories?
Old Mar 5, 2012 | 07:48 PM
accordlxrj's Avatar
I have seen the tail light conversion done and its sexxxy!!. Yes, I made solid mounts and I am keeping everything on the Motor as I received it except the fan.
Old Mar 14, 2012 | 05:27 PM
accordlxrj's Avatar
got the manifold done and someone already bought it.. another one in the works though.
finishedmani3.jpg?t=1331762752
finishedmani2.jpg?t=1331762743
Old Mar 31, 2012 | 05:59 PM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
Looks good I'd be interested in some pipes too. Why manifolds did you use on the motor?
Old Mar 31, 2012 | 09:17 PM
accordlxrj's Avatar
Factory cast lm7
Old Apr 1, 2012 | 08:27 PM
daddy33's Avatar
Car: '85 Camaro
yeah fab me up some pipes too! lol
Old Apr 1, 2012 | 08:43 PM
accordlxrj's Avatar
If you guys seriously want a manifold email me. Accordlxrj@AOL.com
I have 1 left that some one is supposed to be picking up this week. I have been making a couple at a time and if you want them I need to know how many sets of flanges to order.
Old Apr 1, 2012 | 11:43 PM
daddy33's Avatar
Car: '85 Camaro
Thanks for the offer bud, but I actually can't. I just paid $$$ for my dyno-tune and got my car finally up and running. But thanks anyways
But keep up the good work, I'll be following your progress and IF i ever turn to boost, I'll let you know
Old Apr 2, 2012 | 11:56 AM
crimsoncomedian's Avatar
definitely subbing to this one. was going to try doing this, but spent the $$$ and just got the ls1 front accessories instead. and nice work on the pipes!
Old Apr 2, 2012 | 01:08 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Im so keeping up with this. I might be interested in a set of manifolds and so on but want to wait to see the end look as im pretty picky as to the way I want to run it
Old Apr 6, 2012 | 08:10 PM
accordlxrj's Avatar
GETTING NEW SUSPENSION AND MAKING CUSTOM A ARMS
Old Apr 7, 2012 | 08:36 AM
daddy33's Avatar
Car: '85 Camaro
What kind of coilovers are those?
Old Apr 7, 2012 | 09:45 AM
accordlxrj's Avatar
The fronts are koni sports with sleeves and the rears are koni 8212's
Old Apr 9, 2012 | 02:57 AM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
email sent about piping and mounts im armyracerws6@yahoo.com
Old Apr 9, 2012 | 07:09 AM
Brando5641's Avatar
I LOVE that paper towel holder lol
Its lookin good.
Old Apr 9, 2012 | 09:36 AM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Sub'd!
I'd like to see those tail lights, very curious.
Great work btw!
Old Apr 13, 2012 | 01:11 AM
Engine: ls1 soon
I emailed you about a week ago for a price on that piping and motor mounts and have yet to hear back from you
Old Jul 18, 2012 | 03:32 PM
evo-offer's Avatar
nice project.did you end it? i´m probably gonna do the same swap. did you take a lsx harnes or did you your own wiring?
Old Jul 18, 2012 | 04:28 PM
accordlxrj's Avatar
I'm still working on it. I took a brake to finish my bobber project. I made my own harness
Old Jul 18, 2012 | 04:30 PM
evo-offer's Avatar
sounds good. it seems to be more work to put in a 5.3 truck engine instead of a lsx.or i maybe only looks that way?
Old Jul 18, 2012 | 05:29 PM
accordlxrj's Avatar
I just don't have cash flow like most. It's in I'm just needing fuel lines and computer
Old Jul 18, 2012 | 05:31 PM
evo-offer's Avatar
You maybe missunderstood me. is it more work to put in a 5.3 truck engine instead of a (for example) ls1 engine? or is it the same?are you gonna keep the ac?
Old Jul 18, 2012 | 08:47 PM
accordlxrj's Avatar
They are the same you just require oil pan mod with the 5.3. I'm not running a/c
Old Jul 19, 2012 | 12:36 AM
evo-offer's Avatar
what mods do the oilpan need? swap to a ls1 f-body oilpan?
Old Nov 9, 2012 | 03:26 PM
accordlxrj's Avatar
Well I'm back at it. I decided to go with the ls1 intake manifold so that meant putting a ls1 water pump on and that meant switching everything over so I'm going to fbody relocation but I'm going to make all my own brackets. My goal with this build was to not buy anything except the motor and tranny and fabricate everything else unless it was impossible. Here are some pics.
Old Nov 9, 2012 | 03:41 PM
accordlxrj's Avatar
IMAG0298.jpg?t=1352346149
IMAG0299.jpg?t=1352346128
Old Nov 9, 2012 | 03:49 PM
accordlxrj's Avatar
Brackets to make the Holley rails fit the ls1 intake with 5.3 injectors
IMAG0287.jpg?t=1352181095
Stainless throttle cable bracket
IMAG0293.jpg?t=1352180990
Old Nov 9, 2012 | 04:22 PM
  #42
accordlxrj's Avatar
the start of a new set of turbo manifolds
IMAG0203.jpg?t=1352181081
IMAG0237.jpg?t=1352181135
Old Nov 9, 2012 | 04:24 PM
  #43
accordlxrj's Avatar
pic of mounts painted and installed
IMAG0201.jpg?t=1352498671
Old Nov 9, 2012 | 07:38 PM
  #44
Brando5641's Avatar
look at what i did to my truck water pump on my build link in my sig. Its a lot cheaper to run the truck stuff.
Old Nov 9, 2012 | 08:39 PM
  #45
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
looks clean. nice job on those mounts!
Old Nov 10, 2012 | 09:34 AM
  #46
accordlxrj's Avatar
I'm not going for cheap. I wanted to replace the water pump before I put it together anyway and I'm making the alternator bracket so really the only extra expense is going to be the balancer. I'm not sure about ps yet cause I really want to put a pinto manual rack under it.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
BADNBLK
Nov 16, 2016 09:12 AM
ezobens
Aug 19, 2015 10:29 PM
TreDeClaw
Aug 14, 2015 06:58 PM
MENINBLK
Aug 5, 2015 11:58 PM
