question on throttle bodies
Old Dec 15, 2012 | 05:57 PM
ransam's Avatar
Car: 88 trans am 72 olds cutlass
Engine: soon to be 5.3 455 olds
Transmission: soon to be t-56 2004r
Axle/Gears: 3.23 3.73
I have the stock 5.3 truck throttle body and have the chance to pick up a throttle body off of a 01 camaro for cheap. Would there be any gain by going to the car tb? Do the sensors fit from truck tb to car tb?
Old Dec 16, 2012 | 12:17 PM
Pocket's Avatar
Car: 91 Trans Am
Re: question on throttle bodies
Same thing with minor changes that do not affect performance in any way. All DBC TBs use the same rough casting
If the car TB you're looking at is ported/polished, you may pick up a little, but stock for stock cable TB theres no benefit
DBW TBs can get a benefit from larger OEM TBs as multiple castings were used from 78mm to 90mm. Car style TBs also got a faster motor than trucks
Old Dec 16, 2012 | 03:43 PM
ransam's Avatar
Thanks for the info.
Old Dec 16, 2012 | 03:59 PM
Prokilllsx's Avatar
Car: OVRMYHD
Engine: H/C/I LS1
Transmission: 4L60E 3,200 Edge stall
Axle/Gears: 9 bolt w/3.90
You got headers on it yet?
Old Dec 17, 2012 | 06:50 PM
ransam's Avatar
Not yet i am considering making 1 7/8 long tubes with true duel 3 inch exhaust. I plan on running nitrous also.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
